What happens exactly when you turn the car off while in gear on a DCT? | FerrariChat
Discussion in 'Technical Q&A' started by lunyx, Nov 27, 2022.
  1. lunyx
    lunyx Rookie
    Jul 5, 2022
    41
    It seems like this is the commonly accepted way to park the car, but what's the sequence of events? Do DCT cars have a parking pawl like other automatic transmission vehicles, or is it just left in gear like a manual? I'm guessing that the electronic parking brake also engages, but does that happen before or after the vehicle is put in park? I'm mainly wondering about the proper procedure to park on a slope, to minimize stress on the parking pawl, if there is one. Should the parking brake always be engaged first before turning the car off?
  2. windsock
    windsock Formula 3
    1,162
    Yes there is a parking pawl, parking brake and the car will leave 1st and reverse gear engaged. Clutch and gearbox is disengaged from the engine as it requires the hydraulic pressure to engage clutch.
    Qavion likes this.
  3. lunyx
    lunyx Rookie
    Jul 5, 2022
    41
    So effectively, the car is in neutral with the parking pawl in place and the parking brake applied? Does the parking brake get applied first, or does it rest on the pawl before the parking brake gets applied?
  4. windsock
    windsock Formula 3
    1,162
    The parking pawl will drop first and the parking brake second. whether it is resting on the park pawl or the parking brake probably is determined by the timing and whether you are on a hill or not. Steep hill you are likely on the park pawl flat ground the parking brake will likely be doing the heavy lifting. Not sure it really makes any difference.
  5. lunyx
    lunyx Rookie
    Jul 5, 2022
    41
    Good to know. I will probably just engage the parking brake first before turning off the car so that the brakes are the primary method of holding the car in place if I'm ever on an incline.
