What have you done to your Ferrari Today? | Page 119 | FerrariChat
Discussion in '308/328' started by SteveGTB, Feb 5, 2014.
  1. sahn44
    sahn44 Rookie
    Aug 29, 2019
    41
    New York City
    M. Sahn
  2. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    i finally got around to replacing the heater ducting under the spare tire with the correct type of hose, which of course led me to find that two of the 2 heater cores were leaking (Fresh antifreeze on the coils of both), which caused me to search for replacement heater cores and find some off eBay, pressure check those, and install them. Next is a brake fluid flush!
    Thanks go to all of those who commented on my adventures.
    mcimino, Dino246gt, thorn and 2 others like this.
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,812
    Cerritos, CA.
    mcimino, Dane, Basal Skull and 7 others like this.
  4. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
  5. sahn44
    sahn44 Rookie
    Aug 29, 2019
    41
    New York City
    M. Sahn
  6. classicalfas
    classicalfas Formula Junior
    318
    Gardiner, NY
    Peter D
    My last post here was taking out the 308gt4 motor in October. The crank and pistons are back in after the block was machined and the freshly rebuilt heads are on. The oil pump bushings were too loose and out of tolerance so I needed to machine up some new ones. These pumps were essentially assembled and machined together, new bushings cannot simply be pressed in. They will be misaligned and the gears will not spin freely. The bushings need to be finish machined on the lathe, ID, OD oversized about .0015” and pressed in the housing and cover.
  7. Kent Dellenbusch
    Kent Dellenbusch Formula Junior
    664
    Upland, CA
    Kent Dellenbusch
    I like your humor - called the insurance company.
  8. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,310
    Ventura, California
    Robert Garven
    Peter,
    Nice work, wish I had a bigger garage!!!
    Rob
  9. Dane
    Dane Formula 3
    Apr 25, 2002
    1,512
    Not what I’ve done just today, but this has been my work of late.
    1. I cleaned the carburetors and replaced idle jets (.50 to .55); thank you to Pierce Manifolds.
    2. I replaced the air filter (original and disgusting).
    3. I replaced the fuel filter.
    4. My main engine lid release cable snapped so I removed it. Thank goodness the “back-up” released the lid. I ordered a replacement. ETA is 15 March.
    5. I removed the torn rear boot storage cover and ordered a new one. ETA is also 15 March.
    6. I gapped and installed new NGK plugs.
    *New plug wires will be next.
    I am not a pro like many of you on the forum, but I am certainly trying. I could not have done any of these items without your knowledge or input on the forum. Thank you.
  10. classicalfas
    318
    Gardiner, NY
    Peter D
    Looking good Dane. I just finished cleaning, repacking, and installing new boots on the cv joints. The shafts will go in when I drop the motor in. Yesterday, I machined adapters for my newly acquired Cromodora wheels to accept the smaller Dino emblem. These are actually for the 246 or hub cap 308’s. 52mm vs 55mm. I am very pleased with the results.
  11. Kent Dellenbusch
    664
    Upland, CA
    Kent Dellenbusch
    I agree Dane, there is a lot of helpful information from these guys.------ Been there - Done that & willing to share their experiance.
    Dane likes this.
  12. Kent Dellenbusch
    664
    Upland, CA
    Kent Dellenbusch
    Looks Great!
    Dane likes this.
  13. NoGoSlow
    NoGoSlow Formula Junior
    641
    Republic of Texas
    Mark Jacks
    Looks great, Peter. If you don't mind me asking, where did you source the Dino badge wheel inserts?
  14. 308Dadoo
    308Dadoo Formula Junior
    867
    Aliso Viejo CA
    David
  15. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    867
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
    My tank did this various bodge repairs by the PO .I just bought a black alloy tank from super performance.You will be surprised the hose spouts corrode under the rubber out of sight too .Odd really as the coolant supposed to be anti corrosion stuff for the block + rad , yet the tank rusts out ! This is even with regular coolant changes correct spec etc .OEM tanks must be made of cheapo steel or something?
    308Dadoo likes this.
  16. classicalfas
    318
    Gardiner, NY
    Peter D
    NoGoSlow likes this.
  17. sherpa23
    sherpa23 F1 World Champ
    10,008
    Rocky Mountains
    Bastuna
  18. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    I just bought one too. Very happy with it apart from the cap not being straight when tightened!
    Sig www.pless.com.au/mechanics.htm
  19. Rifledriver
    37,114
    Coolant isn't doing it. The steam that corrodes the top of the tank is coolant free thanks to the distilling process. Steam is very corrosive and if you could see inside there are 1000 pits ready to leak. Cannot be fixed. Buy a new one.
    The hose nipples rust because the liquid seeps in there and stays long after the anti corrosion properties wear out.
    sherpa23 likes this.
  20. Rifledriver
    37,114
    The rear diagonal braces and lengthwise tubes to the rear frame header are a good idea. The rectangular longerons flex a lot on vigorously driven cars sometimes buckling the sheet metal usually filling in the open space. Really good area to stiffen the chassis. Its a more serious car than it looks with all the body work in place.
    Saabguy, Portofino and sherpa23 like this.
  21. sherpa23
    10,008
    Rocky Mountains
    Bastuna
    Well, much of the frame is different as it’s all done to the FIA Group 4 homologation spec (this car has all the FIA Group 4 homologation and accompanying FIA HTP).
    As a result, it’s pretty impressive to drive.
    Biggest issue now is sorting out the mixture and the timing and such. As soon as I get that to a good place, I’ll change spark plugs again to the good NGK ones and carry on.
    lm2504me likes this.
  22. sherpa23
    10,008
    Rocky Mountains
    Bastuna
    Took it out this morning on a test run. It runs STRONG at the current set up. Of course not as fast my 360 or F40 obviously but definitely faster than my old 348 Challenge. It feels like it’s in 355 territory at 275hp and 950kg.
  23. Rifledriver
    37,114
    Your guys installed the steering wheel on the wrong side.
    Paint sure is shiny.
    Saabguy likes this.
  24. Rifledriver
    37,114
    My pistons look kind of like your except for the part on top. My rods are way different though. Yours are on top. Who made them?
    robertcope and sherpa23 like this.
