430 - Weird lock issue | FerrariChat
430 Weird lock issue
Discussion in '360/430' started by atguilmette, Jul 20, 2025 at 2:32 AM.
  1. atguilmette
    atguilmette Rookie
    Apr 22, 2025
    1
    Aaron Guilmette
    My 06 430 started experiencing a weird issue with the door locks. After attempting to unlock the car via fob, the doors re-lock. Inserting the key in the lock will cause the door to unlock, but then it will immediately lock again and I’m unable to open it.
    I was able to get in via the passenger door by unlocking the door with a key and timing the door handle. I then had to crawl over the console. I could not unlock the car from the inside.
    To get the doors to unlock successfully, I had to turn on the car (which started the alarm/siren), turn it off, turn it back on, and then drive both forwards and reverse before the interior unlock button would work.
    Any ideas?
  2. Qavion
    Qavion F1 World Champ
    14,268
    Ian Riddell
    Maybe just one of the door lock microswitches has jammed and is telling the doors to lock?
    Is it working now?
    If it happens again, try disconnecting the grey plug on the driver's side or just exercising the lock button.
    The exterior key lock microswitches might also be causing it, but they will be harder to get to.
    Have you had the doors worked on recently? Leatherwork?
    Of course, it could equally be the microswitches on the passenger side.
    colorfull and Mike Morrissey like this.
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,954
    Isle of man- uk
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,954
    Isle of man- uk
    When you try opening the door with the key, you need to pull the outside handle first and then turn the key
