What happens if 355 belt fails? | Page 2 | FerrariChat
Discussion in '348/355' started by IIIVVGTS6, Sep 30, 2023.
  1. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,771
    change/few/into/2/
    The engine will destroy itself in 2 complete revolutions.
  2. Rifledriver
    37,335
    No, it will bend a few valves and if iron break a few guides. Big difference between that and a destroyed engine.
  3. Johnnieblack115
    Johnnieblack115 Karting
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    #28 Johnnieblack115, Oct 14, 2023
    What’s a valve job run DIY? Are there ever any signs before the belts go?
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    Let's say you replace 25% of the valves, all the valve guides, no pistons, no liners. So, $5,000 for a machine shop.
    $3,000 for 30K service kit and two head gaskets plus some other gaskets.
    $1,000 for misc (oil, filters, gear oil, brake fluid, coolant, you'll find some other stuff)
    We are already at $9K and that is not a 40 hour job.
  5. Johnnieblack115
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    The 30k kit is $3,000?? I thought Hill Engineering sold one for like $1,700?
  6. lopena
    lopena Formula Junior
    767
    Of course, if a belt snaps it may not just bend some valves but actually break them…then you’ll have a valve head or two rattling around the cylinders doing untold damage to the pistons, heads and bores…now it’s a total rebuild.
    Alan
    N.J.
    greg328 likes this.
  7. yelcab
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    Price the two head gaskets, water jacket gaskets, intake manifold gaskets, exhaust gaskets, oil drain pipe gaskets, head nuts, head nut washers, don't forget that special head nut socket and tool (they are no longer on loan).
    $495 each, and you need two
  8. Rifledriver
    37,335
    Have you ever seen that even once on a 355? Never is the answer.
  9. Rifledriver
    37,335
    Head nuts and head nut washers???? Why on earth would you ever change those?
  10. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    492
    London
    Steve C
    Even a valve head or two ratting around inside cylinders will only necessitate the replacement of two liners and pistons at most. I recently had a liner replaced, from the top, disconnecting the gudgeon pin rather than unbolting the rod from the crank. It wasn't that expensive.
  11. yelcab
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
  12. Rifledriver
    37,335
    Using quality tools will prevent damaging the nuts. Of all I have done or over seen I have never replaced either. I am doing 2 motors now and have ARP studs for both but reusing all nuts and washers.
  13. yelcab
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    Replacing the liner by removing the piston wrist pin, taking the piston out and the pulling the liner from the top? That is interesting. I would like to see that process. I have always removed the piston with rod from the crank shaft and made a plate to pound the liner out from its bottom.
    As for your "not expensive" statement, that is a deep pocket you are speaking from? The last time I checked, the liner was close to $1000 each. You need one set of rings for one piston $400.
  14. redwedge
    Sep 30, 2012
    492
    London
    Steve C
    I don't have any pics of the process, but the respected indie who worked on my car over here in the UK have done it a dozen times now, obviously every time on #2 cylinder, so it's a proven process.
    Cylinder liners are currently £443 from Maranello Parts. Rings are £200 for a single set of OEM, or Superformance will sell you a set for the whole engine for £649. I'm sure they'd split a set if you asked nicely, call it £100 for a single cylinder if they're nice to you, £150 if they're not. Half what you're quoting.
  15. yelcab
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    I buy from Ricambi so that I know where it's coming from. Yes, it's expensive but the risk is super high if it does not work. It's been a few years since i bought the liner though so prices may have changed,
  16. TinkerF355
    TinkerF355 Rookie
    Jul 10, 2022
    10
    France
    In France, Ferrari says F355 belts can be done every 5 years, providing the car is used regularly
  17. IvanRico
    IvanRico Karting
    198
    Westchester NY
    Ivan Rico
    Reference? I don't disagree with the 5 year assessment - its what Pocono Sportscar recommends as well but that's not the same as an official Ferrari maintenance document.
  18. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,467
    Los Angeles
    I would trust the experience of an intelligent independent Ferrari mechanic w/ decades of exposure to 355's over an "official Ferrari maintenance document."
    IvanRico likes this.
