What have you done to your Ferrari Today? | Page 101 | FerrariChat
Discussion in '308/328' started by SteveGTB, Feb 5, 2014.
  1. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,807
    Australia
    Mark R
    Had the time to give the engine a blow over with compressed air and gave it a wipe down.
    Not bad for a 30 year old, unrestored engine bay if I do say so myself.
    Dane, offtheworkigo, Jroe550 and 6 others like this.
  2. carl888
    carl888 F1 Veteran
    Oct 31, 2003
    6,938
    Melbourne, Australia
    Carl
    Now all you need is to put back some of the wax and you'll be done :D:D:D
    Rosey likes this.
  3. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,807
    Australia
    Mark R
    Forget about the wax, I still trying to clean off your sticky fingerprints from the last time you worked on it. :) :)
  4. Tonksy1
    Tonksy1 Karting
    Jun 21, 2016
    91
    New Zealand
  5. lopena
    lopena Formula Junior
    759
    As you may remember I’ve been replacing the plastic fuel injection lines using the kit sold by Unobtainium Supply. This was a fiddly, challenging job but I’m happy to say that, after about 30 hours, the job is done!
    One surprising fact: the original 32-year-old fuel lines were still pliable with no signs of cracking or swelling, even when I cut one open.
    Alan
    N.J.
    offtheworkigo, JuLiTrO, Rosey and 2 others like this.
  6. bertrand328
    bertrand328 Formula 3
    Jun 1, 2015
    1,620
    France
    Bertrand
    Look new ! I would like to see if all part of the car look like same ...
  7. lopena
    759
    Jroe550, Rosey and bertrand328 like this.
  8. 328GTSinPA
    328GTSinPA Rookie
    Dec 22, 2019
    42
    PA
    David Felker
    Gave it an upper bunk in my garage.
    Thanks to Peter Imbimbo of Car Lifts Plus, I now have a Backyard Buddy Four Post Lift. Works flawlessly and fits the 991 Turbo S in the lower berth and the 328 GTS in the upper berth just perfectly. All this in a garage with a ceiling height of only 9'4".
    Peter and his team did the installation, testing and troubleshooting in under three hours. The lift was packaged beautifully with no mars, scratches or rust. Backyard Buddy was the ideal solution for the limited ceiling height. I had a Lift Master 8500W garage door opener installed prior to Peter's arrival. I can't say enough about Peter's professionalism and level of service. He is a great resource for all of us.
    offtheworkigo likes this.
  9. lm2504me
    lm2504me Formula 3
    1,122
    Nipomo, CA
    Richard
    Replaced the air injection hose from the air pump to the diverter valve. Original hose cracked when I removed the air pump to install stainless steel plugs where the rear bank exhaust analyzer tubes are installed. I purchased 3 feet of FC-647-12 black cloth covered hose from this site:
    https://teaguecustommarine.com/em0011/12-fc647-cloth-braid-hose
    I cut to fit the hose after I reinstalled the air pump. I had to use some silicone spray on the diverter valve side of the hose to slip it on the fitting. Tensioned belt based on 78 owner’s manual.
    Milkshaker0007 likes this.
  10. Milkshaker0007
    Milkshaker0007 Formula Junior
    Sep 22, 2012
    432
    Midlands,uk
    Paul
  11. sahn44
    sahn44 Rookie
    Aug 29, 2019
    41
    New York City
    M. Sahn
    Tamahal, Dane, Jbrauer and 7 others like this.
  12. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Image Unavailable, Please Login Conditioned and touched up the 39 year old Connolly leather this morning... A few authentic wear marks. She is a driver not a show car....
    Tamahal, rocket50 and JuLiTrO like this.
  13. rjlloyd
    rjlloyd Formula Junior
    Jun 19, 2014
    447
    Brisbane, Australia
    Richard Lloyd
    After reading one of the other threads, decided to clean up my targa top. A previous owner had decided it would look good to badly spray paint it black, so after carefully paint stripping it and then using some fibreglass conditioner, came up great Image Unavailable, Please Login
    Then the stripper went on
    Then used a fairly soft scraper to remove the softened paint
    And finished
    Tamahal, Rosey and JPMD like this.
  14. rjlloyd
    Jun 19, 2014
    447
    Brisbane, Australia
    Richard Lloyd
  15. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,313
    Germany
    Steven
  16. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,807
    Australia
    Mark R
  17. built2grind
    built2grind Formula Junior
    Oct 16, 2016
    419
    The Peninsula
    ANDREW
    ‘83 Euro QV in Yellow? How many do you think are out there? WOW!
  18. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Image Unavailable, Please Login The E brake on my 82 308 was engaging a bit high, indicator of adjustment needed. So I adjusted the rear brakes today… You can get to the outside adjustment without removing the wheel. The E break engagement is a bit lower now.
  19. Tustin308
    Tustin308 Rookie
    May 20, 2019
    39
    Tustin, CA
    Arthur Trejo
    Dane, Ray F, miketuason and 3 others like this.
  20. 308Dadoo
    308Dadoo Formula Junior
    867
    Aliso Viejo CA
    David
    miketuason likes this.
  21. jferazzi
    jferazzi Karting
    Sep 12, 2009
    97
    Indianapolis
    Moved the 308 into its new garage! My family and I moved into a different home in the same neighborhood where we’d been living. I was able to keep the 308 at the old house while I worked on the garage at the new place. I finished and painted the drywall then did an epoxy floor. I went with one of those kits from Lowes... Really happy with the way it turned out. Prep work was a colossal pain, but I think it was worth it. Just hope it holds up! The top picture is a not-very-good before pic. I also ordered a Ferrari flag that should fit nicely on the wall above.
  22. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    12,083
    FRANCE
    "De-quarantined" or "de-confined" my 328 GTB to go to to the supermarket.
    You are allowed a one-hour sortie to buy "essential provisions"; I bought 24 half-a-litre beer cans, and 6 kilos of cat food (a cat has had the good idea to have her babies at my home...). Should I have been asked, I could easily have explained that I can't be expected to carry 12 kilos of beer and 6 kilos of cat food on a 1 kilometer walk. The 25 kms on the odometer (15 miles) for a two kms walk would have been more difficult to explain...and the stockpile of beer cans in the house, too...
    For the first time in years in the North-East of France, it has not rained at all for five weeks, and you are not allowed to drive the cars...how ironic.
    The car was happy; me too.
    Rgds
    eyeman1234, QV308 and JPMD like this.
  23. nerofer
    Mar 26, 2011
    12,083
    FRANCE
  24. bertrand328
    Jun 1, 2015
    1,620
    France
    Bertrand
    Bruno, how many beer did you buy this month ? ;)
    And take care at the social distance with the Focus !
