What are these wires for? | FerrariChat
Discussion in 'Mondial' started by westyguy, Jun 22, 2012.
  1. westyguy
    westyguy Formula Junior
    Apr 27, 2009
    252
    Huntsville, TX
    Steve
    Last weekend I pulled the console apart and removed the top part where the switches are. Under there were about 4 fairly heavy green wires with what appeared to be factory staked-on connectors. They were neatly coiled up and appear to be factory. Any idea what these are for? It's an '84 Cabriolet.
    Thanks,
    Steve
  2. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    Most likely window motors:
    White/black is the hot (12V) supply
    Blacks are ground
    Greens deliver power to the motors
  3. westyguy
    Apr 27, 2009
    252
    Huntsville, TX
    Steve
    These were disconnected, though, and all my windows work (though the rears work with typical Ferrari window speed.)
    Steve
  4. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    So does everything on your center console work? Maybe for the radio antenna since its not connected to the aerial switch? Or to rear speakers if you have them. Can you trace it to the other end?
    I was in there a few months ago and do remember some green wiring!@#$#^$*, all over the place, LoL.
  5. Russ Gould
    Russ Gould Formula 3
    Nov 8, 2004
    1,073
    If anyone knows where the ground is for the instruments, let me know how to get to it as mine is intermittent.
