What am I doing wrong (buffing swirls) | FerrariChat
Discussion in 'Detailing & Showroom' started by Meister, May 3, 2020.
  1. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    So I'm not new to detailing cars but most of my cars are single stage or old school laquer. I painted and installed a bumper on this Z06 so I'm buffing in out and the front fenders. Wet sand up to 2K grit then wool pad meguiars fine cut, then show car glaze (pure polish) and I have all these swirl marks. They mostly disappear with a top coat of wax, but I'm thinking they shouldn't be this bad in the first place. I used a small 4" wool pad because I had it on my machine to do the smaller areas of the front bumper, maybe the 6" would be better for the larger surfaces. Any thoughts? This is why I dislike cars with clear coats ;)
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,931
    Central NJ
    Dominick
    I am not an expert ..but it sounds like you missed a step
    Try a orange or white foam pad and a light cut m205 meguairs ..on an random orbit machine
    Sent from my moto g(7) using Tapatalk
    LI2782, APA#1 and MobileJay like this.
  3. MobileJay
    MobileJay Formula 3
    1,442
    Houston
    Jason Cavallo
    You went from an aggressive pad and light compound (I think, not sure where fine cut is on the scale) and then went straight to a glaze. Glazes are full of fillers that hide the buffer trails as you have experienced. As mentioned above, grab some 205 a mild polishing pad and refine the paint.
    What machine are you using?
  4. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    A variable speed makita 7" but at the time using a smaller 4" pad because I had it on and full of compound. The swirls are worse on the factory finished fenders. The bumper I base/cleared a month ago is not nearly as bad.
    MobileJay likes this.
  5. MobileJay
    MobileJay Formula 3
    1,442
    Houston
    Jason Cavallo
    Using a rotary is exceptionally difficult to finish down correctly and not leave holograms. Use a dual action orbital machine and a proper polish like 205 and a medium foam pad and you should be fine.
    flash32 likes this.
  6. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    I do have a smaller DA porter cable somewhere, just have to find it. Thanks
  7. MobileJay
    MobileJay Formula 3
    1,442
    Houston
    Jason Cavallo
    Yeah the Porter cable should be able to get it done.
    Sure thing.
    steved033 likes this.
  8. JL350
    JL350 Karting
    Jan 20, 2013
    215
    Yup, I use a DA on clear coat with 2000 and 4000(?) 3M compound with the right pads, takes some time but minimises the risk of swirls that you are getting. The depth of shine is an added bonus.
  9. Kipper
    Kipper Karting
    May 1, 2010
    103
    Australia
    Kipper
    After painting allow the paint to cure for 3 weeks in good weather finish with 3000 wet paper and use a Rupes orbital polisher or similar
    use 4000 cutting compound then 2500 and go lower if you wish 2500 will give you an excellent finish.
    Rotary buffers/polishers are rubbish
    Kipper
  10. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    Did mine, compound, polish, wax using a porter cable. Came out flawless. Almost don't need a buffer anymore. Picture is of my maser in the old garage.
    Roadney likes this.
  11. bocaf430
    bocaf430 Formula 3
    Jun 10, 2014
    1,361
    LI, boca raton
    be sure your pad is not dry, use enough product.
