What gearbox oil are you using in your 308/328? | Page 4 | FerrariChat
Discussion in 'Technical Q&A' started by Mike328, Jan 27, 2004.
  1. Royal Purple 75W-90
  2. Redline 75W-90 ** NS **
  3. Redline 75W-90
  4. Shell Spirax 75W-90
  5. Mobil 1 75W-90
  6. Castrol Hypoy/c 80W-90
  7. Castrol Syntrax 75W-90
  8. Swepco 201 80W-90
  9. Agip Rotra LSX 75W-90
  10. Valvoline Synthetic 75W-90
  11. Chevron Supreme LS 80W-90
  12. Other (specify below...)
Multiple votes are allowed.
Results are only viewable after voting.
  1. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
  2. RichardAguinsky
    RichardAguinsky Formula Junior
    Nov 12, 2007
    478
    Palo Alto, Californi
    Richard Aguinsky
    I'm using RedLine MT-90. Anyone else using it? I didn't see it in the polling list.
    Cheers,
  3. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,558
    NY/SC
    David
    Based on this thread and local availability I'm going with Royal Purple; is it a given I'll need to add friction modifier? Or would that come only upon a post-change drive that exhibits chatter?
    And how much oil does the change require/should I have on hand; I can't tell from the shop manual, the line appears cut off.
    Thx
  4. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    What's the story on the Redline lightweight shockproof?? The few times I have heard this mentioned, it was in raves on the superiority of the stuff, and yet most seem to be using NS.
    I'm due for an oil change. Wondering which oil to use...
    Hans
  5. Steve Magnusson
    26,932
    No, it already has a full portion of the friction modifier included.
    The gearbox capacity varies by F model, but, if you have a 328, it takes a little more than 4 qts so most people buy 5 qts.
  6. Island Time
    Island Time F1 World Champ
    12,110
    E. TN
    David
    Mobil 1 has transformed every trans I've ever put it in. I'm going w/ it in my new to me 328.
    Is LSD additive required w/ this oil?
  7. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,832
    Cerritos, CA.
    Mike, you forgot to add the Redline MTL on the Poll, I have a very good experience with MTL
  8. AJS328
    AJS328 F1 Veteran
    Apr 23, 2003
    7,520
    New Jersey
    Augustine Staino
    I used Mobil 1 in a couple of my other 328's in the past and I was very happy with it. I would say no to your question about the LSD additive because I never had any diff chatter at all with the Mobil 1. Hope that helps. :)
  9. Island Time
    12,110
    E. TN
    David
    I'll see how it goes w/out it
    Thanks ;)
  10. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,286
    Black Forest Germany
    Martin N.
    it's not in the poll list, but I use, what's imprinted in the manual and engine compartment. ( '80 308 GTB Euro carb, dry-sump )
    Agip Rotra MP 80W-90. No second gear issues, no LSD chatter, and it's ridiculously cheap.
    Best Regards from Germany
    Martin
  11. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    If you know exactly how much over the 4 qts is, then you can use that extra half quart (or so) as a flush when draining the case.
  12. moysiuan
    moysiuan F1 Rookie
    4,254
    Canada
    Why are more people not using Redline MTL? Used it on my old Porsche 944 with the transaxle as the recommended product, did make a huge shifting difference, and I recall a 328/Mondial service bulliten recommended an 80 weight oil for easier shifting? I have some MTL leftover, can I use it in my 1988 Mondial Cab safely? Redline recommended 75/90 and suggested its products can be blended for specific application, just surprised that with all the 2nd gear low temp concerns I expected to see more 80 weight soultions...
  13. f355spider
    f355spider F1 World Champ
    18,055
    There are several threads on MTL...not sure why it is not mentioned here. The feedback has been largely positive.
  14. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,558
    NY/SC
    David
    Towards improving my 328's 2nd gear cold shift and based on this thread and local availability I tried Royal Purple back in March. It was a slight improvement over whatever previously existed but not the dramatic improvement some have seen.
    Yesterday I refilled with RedLine NS and there is a marked improvement in shifting as well as over the RP. Just one fella's experience.
  15. Euro Quattro
    Euro Quattro Formula Junior
    Apr 20, 2005
    344
    Vancouver
    Kent
    I just talked to service dept at RTGT the oldest ferrari dealer in the US and they have switched to Shell lubricants from AGIP.....Im either trying Shell Spirax 75W-90 or the Royal purple. The redline worries me with the chatter people are experiancing with it. I currently have AGIP in it now with only a slghtly stiff cold second gear,but I can live with that,but chatter I dont think I can tolerate.
  16. BigTex
    79,406
    Houston, Texas
    Bubba
    Well, being a Dealer they would switch from AGIP to Shell as indicated on all warranty service...
  17. AJS328
    AJS328 F1 Veteran
    Apr 23, 2003
    7,520
    New Jersey
    Augustine Staino
    I just switched my gear oil for the 4th time in the last 8 months, so I imagine the inside of my transmission must be spotless! :) I never checked to see what was in it when I bought the car but I have switched from that to Redline 75w90NS to Royal Purple to Mobil 1 to Redline MTL. The Mobil 1 was put in by the shop when I had my clutch/shift linkage adjustment done back in June. I always liked Mobil 1 when I used it in my cars in the past but for some reason this particular gearbox just didn't like it. The shifting was generally stiff and awkward, even when fully warmed up and 2nd gear was a *****, especially during downshifts. I just swapped it out for the MTL this morning and I must say there is a marked difference. I have taken two short runs in the car and without even fully warming up the gearbox, the shifting overall is much better. There is also no chatter from the diff, although we did add a little friction modifier. So far, I'm very happy. I'll report back if I notice any changes, either good or bad, after my next extended drive.
  18. AJS328
    AJS328 F1 Veteran
    Apr 23, 2003
    7,520
    New Jersey
    Augustine Staino
    Okay, I have now driven my car for two longer drives, and I can say that switching to Redline MTL has completely transformed my gearbox! Out of the 328's that I've had, I always felt that this one had the stiffest shifting of the bunch. The MTL has changed it so dramatically that I would venture to say the car shifts as nicely as any I've driven. I fully recommend it for anyone with a gearbox that feels stiff or reluctant. It works wonders! :)
  19. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    I've got 5 qts of Redline MTL just waiting to be put in....(draining the old Redline 75-90 ns out)...
    Glad to hear you have had positive results.
    I didn't really have any specific problems with 75-90NS, but IIRC, one of the more experienced Ferrari techs/mechs (who is no longer here sadly... IIRC) said MTL was the only thing he used.
    Thanks for the info.
  20. Llenroc
    Llenroc F1 Veteran
    5,560
    Colorado
    Vern
    You are talking about Brian Crall he recommended MTL for hard shifting(non hypoid) gearboxes. Hard shifting appears to vary by car IMO. My 355ch works well with MTL or GL5 stuff, my 308s did well with their GL5 stuff, my 348 worked better with MTL, but my cars seemed to work better with Redline Products than other brands.
    You should do a search on this and read some of the idiotic posts arguing with Brian on this subject they are a hoot!!
  21. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Those posts as I understand it are the reason he is no longer here. IMO, he offered valuable support and info to us fellow owners and has been a great loss to the site.
