What causes a 1st Gear Lock on out a 456M GTA? [Solved] | FerrariChat
Discussion in '456/550/575' started by paulchua, May 7, 2020.
  1. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,465
    Menlo Park, CA
    Paul Chua
    Been enjoying the 456M GTA, but I just realized the gear selector locked out of the #1.
    I've always just left it and "D," and it works great. I never had to use 'manual' 1st gear, but in a whim, I thought I would try it, and it won't 'shift' down to the 1. It seems to be locked.
    What causes this, and how do you 'unlock' it? I couldn't find anything in the manual or searching these boards.
    Thanks in advance.
  2. tazandjan
    39,166
    Paul- You, of course, know that you have to push down the button on the selection lever to go from D to 1, 2, or 3, but not from 1 to 2, 3, or D.
    paulchua likes this.
  3. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,465
    Menlo Park, CA
    Paul Chua
    Yup, 3, 2 work fine; Just 1 seems locked out.
    And first gear works great of course while in 'D'.
    Cheers
  4. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,465
    Menlo Park, CA
    Paul Chua
    Just a friendly bump, I think I'll pop it open if I don't hear anything from folks here - since 1st gear works fine otherwise, hopefully just a minor issue. I'll make sure to report what I find.
    Cheers
  5. Qavion
    Qavion F1 World Champ
    14,279
    Ian Riddell
    Who makes the gearbox? Is there a generic manual on these type gearboxes?
    Pure speculation:
    Since the gear selection is operated by cable (with some electronic intervention), there may simply be some mechanical adjustments to do. Gear (1) is right at the end of the gate, so may be more susceptible to minor cable length variations. I also wonder if it's a cable lubrication problem? Has anyone lubricated these cables before?
    The manual mentions electronic inhibits on switching from "D" to 3 and from 3 to 2 at higher speeds, but, oddly, there is no mention of inhibits from 2 to 1, so perhaps this also points to a purely mechanical adjustment or failure? I've seen faulty engine mounts on some F cars causing problem with gear changes, but I don't think a cable shifting system would be affected by this kind of problem.
  6. pkl03
    pkl03 Formula Junior
    538
    Sydney, Australia
    Peter
    You mention that it won’t shift down to first, does 1st gear work from stationary.
    Might be a normal function that you can’t shift down to 1st while moving.
  7. tazandjan
    39,166
    Another 456 owner had a jammed switch on his gearshift lever.
    Auraraptor and paulchua like this.
  8. Qavion
    14,279
    Ian Riddell
    I believe the switch is only required from D to 3, Taz. Apparently, that part is working.
    D- X - 3 - 2 - 1
  9. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,465
    Menlo Park, CA
    Paul Chua
    Thank you so much for taking the time to respond. I'm going to open it up and see what is causing it. The transmission works flawlessly as far as everything else.
    Thanks for taking the time to respond. Yes, it does not slot in even from stationary. To be clear, 1st gear works absolutely fine functionally, just that the manual selection part is locked out for some reason.
    I will report my results when I get to it! I think it is something relatively minor and easy to fix since everything else works beautifully.
  10. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,465
    Menlo Park, CA
    Paul Chua
    Okay, popped open the gear lever housing and couldn't make any sense of what would cause the lockout. Feeling defeated, I sadly put everything back together and fired the car up. Now I can't even get the car out of park.
    I was like, I just royally screwed myself.
    I then just rechecked everything and twisted the gear knob tight - that fixed everything. Can quickly shift into 1st now.
    So if you ever have any gear/lock hesitation, make sure your knob is firmly twisted and set into the rod.
    I hope this helps.
    Cost - $0.00
    Cheers
    Il Tifoso, Mirek, tomc and 1 other person like this.
  11. Qavion
    14,279
    Ian Riddell
    No bottle of champagne, Paul? :D
    Glad to hear it was a simple fix. Definitely one for the archives.
  12. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,465
    Menlo Park, CA
    Paul Chua
    Thanks so much Ian! Yes - what happens is if the knob is not fully twisted into the gear shift rod, when the button is depressed, it won't actually press the disengage mechanism. Hence, it's something all GTA owners should check, specifically that the knob is fully twisted into the rod so all gears are easily utitlized.
    Hope this helps the community.
    Cheers Ian.
  13. tazandjan
    39,166
    Paul- If you had not taken it apart....
    Learn something new every day and this time the price was right.
  14. Mirek
    Mirek Formula 3
    1,493
    Los Angeles, CA
    Mirek
    Holy mackerel ! Congrats
    456M GTA and paulchua like this.
