What have you done to your Ferrari Today? | Page 132 | FerrariChat
Discussion in '308/328' started by SteveGTB, Feb 5, 2014.
  1. bl10
    bl10 Formula Junior
    Jun 8, 2011
    442
    Chatsworth, CA
    Barry Leavengood
    Ken
    I see you are in Upland. We are in Chatsworth which made for a long drive on Sunday, about 200 miles, but it was worth every foot. We caravanned with Riley in the rain to the initial meeting point in Tustin. Turned out to be a beautiful day with I believe 15 308s and 1 328. More pics on 308 Facebook group. https://www.facebook.com/groups/439290343892406/
    Kent Dellenbusch likes this.
  2. Kent Dellenbusch
    Kent Dellenbusch Formula Junior
    664
    Upland, CA
    Kent Dellenbusch
    Yes, Upland. I see you have removed your wipers. I was thinking of doing the same. But what to put over the wiper control pegs? Something that looks factory and can easily be removed so I can put my wipers back on should it rain.
  3. bl10
    bl10 Formula Junior
    Jun 8, 2011
    442
    Chatsworth, CA
    Barry Leavengood
    Yep. I had to put them on last Sunday for the Dana point run. Probably the first time in 25 years. (car sat from 94 till 2020). Since the wipers are original 78 you can imagine how they worked. Never found any type cover for wiper pegs.
  4. Kent Dellenbusch
    664
    Upland, CA
    Kent Dellenbusch
    I am going to take mine off in the near future and I'm sure I'll come up with something to cover them to make them look factory. I will keep you posted. What color is your car technically called? I don't see many of them. It looks great.
  5. SMS
    SMS F1 Veteran
    Jan 7, 2004
    6,775
    Indy
    Bill S.
    peterp, Harry-SZ, JuLiTrO and 4 others like this.
  6. lm2504me
    lm2504me Formula 3
    1,122
    Nipomo, CA
    Richard
    My clutch was releasing way at the top of travel, like an "ON" / "OFF" switch.
    So, I followed the guidance on the Birdman Service Procedure to adjust for the 2-3 mm throwout bearing clearance and now I have the 15 - 20mm clutch pedal play until the throwout bearing presses on the pressure plate.
    All is good.
    JuLiTrO, SMS, Dane and 1 other person like this.
  7. Dane
    Dane Formula 3
    Apr 25, 2002
    1,512
    It’s a bit embarrassing, but a leak from the transfer case has developed. I admit that I didn’t replace the copper washers during a recent oil change…shame…I’ll change to the seemingly accepted here Red Line MTL. I removed all four wheels for a quick cleaning. I drank a beer…ok two.
  8. Kent Dellenbusch
    664
    Upland, CA
    Kent Dellenbusch
    I wouldn't be embarrassed. You're doing it yourself. Hats off to you. Your project is above my pay-grade. :)
    Dane likes this.
  9. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
  10. piezo
    piezo Formula 3
    May 27, 2011
    1,533
    Hong Kong
    Steven
    colorfull, Harry-SZ, kiwiokie and 5 others like this.
  11. Kent Dellenbusch
    664
    Upland, CA
    Kent Dellenbusch
  12. DAC
    DAC Formula Junior
    256
    Regina Canada
    Replacing the running light lens. Follows another Fchat suggestion of heating to 275 F for 15 minutes and the lens came out easy!
    peterp likes this.
  13. DAC
    DAC Formula Junior
    256
    Regina Canada
  14. DAC
    DAC Formula Junior
    256
    Regina Canada
  15. Kent Dellenbusch
    664
    Upland, CA
    Kent Dellenbusch
    With the old cloudy lenses, soak them in hydrogen peroxide. You will have to empty about 3-4 bottles depending upon the tray/dish you soak them in. Also, soak them in direct sunlight all day. This also works for plastic parts that were once white and have turned yellowish off-white.
    Fitz and peterp like this.
  16. DAC
    DAC Formula Junior
    256
    Regina Canada
  17. chasjen
    chasjen Karting
    81
    Dublin, Ohio
    Charlie
    Replaced the front main seal this weekend. Not very sexy but less oil on the floor!
    Dane and absostone like this.
  18. SMS
    SMS F1 Veteran
    Jan 7, 2004
    6,775
    Indy
    Bill S.
    Grrrrrrr. PSA don’t use excessive gasket sealer everywhere on cam cover gaskets unless you want the next guy to spend 10 hours scraping and cleaning.
  19. Dane
    Dane Formula 3
    Apr 25, 2002
    1,512
    #3294 Dane, Feb 28, 2023
    Two days belated.
    1. Changed gearbox/oil to Red Line MTL. That oil is gold. Smooth.
    2. I’ve burnt two fuel pump fuses in less than a week. Carrying spares kept me going; a year ago, I would’ve been stranded. I’m not trained nor am I anywhere near the likes of a Steve Magnussen, Brian Crall or Tom Yang. I’m just learning as I go.
    3. A cleaning of battery terminals and/or adjustment of the cables seemed to fix the problem. Whether I’m correct, I really have no clue, but I haven’t had a problem since.
    4. Some OCD torquing of the drain plugs and pan nuts has helped with leaking, but I’m still seeing a leak out of the passenger side engine mount spacer; removal of those studs and resealing those threads will be next. Again, I’m learning as I go.
    5. I cleaned the wheel wells, again, and I inspected belts.
    6. I went to a car show on Sunday, but I turned around immediately once I saw parking. The OCD in me just couldn’t let her sit and bake in the direct sunlight. Strange. Probably.
    4.45 a.m. post. Hope I made some semblance of sense. Off to work I go.
    peterp, miketuason and waymar like this.
  20. SMS
    SMS F1 Veteran
    Jan 7, 2004
    6,775
    Indy
    Bill S.
    troubledz, JTT, colorfull and 4 others like this.
  21. troubledz
    troubledz Karting
    Jan 29, 2021
    74
    Toronto,Ontario
    DINO LAMANNA
  22. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,685
    NJ
    Peter
    troubledz and SMS like this.
  23. bl10
    bl10 Formula Junior
    Jun 8, 2011
    442
    Chatsworth, CA
    Barry Leavengood
    SMS: Wondering about the air box. Are you using some kind of power adder like turbo or supercharger? If so is there a thread?
  24. SMS
    SMS F1 Veteran
    Jan 7, 2004
    6,775
    Indy
    Bill S.
    Barry,
    Yes, its a supercharger application. Using a Powerdyne centrifugal unit making 6 psi boost, so its relatively conservative but makes it pretty fast. Has forged pistons, ss valves, balanced and has reground cams. Using member Mk e's desktop dyno we figure it to be making around 350-360hp.
    peterp likes this.
  25. classicalfas
    classicalfas Formula Junior
    318
    Gardiner, NY
    Peter D
    SMS likes this.
