Weird F1 indicator flashing!! | FerrariChat
Discussion in 'Technical Q&A' started by spidey, Nov 18, 2005.
  1. spidey
    spidey Karting
    Ok, just came in from a quick drive and my F1 indicator (i.e 4th gear) was flashing the gear number, instead of being constant. I changed gears and it went away.
    Any idea?
  2. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,976
    MD and NE
    Robbie
    Never done this before???
  3. spidey
    spidey Karting
    Yes, never before. Was the FI system not fully engaged in that particular gear ??
  4. TOC
    TOC Karting
    Sep 13, 2005
    245
    Montreal, Canada
    John T
    When the gear flashes, even Neutral, it means that the gear has not been engaged or disengaged properly. According the the owners manual, you should select Neutral first & then get into gear.
  5. pino
    pino Karting
    Nov 1, 2003
    208
    South Central PA
    Don't worry, it stored a trouble code. There's always a code...more than you can imagine. It keeps track of everything.
    When mine started flashing on occasion, it was time for a clutch.
    Not saying you have the same diagnosis, but if you want to find out, just connect it to an SD1/2 depending on car.
