Weird engine oil level | FerrariChat
Discussion in 'Technical Q&A' started by 24000rpm, Feb 7, 2021.
  1. 24000rpm
    24000rpm F1 Rookie
    delete, wrong forum.
  2. Steve Magnusson
    26,932
    Not a good thing. On models checked when idling, they usually incorporate baffles inside the oil tank, or arrange the plumbing, to prevent the returning oil from getting on the dipstick and giving a false reading so those might be damaged/missing. However, coolant getting into the oil is possible, too -- have you noticed the coolant level being down or needing topping up lately?
  3. 24000rpm
    24000rpm F1 Rookie
    ok, since you replied, thank you.
    Its not like the oil level increased permanently. It is fluctuating. Last time it was 6 inches higher, and next thing you know, couple days later, its coming back to normal levels as before. at oil temp 180F ,idling , of course.
