What have you done to your Ferrari Today? | Page 142 | FerrariChat
Discussion in '308/328' started by SteveGTB, Feb 5, 2014.
  1. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    746
    Omaha, NE area, US
    Steve
    When doing mine, I found the use of a 2" long 1/2" drive extension allowed me just the right amount of reach to loosen/tighten the socket head bolts. For the hex bit, I was using a 1/2" drive impact bit which is about 3" long.
    Or put another way, to enable using my breaker bar/ratchet/torque wrench placed between the inner part of the control arm and the outer part of the chassis rail (for the inner bolts), I inserted my hex bit into one of the socket heads then measured for the required extension to make it work. Then Amazon is your friend.
    Milkshaker0007 and PAP 348 like this.
  2. Milkshaker0007
    Milkshaker0007 Formula Junior
    Sep 22, 2012
    432
    Midlands,uk
    Paul
    thanks for the helpful tips, my shoulder is totally knackered, awaiting surgery so will try my best, may have to borrow an impact gun off a friend if it can get in with limited space on the outer wheel side. With a long extension the inner CV section will be the easiest ,Cheers
  3. bobbybrown13
    bobbybrown13 Rookie
    Dec 27, 2019
    5
    california
    bobby brown
    Just dropped off my new purchase ferrari 328 GTS to Donnie Callaway out in the Mojave desert. It will need almost everything but the start of it
  4. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
  5. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
    Wow you did?
    Jbrauer likes this.
  6. E-Dino
    E-Dino Formula Junior
    Aug 11, 2012
    378
    San Diego
    Hillbilly hockey stick cam lockers worked well. New belts, tensioners and all new rubber that touches gasoline. 4 rebuilt Webers AND I finally fixed the distributor oil leaks. Now it is time to change coolant and tune the carbs for a good idle. Looking forward to cool weather driving.
    Schulz308, Frisky and colorfull like this.
  7. miketuason
    Feb 24, 2006
    15,811
    Cerritos, CA.
  8. TheMayor
    106,181
    Vegas baby
    Got mine back yesterday after months in the shop. 30 degrees this morning and took it out for breakfast. Hopefully it will warm up a little and I can drive it with the top off soon.
    Zenobie and Frisky like this.
  9. Frisky
    Frisky Karting
    Apr 26, 2014
    230
    MA
    Rolfe Lofmark
    we are waiting for your first go pro drive with commentary.
    Zenobie and TheMayor like this.
  10. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    Took it out for some exercise but quickly discovered brine had been sprayed on the roads. Snow is anticipated. Returned home.
  11. sack
    sack Rookie
    Nov 6, 2023
    26
    Germany
    Marc
    peterp, Nino1964, Zenobie and 3 others like this.
  12. Frisky
    Frisky Karting
    Apr 26, 2014
    230
    MA
    Rolfe Lofmark
    Do you have the before picture?
    It looks great.
    What did you do and who did the restoration?
    Cost?
    ragtop1 likes this.
  13. sack
    sack Rookie
    Nov 6, 2023
    26
    Germany
    Marc
    I did it by myself, only a couple of hours work and two cycles of drying overnight. Sorry no before-picture. It looked worn with brighter areas but not that bad.
    Mostly I used the items of this package plus fluid leather for deeper scratches and straightening of the frayed areas towards the aluminum. They have lots of videos and howtos on their site, unfortunately only in German. But I guess there are similar suppliers elsewhere, too.
    Frisky likes this.
  14. Frisky
    Frisky Karting
    Apr 26, 2014
    230
    MA
    Rolfe Lofmark
    what did you to tomsorice up the aluminum?
  15. sack
    sack Rookie
    Nov 6, 2023
    26
    Germany
    Marc
    the aluminum looked quite good as it was, no scratches. I just cleaned it using cleaning solvent.
    Frisky likes this.
  16. kerrari
    kerrari Two Time F1 World Champ
    Oct 22, 2004
    24,033
    Coolum Beach AUSTRALIA
    Karen H.
    Parked in the rain waiting for tow truck BACK to auto electrician... not happy but it DOES look pretty in the rain with the rain beading on refurbed paint :cool:
    Aus_yz, subnet67 and ragtop1 like this.
  17. bl10
    bl10 Formula Junior
    Jun 8, 2011
    442
    Chatsworth, CA
    Barry Leavengood
    Had the alternator rebuilt after gen light started coming on. Actually it was under warranty as I had it rebuilt last Apr. Turned out to a bit of a frustration as the rebuilt unit wouldn't charge. Took it back and they messed with it and said it's A ok. I witnessed them test it a 14+ volts and 65 + amps. Soooooo I reinstalled it and still no charging. Off again and checked it on the bench using a 2500 rpm impact driver to turn it. Checked out fine. Reinstalled it decided it must be the ignitor circuit. Ran 12 volts to the ignitor post and it charged. Let it run a while, the battery was at 11.6 volts by now, then hooked up the stock ignitor circuit and it works fine. I have no idea why. Along the way I built a tool out of a turnbuckle to tighten the alt belt. and Installed new rubber molding on the wheel wells. Next on the agenda is the speedo sending unit. It's been sketchy for a while but now only works once in a while. Oh yeah I also replaced a couple of stripped wheel well fastners.
  18. ragtop1
    ragtop1 F1 Veteran
    5,242
    Ontario
    Larry Warren
    I had the same issue with my alternator. There's a cable that runs from the alternator to the starter. The connection to the starter failed. I just had to replace the copper eyelet connector at the starter terminal. I'm now getting the proper voltage to the battery.
  19. bl10
    bl10 Formula Junior
    Jun 8, 2011
    442
    Chatsworth, CA
    Barry Leavengood
    The cables were OK. At least I didn't change either one. The Gen light wire goes to the D+ post on the alt and is supposed to excite it so it will charge. Its kind of a strange setup as when you ground the D+ wire the Gen light comes on and when its hooked up to the alt the gen light comes on when the key is in run. So all is as its supposed to be except it didn't charge. Don't know why it started working OK.
    Barry
    ragtop1 likes this.
  20. Zenobie
    Zenobie Formula Junior
    Feb 22, 2021
    251
    Belgium
    CO
    I found it annoying to always have to look for the seat belt buckle once I was in the car. Solved by placing a button made for this purpose on and through the belt. Small job of less than 1 minute per belt
  21. Frisky
    Frisky Karting
    Apr 26, 2014
    230
    MA
    Rolfe Lofmark
    Picture please
  22. Zenobie
    Feb 22, 2021
    251
    Belgium
    CO
  23. Frisky
    Frisky Karting
    Apr 26, 2014
    230
    MA
    Rolfe Lofmark
    Nice, it doesn’t clang around while
    Driving?
  24. Zenobie
    Feb 22, 2021
    251
    Belgium
    CO
    No, and usually there are two of us in the car and we wear the seat belts
  25. SPD360
    SPD360 Rookie
    Oct 3, 2023
    5
    Brisbane
    Was
    Hey mate, I'm glad I've come across this post. I've been trying to get just a quote from Nick for the last 3 months and still nothing. I purchased my 360 with a red wrap. Removed the wrap and had paint damage. I will give Dave a try.
    Rosey and rjlloyd like this.
