What are slow down lights? | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by 88MONDIAL, Jul 15, 2005.
  1. 88MONDIAL
    88MONDIAL Formula 3
    Apr 13, 2005
    1,052
    Racine, Wisconsin
    Jim Smith
    Could someone tell me what exactly "slow down lights" are? What are you supposed to do if it comes on? Is there one light on the dash, or I've heard something that leads me to believe there are two lights, one for each bank of cylinders?
    Thanks in advance!
  2. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    one for each bank.
    They detect above average temps in the exhaust.
  3. Joe G.
    Joe G. Formula 3
    1,109
    Los Angeles
    Joe Gazzani
    ferrari's have built in radar
    (j/k)
    your car will only have one slow down light because you only have one cat
    everything else Matt said is correct with regards to temps
  4. Mondial2
    Mondial2 Karting
    Jan 23, 2004
    60
    Mondial T's only have one cat? Is that true for 348's also?
    I know my '83 Mondial has two cats, and two slow down lights, one for each bank.
  5. matteo
    Aug 1, 2002
    13,748
    Heir Butt
    up to 83...two cats
    84 to 88.5...one cat
    89 up....two cats.
  6. 88MONDIAL
    88MONDIAL Formula 3
    Apr 13, 2005
    1,052
    Racine, Wisconsin
    Jim Smith
    Thank you for your replys. So they are nothing to worry about, you just "slow down" to let your exhaust temps decrease then? So they could go on when you really are pushing the car? Once it cools down the lights go off? I assume this is there so you increase the longevity of your cats then.
  7. Joe G.
    Joe G. Formula 3
    1,109
    Los Angeles
    Joe Gazzani
    exactly !
    Mondial2
    i thought (or took it as implied) that he has an '88 3.2 mondial not a T
    thus
    he has one cat
  8. f355spider
    f355spider F1 World Champ
    18,047
    No. If the lights come on, you have one of two possible problems, the cat is actually overheating (stop immediately to prevent damage or fire), or the protection circuit is defective, and giving a false signal. Regardless, the fault must be corrected.
    The typical cause of an actual overtemp situation is from losing the ignition on one bank of cylinders, causing the unburnt fuel to dump into the exhaust manifold, and ignite in the catalytic converter...causing the high temps. Very dangerous.
