Weird Fluid Leak | FerrariChat
Weird Fluid Leak
Discussion in '348/355' started by wda24729, Oct 2, 2015.
  1. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    #1 wda24729, Oct 2, 2015
    I moved my 348 out of the garage the other day and there was a small fluid leak on the floor. It wasn't engine oil, brake fluid or any other fluid I could recognise. So I got it up on the ramps and the drip was coming from the rear right hand side top 'A' arm bush. There was nothing above it and now that Ive got it up on the ramps, it hasn't dripped again.
    Photos show looking towards the back of the car. Any suggestions?
    http://www.ferrarichat.com/forum/attachment.php?attachmentid=21375
    http://www.ferrarichat.com/forum/attachment.php?attachmentid=2137591&stc=1&d=144380409690&stc=1&d=1443804096
  2. alexjack
    alexjack Karting
    Jun 29, 2013
    67
    New England
    Don
    Looks like coolant.
  3. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    After I had my last major done I had a small puddle under the car several weeks later. After I checked it out it was the compressor oil from the AC which leaked past the new seal they had installed. It was green in color but would be somewhat further forward on the right than what you have described. Just a thought.
  4. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    Thanks - Not coolant as mine is red and the fluid does have a slippery consistency.
    I'll have a look at the AC compressor but thats much further forward.
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,628
    San Carlos, CA
    Mitchell Le
    a 348? Red fluid? Did you happen to use red coolant? There is nothing on the right hand side except for brake fluid and coolant. Oil would be black.
  6. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    No my coolant is red, this fluid is more yellow and oily / slippery. This is why its weird, no leaks from above the bush, just from that position.
  7. yelcab
    Nov 29, 2001
    13,628
    San Carlos, CA
    Mitchell Le
    Was there any work done to it lately?
  8. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    No, apart from my extensive rear end refurb but that was completed early in the year and Ive used the car since with no issues. Im going to get it down off the ramps today for a closer inspection.
  9. hercfe
    hercfe Karting
    Apr 21, 2015
    194
    Northeast US
    Ben
    Red Line is yellow, did you replace the gear oil?
  10. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    Yes i did, a few months back though...i just find it strange its just happened. Had it up and down the ramps today, engine running, stopped , running....and nothing.
  11. Robbe
    Robbe Formula Junior
    622
    The Netherlands
    do you have a cat?
  12. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    Yes, cats fitted
  13. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    I think he was asking if you have a kitty, or one in the neighborhood who might have sprayed your car. Which does seem like a possibility. Would certainly be worth smelling the fluid to find out, since that would sure be a simple answer. If so, please don't do anything to hurt the little guy. Just put out some mothballs or search up some other solution. I know it's frustrating, but it's natural behavior for un-neutered males.
  14. Andy 355
    Andy 355 Formula Junior
    Jun 2, 2013
    434
    Ha. I was thinking the same thing!!! :)
  15. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    Ha..no definetly not cat, I'd recognise that smell! Although Ive no idea what it was. It hasn't reappeared since.
  16. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    Found it! Its the shock absorber leaking. Can these be repaired?
  17. yelcab
    Nov 29, 2001
    13,628
    San Carlos, CA
    Mitchell Le
    Ah that is obscure. You have to rebuild them or replace them.
  18. Ricambi America
    Sponsor Owner
    Contact Rob at: Delta Vee Motorsports He's the man. :)
  19. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    #19 wda24729, Oct 18, 2015
  20. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Bilstein or Delta Vee can rebuild them.
  21. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    Thanks - Will keep updated in case anyone has the same issue.
  22. dwwis
    dwwis Karting
    Oct 19, 2015
    68
    South Milwaukee Wi.
    Dennis Wesley
    I am having the same issue
    I am sending them off to Bilstein in California
    any way some one can give me /Bilstein part number please
  23. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    #23 wda24729, Dec 11, 2015
    Well in the end I decided to send all of my shocks off to a company who did a complete re-build on them. As you can see they have used a complete set of new internals (Bilstein will not rebuild) but also have a valve installed on the top of the strut which has 12 settings, No. 6 being factory, 0 being soft, 12 being firm. The new chromed parts of the strut are also all new. Excellent job.
    By the way, the poor coating seen on the one in the test rig is from when I originally sent my rear shocks to Bilstein!
    http://www.ferrarichat.com/forum/attachment.php?attachmentid=2169699&stc=1&d=1449850902
    http://www.ferrarichat.com/forum/attachment.php?attachmentid=2169700&
    http://www.ferrarichat.com/forum/attachment.php?attachmentid=2169701&stc=1&d=1449850902stc=1&d=1449850902
    http://www.ferrarichat.com/forum/attachment.php?attachmentid=2169702&stc=1&d=1449850902
  24. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    The company are also going to start making their own tubes for these as there has been quite a demand recently.
  25. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
    Email Caitlyn Jenner. She says her boyfriend is always leaking tranny fluid from somewhere. She might be able to help
