what coolant fans come on testarossa | FerrariChat
Discussion in 'Boxers/TR/M' started by jamesrobba, May 3, 2010.
  1. jamesrobba
    jamesrobba Karting
    Dec 5, 2005
    211
    north downey, calif.
    james joseph robba
    hello , i just did my coolant system and all the bleeding question please at 195 the l/h fans come on , what about the r/h fans i see they are not on when do they come please . thank you all jim
  2. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,826
    The two small fans (one on top of the other) on the RH side are the oil cooler fans (so they don't come on until the oil temp is 180~190 deg F). The (single) RH water fan is in front of those fans and the oil radiator (so not easy to see).
    When the LH water fan is running, just feel with your hand at the strakes on the RH side -- if the RH water fan is running, you should be able to feel the entering airflow (and you can do the same on the LH side to "calibrate" yourself). Alternatively, if you remove the water fan relays and put a jumper wire from terminal 30 to terminal 87 in the socket, the corresponding water fan should run (without running the engine) -- if it doesn't, most likely you have a problem in the white connector at the bottom of the fuse-relay panel:
