355 - What do these things have in common..Door locks, | FerrariChat
355 What do these things have in common..Door locks,
Discussion in '348/355' started by EFerrari34, Mar 12, 2022.
  1. EFerrari34
    EFerrari34 Formula Junior Rossa Subscribed
    Jun 19, 2021
    535
    Dallas, Tx
    Timothy
    Good evening,
    Are the following items all tied together on one fuse?
    Cabin light, door locks, door lights & Frunk light?
    They’re all non operative on a 355.
    Are they all tied to fuse 30?
    Thanks in advance.
  2. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,260
    Ian Riddell
    Frunk light is on fuse 12 in the frunk and requires the sidelights to be turned on. On the 2.7 car, doorlocks, door lights and interior lights are on fuse 30.
    Is your clock working?
    308 GTB likes this.
  3. EFerrari34
    Jun 19, 2021
    535
    Dallas, Tx
    Timothy
    The clock is not working sir
    Qavion likes this.
  4. Qavion
    Feb 20, 2015
    14,260
    Ian Riddell
    Then it must be fuse 30 or its associated wiring.
    308 GTB likes this.
  5. Qavion
    Feb 20, 2015
    14,260
    Ian Riddell
    Of course, if the fuse blows again, you'll have to figure out what is causing it.
    e.g. one of the door lamps' power wires shorting to earth.
    All of fuse 30's wiring is orange. Have you done anything to the car recently which may have disturbed the wiring (i.e. in the cabin or in the doors)?
    308 GTB likes this.
  6. EFerrari34
    Jun 19, 2021
    535
    Dallas, Tx
    Timothy
    No sir, I haven’t. But I will try to track it down. Thanks so much for the start.
    Qavion likes this.
  7. EFerrari34
    Jun 19, 2021
    535
    Dallas, Tx
    Timothy
    Fixed. Thank you sir
    Qavion likes this.
  8. EFerrari34
    Jun 19, 2021
    535
    Dallas, Tx
    Timothy
    The battery was changed yesterday & the fuse blew again. I changed the fuse & it blew almost immediately. So my next step should be to follow the orange wires, correct?
  9. Qavion
    Feb 20, 2015
    14,260
    Ian Riddell
    Sorry to hear that your problem continues.
    Correct. Now that you have a hard fault, I would try to isolate the problem by disconnecting things like door plugs and remove and inspect the interior light. I vaguely recall some folks having issues with wiring shorts in the interior light area (but that may have been on a Spider).
    You could also try disconnecting the doorlock ECU (in the passenger footwell), but I don't recall this ECU blowing fuses. It seems unlikely that the clock would cause this problem.
  10. Qavion
    Feb 20, 2015
    14,260
    Ian Riddell
  11. Qavion
    Feb 20, 2015
    14,260
    Ian Riddell
    I've just noticed a wire colour variation between the photo above and the wiring diagrams:
    A grey wire seems to be going into the "+" terminal, and not an orange wire. I don't know if this is standard or a repair.
  12. C-speed
    C-speed Karting
    Jul 13, 2022
    171
    Crescent Kao
    Thanks big time for all the help everyone! I took apart the pedal cover and front center console and discovered that the throttle cable was pinching a bundle of aftermarket wiring for the radar detector/laser jammer which was causing the door lock switch to activate.
    All fixed now! Woot!
  13. C-speed
    C-speed Karting
    Jul 13, 2022
    171
    Crescent Kao
    Oops, just realized I posted my last reply in the wrong thread :/
  14. EFerrari34
    Jun 19, 2021
    535
    Dallas, Tx
    Timothy
    I followed the orange wires to the actual door locks. One measured 5 amp & the other 6; so that’s why it kept blowing. 11 amps on 10 amp fuse. Thanks for your guidance. All set now.
    Qavion likes this.
  15. Qavion
    Feb 20, 2015
    14,260
    Ian Riddell
    I'm not sure what sort of current they are supposed to pull, but perhaps your doorlock mechanisms need lubricating. Out of the car, the doorlock actuators themselves can be tested with a simple 9V battery.
  16. EFerrari34
    Jun 19, 2021
    535
    Dallas, Tx
    Timothy
    Follow-up. I simply disconnected the ceiling light bulb, replaced the 10 amp fuse & everything (outside of the light obviously) works. So my issue is with the interior light…more wiring detective work to come.
    Qavion likes this.
  17. Qavion
    Feb 20, 2015
    14,260
    Ian Riddell
  18. Qavion
    Feb 20, 2015
    14,260
    Ian Riddell
    I assume power comes into the light like this
    ... and that the metal bar (I've drawn a circle around) is live. Make sure the metal bar or the orange wires on that bar aren't touching the car's bodywork.
    EFerrari34 and Carmellini like this.
  19. EFerrari34
    Jun 19, 2021
    535
    Dallas, Tx
    Timothy
    @Qavion
    I removed the bulb; replaced the fuse & everything else worked perfectly. I changed the bulb (and nothing else) and so far so good. However; that you so much for the breakdown. That may prove to be very helpful.
