What deters you from modification? | Page 2 | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by C.Essman, May 2, 2013.
  1. boxerman
    boxerman Two Time F1 World Champ
    20,031
    FL
    Sean
    Depends on what is defined as a Mod. If I put a modern electronic ignition in place of the failure prone original that technicaly is a mod.
    If you remove some design shortcommings is that a mod. Like if I remove the air cleaner and run velocity stacks on a 275 GTB that cleary is not he way it came, but your are unlocking the potential and intent.
    If I use amore modern brake pad that is a mod although the other componants in the braking system are as per orig sec.
    If I chnge the tires that is a mod.
    If I remove emissions equipment and put ahigh lift cam in that is a mod, although ts probably putting ght e car to an intended spec.
    What am i driving at, I think its perfectly OK to symoatheticaly upgrade a car, removing certain obvious faults while keeping the essence of the thing.
    Putting 9 Inch rims on a Daytona rear just makes it better.
    Putting modern rubber on a boxer unlocks the suspension. Changing arestrictive exaust or air filter on an older car, changing carb fuel flows, that all OK.
    Sympathetic enhancements dont change the essential vehicle they just make it run properly devoid of legislative equipment limits from period.
    In other words you are purifying the essence of the vision.
    Of course you can do whatever you want with your car, but at a certain point its not really a ferari, just like a ruff 911 is not technicaly a911.
  2. Tokyo Drftr
    Tokyo Drftr Formula 3
    Jan 18, 2009
    2,461
    UA-USA-JP
    Ро&#1081
    Other than the std modds, i built diffusers, lowered suspensions, custom exhausts and did a lot of custom wiring. Std race car stuff. Pics have been posted before.
  3. TheMayor
    107,785
    Vegas baby
    I think most worry about 1) losing whatever warranty they have and 2) depreciation.
    You can add a $10,000 titanium exhaust to a 458 and it will actually go DOWN in value.
  4. Redneck Slim
    Redneck Slim Formula 3
    Mar 10, 2011
    1,693
    Palo Alto,CA,USA
    Walt Kimball
    Nothing. I have been extensively modifying my cars for decades,including my daily drivers. Better performance,better looks,more enjoyable to drive,more enjoyable to own.
  5. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,638
    E ' ' '/ F
    Enzo Gorlomi
    The main limit is pocketbook. I'm a poor boy, so the mods are minor, and are being done to a 25 year old car :)
  6. Texas Forever
    Texas Forever Eight Time F1 World Champ
    BANNED Rossa Subscribed
    Apr 28, 2003
    85,600
    Texas!
    This. I learned my lesson on modern motorcycles. Just changing mufflers will lead a major headache.
    Plus, it will hurt the value of your car if that means anything. Think about it. Would you buy a car that someone else has modified?
    Dale
  7. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #32 Napolis, May 2, 2013
    Yes and no.
    I began modding over 40 years ago. I changed the factory defroster in my 275 GTB from a sponge wrapped in a chamois to a much more powerful in line fan.
    I enabled my 308 GTB to drive up the Westside Highway in bumper to bumper in the summer without overheating by taking a sawzall to the bonnet and putting in a outlet that allowed the radiator to work properly a modd that Ferrari adapted to later cars.
    That said I take your point as my modified F430 Scuderia clearly shows.
  8. V-TWELVE
    V-TWELVE Formula 3
    1,800
    Vancouver, BC
    I'm ok with any mod as long as it can be removed in a weekend with no repair needed to the vehicle. I also like to see a car with upgraded factory equipment rather than aftermarket. IMO it keeps the vehicle classy and does not cheapen it. An example would be to put Stradale bumpers, spoilers and wheels on a 360 instead of aftermarket components.
  9. V-TWELVE
    V-TWELVE Formula 3
    1,800
    Vancouver, BC
    #34 V-TWELVE, May 2, 2013
    My golden rule is don't F*** with your daily driver when it comes to the mechanicals. I just want to turn the key and go and be assured it will indeed go. Mechanical mods are ok if they fix a problem with the vehicle such as crappy electrical components.
  10. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    I like the car the way it is.
