Welding Equip Recommendation | FerrariChat
Discussion in 'Other Off Topic Forum' started by PhilB, Sep 13, 2007.
  1. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,353
    Southern New Jersey Shore
    Phil
    This would be for general household use - have an immediate need to weld some chain link fence parts (galvanized piping 1 5/8" through 2 1/1"). Will also use to fabricate basement window guards, and then some shelving. Maybe at some point will use for the car or Jeep (for brackets and stuff but probably never for body work).
    Never welded before but this shouldn't be an issue as I'm a very skilled carpenter, tile setter, electrician, plumber, etc.
    Nothing I need to use it for will be for "finish" work, all rough stuff, more for strength than looks.
    110v preferred if possible but 220v won't be much of an issue.
    Mig, Tig, etc. - not sure what it all means.
    Lincoln? Other brands?
    Thanks for you advice,
    Phil
  2. LightGuy
    LightGuy Four Time F1 World Champ
    46,149
    Texas
    David
    Tig is the best. Can do it all. Aluminum to titanium. A used one worth anything starts at 1k.
    Arc's days are close to an end with cheap Migs available.
    I am not a big Mig fan but bang for the buck is the way to go.
    There are resellers of used equipment that can offer like new machines for half price. They can also direct you do which one works best for your needs.
    Buy a GOOD one , use it forever, and get your money back when you sell.
    110v is next to worthless.
  3. SRT Mike
    SRT Mike Two Time F1 World Champ
    Oct 31, 2003
    23,343
    Taxachusetts
    Raymond Luxury Yacht
    I have a different viewpoint than this gent, FWIW.
    Tig is great - FOR FINISH WORK or for aluminum, neither of which this guy says he wants to do. The cons of Tig are its expensive for equipment, gas, materials, its slow, its very difficult to get good results, and is all around a higher-end system than Mig or arc. And good luck welding upside down with Tig. Wear leather pants and don't weld above the family jewels :)
    110V is not worthless at all, 220V is better because you draw less amps for the same wattage, but on a solid 20-amp circuit, a 110V Mig can perform admirably.
    Philip, when I read what you wrote, one word popped into my head immediately "MIG". For what you want to do, Mig is cheaper, faster, will produce better results, and is much easier for a new welder to learn. Mig is the workhorse of welding. I would look at Lincoln and Miller, they both make good machines. For under $500 you can get a pretty sweet Mig setup. Also the gas is less hard to deal with (in terms of finding suppliers willing to refill your bottles without a service contract) as compared to Tig.
    The only time I would ever suggest Tig over Mig is if you are doing finish work where looks are extremely important and the weld cannot be finished (ground and painted over later), or if you are working on very thin materials, or exotic materials like magnesium, titanium or even aluminum. Tig is great for all that, but far inferior to Mig as a general workhorse for around-the-shop-around-the-farm welding tasks.
  4. URY914
    URY914 Formula Junior
    Feb 17, 2004
    608
    Temple Terrace FL
    Paul
    For general purpose welding you can't beat a MIG. I bought mine and within minutes I was welding. Miller and Lincon have website that tell you everything. TIG you'll need to take a class IMHO.
  5. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,353
    Phil
    Thanks to all of you for your feedback. I appreciate your points of view.
    Considering the work I'm doing is rough, and not on very exotic material (chain link fence posts), sounds like MIG is the way to go.
    I'll check out Miller and Lincoln, and report back here what I decide. An obvious alternative is to hire the work out and not make any decision on the equipment myself. But I own all my tools, buy good tools, and keep them for years and years, as there is always something that comes up that needs to be dealt with that is too small or too costly to hire out.
    Thanks,
    Phil
  6. Scotty
    Scotty F1 World Champ
    10,548
    Oregon
    Scotty Ferrari
    I have two questions. Background is that I now live rural, and could use the ability to weld from time to time. I have almost zero skills (I've brazed, I'm skilled at silver soldering jewelry, and I have used a Mig welder twice). The clear answer is to get someone who knows welding well to do the work, but that isn't easy to source.
    1) There are now combination machines that do stick, unshielded MIG (flux core wire), MIG, and in some cases add TIG. The machines aren't all the cost--there is the PPE (helmets, respirator, jacket, gloves). As said above TIG is a harder to learn skill, so I think I'd be fine with a machine that didn't do that. Is anyone currently using a combo machine that they like?
    2) Cheaper laser welders are becoming a thing. They have material thickness limitations, and have their own safety considerations (as well as some in common with MIG), but they are apparently easier for a beginner to use. Anyone using one?
  7. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,813
    Lake Villa IL
    What is it you're trying to do or think you will need to do? If it's just random steel I would vote for mig but if you're so rural that shielding gas is a pain to get then just get a basic/old stick welder.
    Scotty likes this.
  8. Scotty
    10,548
    Oregon
    Scotty Ferrari
    Simple stuff. Tack welding nuts to bolts, fabricating brackets that will not carry a significant load, welding reinforcing plates to square tube steel, etc.
