News
430 Well, I Spoke Too Soon (CEL After Header Install)
Discussion in '360/430' started by BlacktopRacing, Feb 10, 2019 at 7:47 PM.
  1. BlacktopRacing
    BlacktopRacing Formula Junior
    585
    Dale
    So in at least my DIY thread and in a reply to somebody else's thread, I mentioned not getting a CEL after installing my ceramic coated AP headers. That was based on three separate occasions when I've pulledthe car out of the garage, let it warm up to normal operating temps, revving it a few times, then pulling it back it the garage. All in all, each occasion lasted around 15-20 minutes. Never a CEL. I went to do the same today, and got a CEL. My theory is that at least one O2 sensor is failing due to the ceramic coating on the inside of the exhaust. I still have all the panels off, so I plan to check and make sure all the manifold nuts and sensors are still tight. I don't have a scan tool, but I'm open to recommendations. I was thinking of this one: https://www.oreillyauto.com/detail/b/bosch-3089/tools---equipment-16488/diagnostic-16546/code-readers-scanners-17943/5609f7011617/bosch-scan-tool/obd1300/2578941
  2. 24000rpm
    24000rpm Formula 3
    Aug 31, 2012
    2,323
    Asia and the U.S.
    ok, so without an error code such as p0xxx , it is shooting in the dark. Why o2 sensor would fail because of heat insulation? the stock header insulation is even better than ceramic coating! It is just that the oem style insulation is way too expensive to produce in the afttermarket hence the ceramic, which is an half-ass solution, in my humble opinion.
    f355spider and Rifledriver like this.
  3. Skidkid
    Skidkid F1 Veteran
    Rossa Subscribed Owner
    Aug 25, 2005
    5,168
    Campbell, CA
    John Zornes
    I am with 24000. It has nothing to do with the coating. It has everything to do with the sensitivity of the O2 sensors and is the problem that EVERYONE who replaces the stock headers faces. Why would yours magically not have that issue and it be attributable to something that shouldn't have any impact? When you hear hoof beats you don't think zebras.
    f355spider likes this.
  4. mike32
    mike32 Formula 3
    May 13, 2016
    1,638
    Uk
    While it is warming up, dont rev it- this sends unburnt fuel up the pipe and deposits it on the cool sensor. Just let it tick over to get some heat in the sensor
  5. cpep
    cpep Formula Junior
    276
    new york
    CHARLIE
  6. parkem
    parkem Karting
    93
    florida
    peter palermo
  7. BlacktopRacing
    585
    Dale
    That's a good point. I never rev a car while it's still warming up, but I might have done so a little early that time. I thought I dodged the bullet like others with AP headers have reported (not getting CEL). That's part of the reason I suspect it has to do with the coating. We just got 4" of snow, so it may be a while before I get another chance to pull it out to see if it goes away on it own.
  8. FerrariFab
    FerrariFab Karting
    139
    Inland Empire
    CFI Designs
    Retune the care and blank sensor signal so its never an issue.
  9. mwstewart
    mwstewart Formula 3
    1,337
    England
    Mark
    360Trev is offering a reflash tool to desensitise the rear cat o2 sensors.
    I have a custom tune on my car which included it - it is my preferred option.
  10. JoeTSI
    JoeTSI Formula Junior
    631
    Huntsville, AL
    Joe K.
  11. Rifledriver
    Rifledriver Two Time F1 World Champ
    24,557
    Austin TX
    Its not going away on its own.
  12. hessank
    hessank Formula Junior
    983
    Canada
    Fred
    If you live in a State that requires emission testing then it is prudent to purchase a scan tool that has the "Monitor Ready" or Drive Cycle Complete " status built in. That way you know when not to go to the test facility
    My $0.02
  13. BlacktopRacing
    585
    Dale
    I do (Pennsylvania), but my car is exempt die to putting less than 5k miles on it between inspections. I'll be exploring those bungs mentioned above. Yay, another $300+ between a scanner and hardware.
  14. BlacktopRacing
    585
    Dale
    I ordered an Actron CP9680 scan tool and was wondering if it will go so far as to indicate which O2 sensor(s) might be causing the CEL, assuming that's what it is. Was also wondering if it's safe to assume it would be one, or both, of the O2 sensors that were mounted on the OEM manifolds, now on the back part of the headers??
  15. cpep
    cpep Formula Junior
    276
    new york
    CHARLIE
    The code will indicate left bank or right bank pre or post.
    BlacktopRacing likes this.
  16. BlacktopRacing
    585
    Dale
    So, I received my OBDII scanner today and the code it found was P0600, which reads as follows:
    Motronic ME 7.1.1 - RH
    P0600
    RH-B AND LH-B CAN LINE ERROR
    CAN line communication error between the RH ECU and the LH ECU
    Communication Error
    Wiring and system intactness check.
    I don't know what to make of this. I was extremely cautious with disconnecting the four sensors and reconnecting them. I even wrapped everything in cotton and plastic. Another thread elsewhere mentioned something about not getting a reading on the tach, but my tach works. As far as I know, there are no noticeable traits to consider, such as rough idle, hard starting, etc. Everything appears as normal, but then again, I haven't driven it off my driveway yet. I was able to clear it without it coming back (at least not yet).
  17. Testarossa Lover
    Testarossa Lover F1 Rookie
    Silver Subscribed Owner
    Dec 31, 2006
    3,361
    Newport Beach, CA
    Haig Barsamian
    Mine had fabspeed headers, it left me with codes. I had the 02 sensor extenders installed, codes still remained. I went back to stock headers, problem solved. I installed fabspeed muffler and tips months later, check engine came back. revert back to stock and problem solved. The only modification I am able to do without codes is to keep everything stock except the tips which I have are Fabspeed.
  18. BlacktopRacing
    585
    Dale
    "EVERYONE"? Others have reported not getting a CEL after installing headers. In my case, it turned out the CEL had nothing to do with emissions or exhaust, so my AP headers are still CEL-free :) Maybe I'll still get a header-related CEL down the road, but keeping my fingers crossed.
    The P0600 points to communication between the left and right bank ECUs, and I have a suspicion I know why. After a successful header install, I thought I'd take on something easy, like installing a custom drink holder assembly on the rear parcel shelf between the seats. The assembly was secured by two fine thread screws, which I'm guessing nicked a wire below the shelf. I'll have to take out the panels and check things over. I wish I never got thirsty while driving :(
  19. BlacktopRacing
    585
    Dale
    Well, my above theory was disproven. Not only did the two screws I put through the rear parcel shelf clear all the wires underneath with ample room, everything is still like new. So the search for the cause of the coincidental P0600 code continues.
