What have you done to your Ferrari Today? | Page 137 | FerrariChat
Discussion in '308/328' started by SteveGTB, Feb 5, 2014.
  1. Milkshaker0007
    Milkshaker0007 Formula Junior
    Sep 22, 2012
    432
    Midlands,uk
    Paul
    I use 75 80w. Been using last 11 years zero issues. Personal choice others will have / disagree
    Lots and lots of oil recommendations thread, have fun searching:))
  2. Milkshaker0007
    Sep 22, 2012
    432
    Midlands,uk
    Paul
    I just find it easier for gravity to send the oil down into the filler hole on the transmission than to pump it in. there a many different other ways as well
    Dane likes this.
  3. classicalfas
    classicalfas Formula Junior Silver Subscribed
    Dec 5, 2012
    318
    Gardiner, NY
    Peter D
    Portofino, Dane and 4right like this.
  4. classicalfas
    Dec 5, 2012
    318
    Gardiner, NY
    Peter D
  5. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    Worked on my new to me 328 GTS.
    The mirrors were not working correctly.
    So I checked the wiring schematic and checked if all was as it should.
    Decided to open the switch study it, clean, regrease with dielectric grease and reassemble it.
    Back in place they now work as they should.
    Also reajusted my steering height, and recentered it.
    My driver door didn't fit to my standards so I also did that. Now much more to my liking.
    SMS likes this.
  6. Dane
    Dane Formula 3 Owner
    Apr 25, 2002
    1,512
    I had an easy departure from my normal amateur struggles….I cleaned these air filters with simple soap and water; air dried and reinstalled.
    Yes, I have the original airbox…These just make carb work and tuning so much easier!
    I also replaced the four year old Duralast battery.
    TheMayor likes this.
  7. Anthony Rapuano
    Anthony Rapuano Karting
    Aug 16, 2022
    211
    CT
    Anthony V Rapuano, Jr.
    Hi Dane
    I think the individual air cleaners look neat, and would certainly agree that they make carb work much less of a pain. The downside, as I'm sure you're aware, is that you lose some of the ram effect of the side air intake and standard air box. Additionally, the carbs are ingesting hot engine compartment air (though somewhat mitigated by the continued inflow of outside air through the side intake) which probably doesn't help performance. I also see that your choke linkage is still in place. As has been discussed on the forum multiple times, it seems the consensus is that a number of owners of carbureted 308's disable the choke by disconnecting the main choke cable and/or removing the choke linkage rods between carburetors, thus avoiding the possibility of a sticking choke impairing performance. Also, what did you replace the Duralast battery with? Four years of service for a battery seems short to me.
  8. bitsobrits
    bitsobrits Formula Junior Rossa Subscribed Silver Subscribed
    Nov 12, 2011
    740
    Omaha, NE area, US
    Steve
    Surely you jest. Ram air effect at speeds below triple digits would be all but imperceptible. Cool (or even just stable temp) air intake? That's a real benefit.
  9. Anthony Rapuano
    Aug 16, 2022
    211
    CT
    Have you noticed any perceptible change in performance with the individual air cleaners versus the stock airbox, assuming you had driven the car for a time with the stock intake setup in place prior to the individual air cleaners? I am serious about some degree of ram effect with the stock airbox in place, given that at speed outside air is being forced into the confines of the airbox which should, theoretically, increase the air pressure in the box and force more induction. At slow speeds (?) I'm sure it is a negligible effect, but at highway speeds and above I have to think there is some benefit.
  10. bitsobrits
    Nov 12, 2011
    740
    Omaha, NE area, US
    Steve
    Much has been written on this subject, so I would suggest some reading. Generally speaking, there will be a negligible impact on pressure until you are considerably above legal speeds. Most reported testing on 'ram air' systems shows a 1-3% power increase at speeds above 100mph, but there is some debate about how much of that comes from 'cold' air, and how much from the pressure increase as ram air systems almost always provide unheated intake air. Also note the air intake path needs to completely sealed to maximize any ram effect. And with a carbureted car, forcing more air into the engine will tend to lean out the fuel mixture, so if you don't jet for it there is no gain. Also, what evidence do we have that factory air intake is properly placed on the body to maximize any ram effect?
    I would summarize my view by saying that the factory setup is pretty darn good for a stock engine, mostly because cooler outside air is better than engine compartment air. But many people run the individual air cleaners with no apparent ill effects. Additionally, I would conjecture, but haven't tested it, that the individual air cleaners may produce a measurable power increase in the upper rpm ranges due to the larger available plenum area (engine bay vs airbox).
  11. Anthony Rapuano
    Aug 16, 2022
    211
    CT
    That's great info. Thank you. The reading I have done, granted, mostly pertains to the "hot rodding" of American muscle cars, i.e., front engined with ducted air intakes in the grill, leading edge of the hood, or via hood scoop. These were largely closed systems, and my guess would be that the intake's orientation directly into the airstream would provide a more obvious effect than a side mounted intake. It would be interesting to see if there were ever any engineering studies done specifically of the 308 side intakes. I'm sure their placement was driven as much my aesthetics as anything else. My understanding also is that the carbureted cars tended to be jetted/tuned somewhat on the rich side and would therefore tend not to lean out at higher speeds.
  12. ClydeM
    ClydeM F1 World Champ Owner Rossa Subscribed
    Nov 4, 2003
    11,889
    Wayne, NJ
    Clyde E. McMurdy
    Got a new house, with only a one car under-house garage. HOWEVER, there are two slots 90 degrees off the main slot way big enough for 2 more cars.
    But how to turn the car in the garage for the slot without lots of aggravation and forward/reverse gear?
    Well, I'm no big fan of Harbor freight, but Father's day they put these on sale for $100 each.
    I read several reviews and testimonials, I bought 'em
    one under each wheel, jack it up, push the car from the main slot to a perpendicular slot.
    It's not like pushing a shopping cart. I had to lean into the car. But it works! One person.
    These wouldn't be bad at all for a small mechanic shop. You can push it in any direction.
    now the car is out of the way and in a great spot to work on & wax. I'll use these to put
    another in the spot next to it.
    peterp and waymar like this.
  13. rjlloyd
    rjlloyd Formula Junior
    Jun 19, 2014
    447
    Brisbane, Australia
    Richard Lloyd
    imahorse, Dinzo22, piezo and 5 others like this.
  14. Milkshaker0007
    Sep 22, 2012
    432
    Midlands,uk
    Paul
    Finally had time to replace the cam belts and hills tensioners + auxiliary belts.
    Old belts were in good condition, no cracks at all, old hills tensioner bearing where running smooth still just a slight grease weep on both
    If it wasn’t for that air conditioner pump it would be so much easier, I think it got 10 kg heavier from last time I did it, or I’m getting older :)
  15. Enzo Anselmo Ferrari
    Enzo Anselmo Ferrari Formula Junior
    Apr 4, 2009
    903
    France
    Dinzo22, Rosey, TheMayor and 3 others like this.
  16. Arizona30
    Arizona30 Karting
    Aug 23, 2018
    53
    Kevin
    I wish I had enough courage to change my timing belts.
  17. Kent Dellenbusch
    Kent Dellenbusch Formula Junior Silver Subscribed
    Oct 7, 2008
    664
    Upland, CA
    Kent Dellenbusch
    I'm with you on the courage part. I'm extremely comfortable with detailing, and body correction but not mechanical. I just leave that to the guys who have invested time and tools to do the job correctly. I do ask questions because I like to learn. I've got a fantastic mechanic in the LA area. Eric Sanders at GTO Engineering.
    Arizona30 likes this.
  18. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    MTL for newer gearboxes but if a little wear then choose the NS
    Both very high quality
  19. newark_308
    newark_308 Karting Silver Subscribed
    Jul 28, 2004
    213
    Newark DE
    Glenn Frenck
  20. Kent Dellenbusch
    Oct 7, 2008
    664
    Upland, CA
    Kent Dellenbusch
    They look great.
    Is that a fire suppression stick to the left of your driver's seat? Good idea.
  21. newark_308
    Jul 28, 2004
    213
    Newark DE
    Glenn Frenck
    Element fire extinguisher
    Sent from my SM-S918U using FerrariChat.com mobile app
    Kent Dellenbusch likes this.
  22. Kent Dellenbusch
    Oct 7, 2008
    664
    Upland, CA
    Kent Dellenbusch
    Thanks. I should get one or two.
  23. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    They look fantastic…. What is the source for the covers?
  24. MFlanagan
    MFlanagan Karting
    Dec 21, 2016
    159
    https://elementfire.com/
    I think they're the best fire extinguishers for cars that are being prouced. We have one in each of our cars and each of our garages.
    newark_308 likes this.
  25. Ferraridoc
    Ferraridoc F1 World Champ Owner Silver Subscribed
    Jun 20, 2012
    17,218
    Gold Coast, Aust.
    Patrick
