Weird gas smell | FerrariChat
Weird gas smell
Discussion in 'Technical Q&A' started by Schumi76, Nov 1, 2010.
  1. Schumi76
    Schumi76 Formula Junior
    Feb 15, 2006
    329
    NC
    Marco
    03/360 Spider stick with 10,000 miles on the clock.
    The last few times I drove around with the top down I noticed a small gas smell in the car.
    The weird thing is that I can only smell it when I am in 3rd gear or higher and under full acceleration and over 5,500 RPM. The gas smell is there for few seconds and then goes
    away. After I drove the car I checked for any possible gas leaks in the engine compartment. Everything looks dry and fine. No leak........
    Again, you can only smell it with the top down, 3rd gear or higher and under full acceleration and being over 5,500 RPM. With the top up and otherwise no gas smell.
    Any ideas guys ??? Thank you !!!
  2. f355spider
    f355spider F1 World Champ
    18,055
  3. Schumi76
    Feb 15, 2006
    329
    NC
    Marco
    I thought the spider top only has to come off on very early model year Spiders ???
  4. f355spider
    18,055
    #4 f355spider, Nov 1, 2010
    I'm not an expert on the subject, but not from the various threads I have read. I have not seen any exception made for later cars.
    Doesn't matter, you need a proper diagnosis first, which will require taking to a qualified shop.
