348 - Weird issue reinstalling 348 Alternator | FerrariChat
348 Weird issue reinstalling 348 Alternator
Discussion in '348/355' started by aballas, Jun 23, 2023.
  1. aballas
    aballas Karting
    Jul 29, 2017
    134
    Portland, OR
    Hi all,
    just recently rebuilt the 105A Denso alternator on my '94 348 Spider, and I'm having the weirdest issue getting it back in the car.
    A little background, the car was a little unique, it had a power steering conversion, using Mondial T parts and an F355 steering rack. I actually used this opportunity to go back to manual steering, and as such have removed the Mondial steering pump, which in turn changes the location of the upper mount for the alternator.
    I sourced the correct upper mount (p/n 149627), and went about reinstalling things.
    HOWEVER.... the mounting holes on the Alt no longer line up with the upper and lower mounting brackets. Its *close* but off by a few millimeters preventing me from being able to get both bolts in. To verify it wasn't the incorrect upper mount I also tried reinstalling it with the steering pump upper mount (as it was in the car previously) and I am running into the same issue.... a few mm (maybe 4-5mm) out of alignment.
    I cannot for the life of me figure out what would be causing this, or how to remedy it. Has anyone else run into a similar issue?
  2. fatbillybob
    Aug 10, 2002
    28,978
    socal
    For 348 there were 2 alternators. So possibly 2 mounts. Been years can't remember. Can you drill to size?
  3. fatbillybob
    Aug 10, 2002
    28,978
    socal
    Are there 2 mount part nos
  4. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #4 Ferrarium, Jun 23, 2023
    Need pic I'm afraid. I had my alternator and brackets off and I recall some issue getting them back on correct, can't recall exactly bit it was alignment related.
    There was Delco and Denso alternators but you said denso alternator and that bracket is the denso bracket. 144639 is the Delco part number. Maybe parts mixed up when sent.
    Is the upper bracket you have curved or straight like this, denso one is straight.
  5. aballas
    aballas Karting
    Jul 29, 2017
    134
    Portland, OR
    #5 aballas, Jun 23, 2023
  6. fatbillybob
    Aug 10, 2002
    28,978
    socal
    Maybe wrong alternator? But that top hole is a steel bushing in what looks like black delrin bushing. You could make an offset delrin bushing to still use that alternator. We do that all the time to get more camber on streetcars converted to race cars. You could know if that's possible by popping the black bushing out and seeing if that will work.
  7. aballas
    aballas Karting
    Jul 29, 2017
    134
    Portland, OR
    It's the alternator that was in the car.... i rebuilt it myself. It's pn 155785.... it's the right alternator..
  8. aballas
    aballas Karting
    Jul 29, 2017
    134
    Portland, OR
    This is from the eurospares website. Referencing the part number. This is the part number that's on my alternator that you can see in the picture above.... It's the right alt.
  9. fatbillybob
    Aug 10, 2002
    28,978
    socal
    What if guy who mod the steering etc mod the alt?
  10. fatbillybob
    Aug 10, 2002
    28,978
    socal
    These cars change hands so often anything possible
  11. aballas
    aballas Karting
    Jul 29, 2017
    134
    Portland, OR
    Here's the thing though..... I even tried putting it back in with the mondial upper mount as well. (how it was in the car when i took it out) Same issue. doesn't line up.
    There's something that has changed with the alignment of how things mount, but i can't see how there is any way to adjust that.
  12. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Right but the front of the alternator could have been changed giving it slightly different mount location?
  13. aballas
    aballas Karting
    Jul 29, 2017
    134
    Portland, OR
    No.... I didn't make any changes to it, and it wouldn't even go in with the previous mounts with which it was installed.
    Something changed between me taking these things out of the car, rebuilding the alternator, and now trying to get it back in the car. This has nothing to do with any previous modifications done to the car or the alternator, because if that was the case I would be able to get it to fit again with the old parts (the only new part I had to source was the upper mount) yet here I am. It won't fit with any of the parts I have.
  14. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Ok so the same alternator was in with diff bracket and that bracket no longer works either got it.
    As I said, I took mine off on a motor rebuild and has similar issue, was very confused too, forget exactly what happend but it fit again after not fitting, don't recall if it took it all back off and redid it or what exactly.
    Sorry can help more but I experienced that. Mine is also a denso.
    Sent from my SM-G990U using FerrariChat.com mobile app
    aballas likes this.
  15. fatbillybob
    Aug 10, 2002
    28,978
    socal
    Sounds like op install error. Sometimes slop error adds up. Try loosening all brackets and in stall alt. Does it now fit with loose bracket? If yes the try mild gentle finger tight brackets work alt. On. That will slide bracket into position. Remove alt tighten bracket bit more. Alt install then remove and tight bracket and alt should fit.
    aballas likes this.
  16. m.stojanovic
    m.stojanovic F1 Rookie
    3,219
    Serbia - Niš
    Miroljub Stojanovic
    Bob's advice above will most probably solve your issue. The two holes on the upper bracket for mounting the bracket to the engine are rather close to each other so the clearance of these holes to their studs would allow quite a bit of movement (up and down) of the hole for the alternator. You probably pushed the upper bracket upwards while tightening the two studs. If you release the two nuts holding the bracket to the engine, you should be able to bring the end of the bracket (the hole for the alternator) quite a bit down and align it.
    aballas likes this.
  17. 32 Ford
    32 Ford Karting
    Jan 31, 2021
    175
    vancouver
    Mike McGowan
    is it Possible the front and rear casings were "clocked" wrong when is was re assembled.?Happened to my buddy. Bought 2 alternators thinking they were wrong. He just need to re clock the case to lign up the holes.
  18. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
  19. aballas
    aballas Karting
    Jul 29, 2017
    134
    Portland, OR
    This particular alternator there isnt a way to "clock" it... there's really only one way it goes together.
    That said....I did eventually get it.
    I had to loosen up the upper mount... it didnt seem like there was much play/slop in it, but it was apparently enough to keep things from going back together unless it was exactly right
  20. aballas
    aballas Karting
    Jul 29, 2017
    134
    Portland, OR
    This actually ended up working.. thank you
    steved033 and fatbillybob like this.
  21. fatbillybob
    Aug 10, 2002
    28,978
    socal
    glad it worked out. We have all been there…
    aballas likes this.
  22. KevZep
    KevZep Formula Junior
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    I can remember there was some fiddling to get mine on when I had the engine out, there isn't much room, it has to be lined up just right...
    Good you got it sorted!!
    aballas likes this.
