Weird noise at cold startup | FerrariChat
Discussion in '360/430' started by ferralc, Apr 14, 2016.
  1. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    #1 ferralc, Apr 14, 2016
    Every time I start my car from dead cold I hear a weird rattling noise that eventually stops after the car idles back to normal, but I am wondering if this is something that I need to address because it only happens at the first start of the day and I cannot reproduce it after driving it to a shop unless I leave the car there overnight.
    It starts right away and increases and becomes really obvious at around the 30 second mark for about 15 seconds and then it goes away, any ideas?? Thanks guys!!!
    https://www.youtube.com/watch?v=LWujaAXbKks
  2. Red 27
    Red 27 Formula 3
    Feb 2, 2008
    1,002
    San Diego, Ca
    Dave
    I would have it checked out at the shop ASAP. Something is not right.
  3. MalcQV
    MalcQV F1 Rookie
    Oct 11, 2004
    3,292
    Manchester, UK
    Malc Holden
    My previous car an F355 had a similar sound. I mentioned it at the specialist but I was told it was something of nothing. Better to be safe though.
  4. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    I was going to say it sounded like intake noise from a leak in the intake after the mafs somewhere... But then it sounded to get faster and more rattle-y for some reason.
  5. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Only at overnight cold start? I would guess the smog air injection pump.
  6. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    Yes only after the overnight start and only when the car is revving higher, once the idle normalizes (after a minute or so) the rattling noise goes away (like at the end of the video) and it doesn't return until next day.
  7. mello
    mello F1 Veteran
    5,469
    CA Bay Area
    Steve
    Sounds like the hydraulic tappets (aka lifters) are charging up after a leak-down overnight. Did you use the proper oil? What brand?
  8. RedTaxi
    RedTaxi F1 Rookie
    3,310
    New Zealand
    Glen
    Isn't there a flap or linkage or something in the intake plenum that is known to rattle?
  9. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    Yes the pennzoil platinum euro 5w-40 recommended by Ferrari, I changed the oil almost a year ago and back in March the dealer did a complimentary inspection of all the car and the technician said it had a little too much and he removed a bit.
  10. kommons
    kommons Karting
    Sep 30, 2013
    215
    Silicon Valley, CA
    Chris
    That's not a healthy sound, it seems inconsistent as well. Is it possible to get a general location for the sound? It sound ominously like when my oil pump tensioner broke. Does it sound engine internal or upper plenum. Do you have a mechanic's stethoscope?
  11. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    I know it sounds pretty bad in the video but something as threatening can't just go away after 30 seconds and never come back until the car is dead cold again, that is why I don't believe is something that serious, I will leave the car for the annual service and have the shop keep it for a couple of days so they can reproduce it, at least is not a known serious issue (like the headers noise in 430s)
  12. vrsurgeon
    vrsurgeon F1 World Champ
    16,456
    Charleston, SC
    Curt
    A few causes I can think of. Can you localize it better? Under plenum? Air injection?
    If its the muffler bearing, just give it a squirt of elbow grease.. ;)
  13. hessank
    hessank Formula 3
    1,891
    Canada, Florida
    Fred
    #13 hessank, Apr 16, 2016
    How long between startups to produce your dead cold scenario?
    I would suggest splitting that time in half and see if it still happens(theory that the oil is draining and leaving the tappets dry. If it happens still when halved then split it another half.
    Also check the headers too as it is not uncommon on the 360s for them to crack where the secondary air tubes are welded to the primaries
  14. mello
    mello F1 Veteran
    5,469
    CA Bay Area
    Steve
    I had some sticky tappets on my C5 Corvette back when. I just threw in a can of engine flush and drove it a few hundred miles before an oil change. Miraculously, the sound disappeared. You might want to give it a try.
  15. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    I will buy everyone a round of drinks if I can fix this with an engine flush, I might give it a try before spending hours of labor chasing a ghost sound
  16. Fatty
    Fatty Karting
    Jun 5, 2010
    235
    Australia
    Sounds like the butterfly valve in the compensation duct. One or both screws could be getting loose. Get it checked out asap. Remove the left AFM, and stick in an extended mirror with a torch to have a look, if you are able to.
  17. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    A very good mechanic I know heard the noise and he said it is very typical for 360s to do that noise eventually, he said the fuel pressure pump has a valve that stops the fuel flow and it has a small leak and overnight it loses all the pressure, it sounds weird until the pump recovers all the pressure to supply fuel to all the cylinders.
    I am traveling right now so I don't have a chance to get it checked, I will ask the shop to take a look at my return when I do the annual service
  18. Trouts10
    Trouts10 Karting
    Dec 2, 2015
    164
    Chino Valley, AZ
    Richard Heilman
    I also have a similar sound at cold start up. It's noticeable for about 20-30 seconds, then disappears. The car had a full dealership inspection and service just before purchase, so I would like to think it was something they would address and correct if it was a problem or potential problem.
    It will be interesting to hear what your shop has to say about the noise. My Modena isn't due for fluid/oil service until November, so that's when I plan to have them check on the noise; unless, of course, it doesn't become a bigger issue before then.
    Hope we can get an update from you soon.
  19. BladeMD
    BladeMD Formula 3
    1,140
    Sarasota, FL
    Hannibal
    I've read that a "ticking" sound could be a sign of the precats in the headers throwing shards, but I've never heard it personally.
    Id be interested in hearing how it differs from this, because it's exactly how I imagined it sounding.
  20. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    I will and post results
  21. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    That's what I thought but as I said before it is really weird it ceases the sound completely as soon as the idle returns to normal, I would guess the headers will keep making noise here and there.
  22. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    Can you please take a video and post it here so we can compare them??
  23. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    #23 ferralc, May 14, 2016
    I will bring my car to the annual service next week and to address this noise, so far I have two diagnosis of two different mechanics who watched the video, one says it could be the fuel pump that loses pressure overnight.
    The other one (which I believe is the most accurate one for the type of metal cracking/rattling noise) is "the secondary air system and thermal expansion of the headers" because once they are warmed up the noise goes away cleanly and it doesn't track with engine revs.
    I will know for sure next week, my question for you guys is if the headers are making noises when they are warning up does this mean they are about to fail or they just need to be adjusted??
    If this is the case I really want to change the headers to an aftermarket option but I have heard the smog shops in California are failing the visual test in every single car with aftermarket (shiny) parts inside the engine bay.
  24. RWP137
    RWP137 Formula 3
    Apr 29, 2013
    1,594
    AZ
    Rick
    Grab a hose or tube and from your ear try and isolate the sound. I'd guess it's pieces of catalytic converter rattling around before things heat up. 355's-430's have cat issues.
  25. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    I used a stethoscope and I believe the noise comes from the left header ( my window of opportunity was pretty small)
    My guess is the catalytic converter "stone" inside the header is rattling
    I found this thread in *********** and it makes sense to me
    http://www.***********.com/#/forumsite/21041/topics/34442?page=1
    But why the sound would be completely gone after less than a minute? Do these "stones" expand with heat and stop rattling??
    If the header is the culprit does this merit a header change, is this the catastrophic header failure everyone talks about?
