What brand/spec fluid should be used in the F1 system? | Page 3 | FerrariChat
Discussion in '360/430' started by 430b, Oct 25, 2015.
  1. Jaymac
    Jaymac Formula 3
    1,023
    New Hampshire
    Jeremy McCurdy
    Regarding the F1 fluid specifically, if I’m just doing the siphon/top-off method, is it ok to mix the Ravenol GHA-F with the Shell ATF that was put in there last year?
  2. Jaymac
    Jaymac Formula 3
    1,023
    New Hampshire
    Jeremy McCurdy
    Seems the ravenol is NLA from most vendors. Makes me wonder if there’s a reason why.
    Since the forum won’t let me edit my post for some reason, let me replace the Ravenol with the Petronas CS Speed 75W; compatible with the Shell ATF that’s in there from last year?
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,213
    Central NJ
    Dominick
    Shell ATF is nothing more than DEXIII atf - use mobil 1 atf
    RobinMasters likes this.
  4. Jaymac
    Jaymac Formula 3
    1,023
    New Hampshire
    Jeremy McCurdy
    Flash, I’ve read this (and other threads) several times over the last few months. In your research, does the Petronas CS Speed offer any advantages over the M1 ATF, or vice versa?
  5. tstuli
    tstuli Formula Junior
    Jun 12, 2018
    380
    NC
    It may be overkill, but I found this place www.lubefinder.com that repackages a lot of the Shell products in reasonable/consumer friendly quantities. It may be $20/L but the amount that I'll actually use/peace of mind against risks of mixing random stuff it was worth it for me.
    NORTY likes this.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,213
    Central NJ
    Dominick
    The CS has less additive which are not needed here and it has a better flow rate at lower temps
    Not doing any scientific analysis i would be able to say does it make a difference.. maybe if it is extremely cold when you use the car ..
    If you are going to mix it ..doesn't make sense
    If you were to drain the system and refill with something I probably would consider the moly product that have been used by many since CS is hard to get
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,213
    Central NJ
    Dominick
    #57 flash32, Jan 18, 2022
    This i have done research on and Mobil 1 ATF is equal to and better to the shell ATF they used .. But of course some of those things don't make a difference in this purely hydraulic system
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,213
    Central NJ
    Dominick
    If you have a early 360 you can use the Castrol dex/merc .. older compatibile with older seals used
  9. tazandjan
    39,412
    AandSC likes this.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,213
    Central NJ
    Dominick
    Terry
    Although I am sure it is a great fluid but at 55 dollars a quart not sure what if the benefits (if any) make sense
    The only thing is that is "thinner" at some temps which not sure what it means in real world driving
  11. Jaymac
    Jaymac Formula 3
    1,023
    New Hampshire
    Jeremy McCurdy
    So that was my question. I have the Petronas in my Amazon cart, but I was wondering since I’m only planning on doing the siphon/top off method for now, would there be a drawback to mixing that with the Shell ATF that’s in there from last year.
  12. Skippr1999
    Skippr1999 F1 Rookie
    4,585
    I’ve been using the Redline D4 for the past decade with no issues. If I remember correctly rifeldriver may have suggested it.
    Flea7 likes this.
  13. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,213
    Central NJ
    Dominick
    I wouldn't mix it ..you are overthinking it ..go for the Castrol or Mobil 1 ATF sync ..no benefit from.mixing ..in fact may hurt
  14. Jaymac
    Jaymac Formula 3
    1,023
    New Hampshire
    Jeremy McCurdy
    Meaning that the M1 ATF is able to mix sadly with the Shell ATF in there? Or are you suggesting a full flush and start fresh with one of those?
    And yes, unfortunately, I overthink everything.
  15. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,213
    Central NJ
    Dominick
    I meant that I wouldn't mix Petronas ..the other two Mobil 1 or Castrol will mix no prob
    Jaymac likes this.
  16. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,147
    Josh @jtcarprojects
    Is D4 still the go too. Interesting why scud is recommending the liquid molly hydraulic oil.
  17. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,213
    Central NJ
    Dominick
    Unless you planning to completing flush it and red stuff is in it just go with Mobil 1 ATF Dex III not VI
    I heard others using D4 but I haven't used it or recommended to anyone ..not saying anything good or bad but never did enough research on it
  18. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,147
    Josh @jtcarprojects
    That's what I was thinking. Stick with the atf
    flash32 likes this.
  19. DanNE
    DanNE Formula Junior
    Jun 7, 2013
    788
    Did we ever figure out what happened to the Ravenol? I still have some on the shelf, not sure if I should use it at the next change or not...
  20. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,213
    Central NJ
    Dominick
    DanNE likes this.
  21. Jaymac
    Jaymac Formula 3
    1,023
    New Hampshire
    Jeremy McCurdy
    What Dominick said. I use it exclusively now and get it from Blauparts.
  22. NORTY
    NORTY Formula Junior
    Aug 15, 2008
    571
    CARLSBAD, CA, USA,
    NORTY
    I wouldn't mix fluids, unless it was emergency. Even then, I'd flush and replace with the proper fluid at earliest chance. As temperamental as gearbox's have become, it's just not worth the risk. But then, what do I know...
  23. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,213
    Central NJ
    Dominick
    If the fluid in there is red the F1 reservoir then you're not really mixing anything and mixing ATF fluid with ATF fluid and in the gear oil you're going to be changing it anyway
    So I'm not sure I follow
  24. DanNE
    Jun 7, 2013
    788
    There was the old ravenol gh-f which I bought years ago and stored on a shelf...it was supposedly for the F1 replacement but I don't see it being made (or sold?) anymore...
  25. NORTY
    Aug 15, 2008
    571
    CARLSBAD, CA, USA,
    NORTY
    Just because 2 fluids are red, that doesn't mean they're going to offer optimum performance when mixed. Will they work? Likely. Will they offer optimum performance? Maybe, maybe not.
    Hope this clarifies. (Retired tribologist, here.)
