What are the differences between left and right fuel pumps? | FerrariChat
Discussion in '360/430' started by RedNeck, Sep 24, 2018.
  1. RedNeck
    RedNeck F1 World Champ
    12,310
    The CSA
    Me
    Is it just the float? Could the 1 pump be modified to use for both banks?
  2. MD355
    MD355 Formula Junior
    Mar 8, 2004
    802
    Athens, Greece
    MD
    Yes, the LH has the float. I don't know about other differences.
    Since we are this topic, the new design apparently has a flaw with the fuel indication.
    I fill up my car, it goes to 100% the bars.
    I drive approximately 300 km and the fuel gauge gets stuck at 3 bars. It will never go below that.
    Once, I ran out of fuel because of that. I am used to filling up once the bars start flashing.
    I asked my mechanic to double check if he kinked the indicator while installing, but he said that there was nothing blocking the float.
    So, it is software related ?? Any calibration required ?
    (for the record, the one time I ran out of fuel, the fuel tank took in exactly 85 liters. Last night I filled up after doing 300 km and it took in 73 liters. I think at 20 liters before empty it should show 2 bars and anything below 75 liters it should show zero bars and blinking. That does not happen anymore in my car)
  3. RedNeck
    12,310
    The CSA
    Me
    Would be interested in knowing if anyone else has this issue after replacing pumps.
  4. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    My 430 has the new updated pumps. I struggle to fill the last bar. I run it down to around 2 bars before filling. Even got down to 1 bar once without issue.
  5. mello
    mello F1 Veteran
    5,489
    CA Bay Area
    Steve
    I've replaced the pumps with the new design one. No problem.
  6. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    918
    TX
    anyone know what the new updates were? I know the new one has a different colored top, beige instead of white but what else was updated? Was it just stronger plastic?
  7. 02360spider
    02360spider Formula 3
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    I changed my pump no problems i had a hard time getting the arm in the track but good to go
    Sent from my SM-G950U using Tapatalk
  8. RedNeck
    12,310
    The CSA
    Me
    Anyone know the answer to the original question? :)
  9. mello
    mello F1 Veteran
    5,489
    CA Bay Area
    Steve
    The differences are the new plastic material used on top of the pump and a newly designed float; from round to flat, which suppose to give a more accurate reading of the gas level on the gauge. When installing, make sure that the pump is seated within a round indentation at the bottom of the tank, and that the float is behind the baffle. You have to maneuver the pump so that the arm of the float is not bent while inserting the pump into the tank. See 3rd picture.
  10. mello
    mello F1 Veteran
    5,489
    CA Bay Area
    Steve
    Yes, it is stronger plastic to prevent cracking (and possibly resistant to ethanol) on the regulator/nipple to the hose coupler.
  11. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    I installed the new style fuel pump RH and LH now its all over place reading full empty in the middle, only started wend I filled it completely up. Now that I have ran almost a half tank now it seems to be okay ? I was having a hard time filling up with fuel it keeps tripping the gas pump off, so I remove the fuel roll over valve and blew through it seem to me it was sticking so I buy passed it will see wend I go to refill with fuel if it works
  12. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    I deleted evap system and using the Challenge vent system it vents threw the rear bumper you can see it on the right side upper corner
  13. 24000rpm
    24000rpm F1 Rookie
    if you can try my method:
    install it again and this time , lean your whole body to the engine.
    i am 90% sure it is an installation issue.
  14. G. Pepper
    G. Pepper Three Time F1 World Champ
    38,391
    Texas/Colorado
    George Pepper
    My car came with mismatched fuel pumps, so I replaced them both and kept the extra new version as a spare. No problems.
    My car has always been picky when fueling, but I've figured out how to keep the shutoff from triggering early by backing it out and not trying to fuel at full speed.
    I fill up at half a tank, and everything is accurate from there to full.
    RANDY6005 likes this.
  15. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Hey 24000rpm I thought the same thing like you said the install was off, It was a pain in the ASS !!! On the coupe is harder than the spider, all those 6mm bolts trying not to drop in the the tank and lining up the float in the tank and smelling gas I had too stick my hand in the tank to make sure the float was good
    02360spider likes this.
  16. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    I hope removing that roll over valve helps at the pumps filling up will see and I will post results
  17. timwu12
    Oct 31, 2014
    918
    TX
    so the oval flange does need to come off to replace both pumps, right?
    I thought some people were just replacing it through the circular pump hole itself.
  18. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    I had to remove the flange on mine it was a coupe. spider might be different
  19. mello
    mello F1 Veteran
    5,489
    CA Bay Area
    Steve
    Just a few words of caution when R/R the pumps. Make sure that the fuel line coupler is installed correctly on the pump outlet nipple. When you hear a click, yank on the coupler a few times to make sure. You don't want a Car-B-Que while driving.
  20. Rhoads56
    Rhoads56 Karting
    191
    Perth, Australia
    Perry
    I recently replaced my right hand pump with a left hand version. I simply removed the bits that are different between the two: float etc.
    Bosch makes them oem and you’ll find they are 1/3-1/4 the cost of the same part in the Ferrari box.
  21. timwu12
    Oct 31, 2014
    918
    TX
    got a part number?
    G. Pepper likes this.
  22. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
  23. Rhoads56
    Rhoads56 Karting
    191
    Perth, Australia
    Perry
    0 580 313 052
    I paid $212 Aussie dollars. $780 via the dealer.
    timwu12 likes this.
  24. RedNeck
    12,310
    The CSA
    Me
    Thank you! This is the info I was looking for. I have one on order, I think I paid about US$240, 50 of that was shipping from the UK.
  25. timwu12
    Oct 31, 2014
    918
    TX
    Is this Bosch cross referenced number also with the beige top or the original white top?
