What does the Light Sensor do? | FerrariChat
Discussion in '360/430' started by RossoF430, Feb 21, 2023.
  1. RossoF430
    RossoF430 Karting
    Jun 6, 2022
    142
    Clint
    Like the title says, what does the Light Sensor on top of the dash do? Secondly, has anyone added auto headlights on?
    colorfull likes this.
  2. GogglesPisano
    GogglesPisano F1 Rookie
    3,111
    East Bay, California
    Joe
    It's a "sun radiation sensor." It is used as part of the automatic climate control to adjust the temperature.
    Taken from another group for better explanation:
    "A solar radiation sensor mounted within an automotive vehicle can accurately detect solar radiation heat influx due to rays of sunlight falling upon the vehicle. The detected heat influx value is used in controlling an automotive vehicle air-conditioning system to adjust passenger compartment air temperature, more specifically to determine an appropriate air conditioning air mix door opening percentage. The sensor is part of the AUTO air conditioning system."
  3. hessank
    hessank Formula 3
    1,901
    Canada, Florida
    Fred
    Not exactly auto headlights BUT my Canadian 360 has DRL (Daylight Running Lamps) and I have not touched the light switch in 9 years
  4. GogglesPisano
    3,111
    Joe
    With the Scud Ing Swiss LED accent light for the front, I just leave my switch in the first setting since it's basically like an LED DRL.
  5. RossoF430
    RossoF430 Karting
    Jun 6, 2022
    142
    Clint
    The lights turn off when the key is switched off, correct? I believe the "P" in the center console turns on parking lights but they stay on even after key is removed.
  6. GogglesPisano
    3,111
    Joe
    That is correct. They're only on when the car is turned on.
  7. imahorse
    imahorse F1 Rookie
    4,291
    WI
    Dustin
    It's the car's nipple. Feel free to grab it and twist it if you want your car to go faster.
    hessank, JWeiss and priericky128 like this.
  8. JWeiss
    JWeiss F1 World Champ
    Nov 18, 2010
    11,772
    NYC and Long Island, NY
    JWeiss
    I thought that was the one under the driver side mirror.
    imahorse likes this.
  9. imahorse
    imahorse F1 Rookie
    4,291
    WI
    Dustin
    That one is too. They are kind of lopsided. If you pinch them both while going 88mph you go back in time.
    Sj_engr and JWeiss like this.
  10. hessank
    hessank Formula 3
    1,901
    Canada, Florida
    Fred
  11. racerlev
    racerlev Rookie
    Dec 5, 2022
    15
    Since delivered in August 2023 my 296 GTB has had the following issues that I now believe is due to a faulty light sensor:
    1. Headlights often on during bright sunlight
    2. Driver displays too dark during daylight
    3. Automatic windshield wiper does not work.
    I expect that Ferrari will replace the sensor later this month.
  12. Qavion
    Qavion F1 World Champ
    14,049
    Ian Riddell
    In case that doesn't make sense to most folks...
  13. racerlev
    racerlev Rookie
    Dec 5, 2022
    15
    Hooray! Ferrari of New England found that the light sensor was not properly adhered to the windshield. (problem since car was delivered new). Sensor was cleaned of old "glue" and properly adhered to the windshield which resulted in clearing up the issues of headlight sensitivity, automatic windshield wiper not working, and HUD being too dark.
    Qavion likes this.
  14. Cknkeyasen
    Cknkeyasen Karting
    Nov 28, 2023
    58
    Dallas
    Cliff Nkeyasen
    So no risk of coming back to a dead battery right?
    CKN
  15. GogglesPisano
    3,111
    Joe
    Not unless you come back a month later :)
