What did you do to your Mondial today? | Page 13 | FerrariChat
Discussion in 'Mondial' started by ddenboer, Dec 26, 2016.
  1. greatscott73
    greatscott73 Formula Junior
    Sep 1, 2017
    446
    Eastern Tennessee
    Howard Scott
    Removed the A/C compressor to fix a front seal that was leaving a nasty puddle in my garage. Royal PITA to remove and reinstall, but it seems like the problem has been cured.
    JLF and MvT like this.
  2. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
    Needed to have some new rubber to pass the MOT this year. Decided to go for a classic look tire, which I had seen on Johan's (AKA Jeka) Mondial.
    GoodYear efficientgrip performance 225/55 r16 rear
    GoodYear efficientgrip performance 205/55 r16 front
    Allen S., Dino2400 and Jeka like this.
  3. Dino2400
    Dino2400 Formula 3
    Feb 21, 2009
    1,298
    Great choice, look indeed period correct. But is there a piece of your rear bumper missing again?
  4. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    Well, not again :) I didn't repair it since may 2019. Time is an issue these days! I would be lucky if I can take it out for a drive once and a while.
    Anyway also did some pre-work in repairing it. Fitting and it seems to fit perfectly. Only the lower grill does not line up with the middle hole.
    Dino2400 likes this.
  5. Dino2400
    Dino2400 Formula 3
    Feb 21, 2009
    1,298
    Ah! Pfew... For a moment i thought you took another hit. Hope she will be as new again soon!
  6. BillyD
    BillyD Formula 3
    1,828
    Pacific Northwest
    Bill
  7. Brooklands
    Brooklands Karting
    Aug 4, 2014
    112
    North Vancouver, BC
    Phil Delory
    Today I removed the engine.
    For my 1983 Coupe's upcoming 40th birthday, I thought it would be nice to treat the Ferrari to some fresh rubber.
    Since nobody should ever trust old cracked rubbers, with it's 40 years and 25K miles, it's getting new fuel, vapour, coolant, brake, long tunnel, and oil cooler hoses. As well as suspension bushings, axle boots, brake calliper seals, clutch slave seals, cam seals, belts, tensioners, drive sprockets, rad core, water pump seals, and some other standard service stuff.
    Although it took a solid days work to pull the motor with jack stands and floor jacks by myself, and hopefully not much more to put the lump back, I am hoping to save a similar amount of time with the much better access.
    Cheers,
    Phil
    rob, decampos, ellum and 1 other person like this.
  8. moysiuan
    moysiuan F1 Rookie
    4,186
    Canada
    So you did this with a jack and jack stands? Wow, tell me more, I would like to do this someday, without a lift.
  9. Brooklands
    Brooklands Karting
    Aug 4, 2014
    112
    North Vancouver, BC
    Phil Delory
    Just 6 ton 24” jack stands for the back frame, and normal 2 ton shorter stands for the front. Two floor jacks with one having a 24” lift was perfect for my 5” plywood dolly. A small 2x4 spacer on the jack allowed the final 25.5” lift for the engine to roll easily out the back. All really pretty straight forward.
  10. 85QVEuro
    85QVEuro Formula Junior
    Jan 15, 2021
    545
    NYC
    Joe
    same here - used a 3 ton jack, jack stands, a moving dolly w/ 3/4" plywood on top for a landing surface - kept the front wheels on the ground
  11. 85QVEuro
    Jan 15, 2021
    545
    NYC
    Joe
  12. 76Steel
    76Steel Formula 3
    Sep 8, 2007
    1,482
    New Jersey
    This is interesting, it seems like pulling the engine on the Mondial for service is perhaps slighly more common than expected. With Mondial's engine tucked in generally, it's way easier to get to the rear bank once removed.
    Yesterday, I leather conditioned all door panels and seats in my 1987.
    moysiuan likes this.
  13. moysiuan
    moysiuan F1 Rookie
    4,186
    Canada
    I think the engine is missing? :)
  14. 85QVEuro
    Jan 15, 2021
    545
    NYC
    Joe
  15. srephwed
    srephwed F1 Veteran
    7,088
    street,md
    fred brown
    Nothing!!! It's 8 degrees here.
  16. 85MondialQV
    85MondialQV Karting
    Feb 20, 2021
    98
    Matt Drake
  17. Cafe racer
    Cafe racer Rookie
    Mar 22, 2020
    24
    London
    Nigel Waterfall
    I got my Mondial T back from a major service last weekend, they also sorted out a few other issues as it was overheating (blocked radiator) ABS light on (computer fault & wiring loom issues) & suspension light on (faulty actuator)
    I still have a few jobs to do, the Suspension light is still on, but the actuators all work so maybe it just needs re-setting? or can this be reset without going to a dealer??
    the next big job is going to be a repaint as there are chips & scrapes on almost every panel, but for now I'm going to enjoy the car over the summer
    Nigel
    Brooklands and moysiuan like this.
