What have you done to your Ferrari Today? | Page 10 | FerrariChat
Discussion in '308/328' started by SteveGTB, Feb 5, 2014.
  1. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    I have an old Fox XK band radar detector with the two pitot looking tubes on the front grille. Still works too! Goes off every time I get near high tension wires. I believe these were dealer installed on my 1978 308 GTS. Like you, I am struggling on what to do with them. Keep or delete?
  2. dflett
    dflett Formula 3
    1,632
    NY
    David
    #227 dflett, May 17, 2014
  3. pgarossino
    pgarossino Formula Junior
    Nov 19, 2009
    307
    Houston Tx
    Paul G.A. Garossino
    Interesting that after about 12K miles the Iridium plugs had gone from 0.025 to about 0.040. I'm not sure that I noticed any change in performance, but I was glad to have the plugs back to 0.025 and a more substantial electrode setup that hopefully will last a little longer.
    When I last changed the plugs all extenders where in good shape so I reused them. This time around 5 out of 8 had longitudinal cracks along their body from the top down. I have a new set [of 8] coming from T.Rutlands [$17 ea.] which I will install when they get here.
    Drove her and my wife over to Ray's Grill for dinner. Stopped at Da Vinci Restorante on the way back to see Chef Alex's yellow F355. Nice car! Great night!!
  4. Jez
    Jez Karting
    Jul 29, 2013
    70
    Westerham
    Jeremy Gilbert
    Replaced a relay to stop the right hand side headlight bouncing up and down on its own!!
    Swapped out some of the fuses while I was there and tightened up the connectors on the fuse board.
    Fixed the interior light. It's now comming on when I open the drives door, but not the passenger door for some reason!! Will need to investigate more next week
  5. jagmanv12
    jagmanv12 Karting
    Aug 25, 2010
    236
    Surrey UK
    Mark
    Visited the Mercedes and Porsche museums in Stuttgart and then drove to Mannheim. Coming to the end of a 2 week European tour as back to UK tomorrow. Will be close on 3000 miles in 2 weeks.
    Ooops wrong section as I'm in my 550.
  6. francisn
    francisn Formula 3
    Apr 18, 2004
    2,015
    Berks, UK
    francis newman
    Walked to where my GT4 lives (it's 4 and a bit miles away depending whether I take the scenic or boring route). Fitted the new relay for the headlighgts and all now works as intended except the inner headlamp is still not lighting. But that will get sorted later in the week.
    I was only with the car for 15 minutes but the leather smelt really beautiful since I treated it with Leatherique.
    Next drive? Maybe Thursday - HOPEFULLY
  7. TacElf
    TacElf Formula 3
    Aug 15, 2010
    1,719
    Seattle area
    Jeff
    Fixed the headlight linkage on the driver's side pod, cleaned out the cabin fan "filter" behind the lower front grill, pulled out both blower fans an completely cleaned them, disassembled the center console clock and cleaned it out really well. Now its keeping perfect time again.
  8. RJR89
    RJR89 Formula Junior
    May 14, 2006
    808
  9. ckracing
    ckracing Formula Junior
    May 20, 2006
    728
    Jacksonville,Florida
    Charles
    Rebuilt the cv joints and replaced the boots.
    3 weeks ago I replaced timing belts, new spark plugs, new oil and filter and installed new Hill Bearings.
    Charles
  10. DANCER308
    DANCER308 Formula Junior
    Oct 24, 2009
    935
    KY
    Dan
    '79 GTS. Removed the baffles from the exhaust tips, no more chirping angry crickets!
  11. TacElf
    TacElf Formula 3
    Aug 15, 2010
    1,719
    Seattle area
    Jeff
    Did that today, too :D
  12. rkljr
    rkljr Formula Junior
    May 16, 2011
    723
    South of Boston, MA
    Richard
    Completed the installation of my steering rack after replacing the worn inner bushing. It feels so much smoother.
  13. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    Tracked down a loose wire. Now the radio works.
    Not that I ever turn it on but the hazard flashers are on the same circuit and you never know.
  14. Crallscars
    Crallscars F1 Rookie
    Jun 7, 2006
    2,512
    Bainbridge, GA
    Douglas Crall
    plugged in the trickle charger.
  15. SpyderGT
    SpyderGT Formula Junior
    May 15, 2005
    997
    Vancouver, BC
    Jon
    Sea to Sky Highway - Vancouver to Whistler - about 190 miles return - perfect GTS weather
    Jon
  16. John M
    John M Formula Junior
    Nov 18, 2004
    887
    Kentucky
    Two new radiator fan motors from Jag dealer which were perfect replacements for the originals sans paint. Painted the original fan blades and the new fan motors. And installed all through the grill openings (no bumper or radiator removal required).
    Round two was new original fuse boxes. Had to modify the white one to match the i power inputs. Add a couple of doublers as well to white box. New covers and decals for them as well. Very little drama for this change out.
  17. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Replaced the cabin light on my GTS so it now goes on when my doors open and have a delayed off when doors are closed. Hasn't had that function since I owned it. Turns out part of the old lamp housing was crushed inside. Amazing that someone would just mash the thing in destroying its function rather then take the time to pop it in correctly.
    When all else fails read the damn manual. - wife
  18. ClydeM
    ClydeM F1 World Champ
    11,916
    Wayne, NJ
    Clyde E. McMurdy
    Check the parts xref thread. There's a cheap, readily available replacement.
    Getting the new puppy on...that's a different matter.
  19. ar_es
    ar_es Formula 3
    Jun 6, 2013
    1,720
    Rome
    Ares
    Oil change. Nothing more nothing less!
    Sent from my F430 using Tapatalk.
  20. lopena
    lopena Formula Junior
    759
    I took my 1988 328GTB to Mario LoMedico's Exotic Cars in Shrewsbury NJ (732-747-6720) for a timing belt service and fluids change. I also asked them to find the cause of an intermittent starting problem. The old belts were 6 years old with about 2,000 miles on them and they didn't look too bad (no cracking) but they were beginning to stiffen and dry out a bit...I suppose I could have easily gotten another year out of them, but why take that chance? Mario's Ferrari technician, Danny, found the cause of my starting problem (corrosion at the fuse box) and the car now starts and drives great, especially with new synthetic gear lube in the transaxle.
    I've had Mario's service my 328 for the past twenty years and they've always done vey good work. They're honest, reasonably-priced and highly experienced.
    Alan
    New Jersey
  21. bentrm
    bentrm Formula Junior
    Sep 17, 2011
    596
    Pittsburgh, PA
    Rob
    Good to hear! Hope all goes well.
    I finally buttoned up my car.
    Did the belt service with help from my great friends.
    Today I did a quick detail to be presentable at cars and coffee on saturday.
    Walmart tomorrow for Old Spice. If'n I get the chance.
    If not.....
  22. sltillim
    sltillim Formula 3
    1,697
    San Diego
    Replaced my clutch cable and became a contortionist at the same time!
  23. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Installed a garage door open for the Ferrari bay. Ironically it has a cog tooth belt!!!!
  24. ClydeM
    11,916
    Wayne, NJ
    Clyde E. McMurdy
    You posted this in the parts XREF thread, right? Please, with part numbers if you have them.
    I did mine without incident. When mine broke I was in the boonies of NY/NJ/PA and happened to be near a small local Ford dealer who wouldn't touch the Ferrari. Saturday like 3pm minutes before closing. Not good. If it weren't for his enthusiastic mechanics, I would have had to flatbed it home. There's a thread about it somewhere in the archives.
