What have you done to your Ferrari Today? | Page 148 | FerrariChat
Discussion in '308/328' started by SteveGTB, Feb 5, 2014.
  1. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    214
    Boerne, TX
    Rodney Bolt
    What sized lines? #6 and #8?
  2. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,221
    CT
    John Kreskovsky
    New tires and center caps. I bought the center caps years ago knowing I'd need them some day. They are an exact match to the OE.
    Tires from Tire Rack. I can not recommend too highly their mobile installers. I've used them twice. They take pictures of all the wheels before and after mounting. Very careful. They ask questions about lifting the car. Mount and balance for $160, at you home. Their machines don't grip the wheels with spikes so no paint damage to the inner side of the rims. Even asked how I wanted the wheel caps positioned. No sitting waiting at a shop for your turn and you can be right there with them.
    LE06, stoked_7 and miketuason like this.
  3. pappy.72
    pappy.72 Formula Junior
    Nov 13, 2010
    536
    Elgin, IL
    Dave
    Finally got around to installing the SRI fuel hose set on my 89. The old hoses had date codes of 1988 on them. They had zero dry rot or cracks in them even when cut open and stretched open. Surprising they looked that good. Either way I’m glad to have them updated. Job took around 4 hours with clean up and checking for leaks.
  4. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    845
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
    Replaced the ancillary belts as the AC broke on a rally and threw off the alternator belt .
    I suspect the York AC pump got very hot , after 8 hrs running and melted its belt ? Or it wasn’t tensioned enough and started to slip ?
    Last done 2021 .
    In future I need to check the tension annually .
    I opened the lub nut and oil / gas hissed out - that’s the green stain = seems to hold pressure .
    Tricky part is the AC belt .You have to remove the lower bracket + tensioner .The AC studs I double nutted and unscrewed them to get the bracket off .Then you have to manoeuvre the new belt in .It’s too tight as is .So you have to loosen off the top three bolts on the upper bracket ( no pic s sorry ) , this drops the pump enough so you can slip the belt on the clutch .
    You have to do the clutch end last after the other end because at the other end the crank , it fits on the inner of the two pulleys. So you put the crank end first then second the clutch = Argh !!!
    Once on tighten up the upper bracket loosely and while there’s still a little movement re fit the lower bracket refitting ( double nutting ) the pump studs .Once they are home button up both brackets .
    Refit the tensioner and get is as tight by hand as you can .Various threads on belt tension on here I read them all
    The alternator/ water pump is a doddle in comparison, just a regular alternator belt procedure I used a pry bar to tIghten .
    Both bolts are a bit tricky but none the less do able.
    Various test runs and checking for interference etc all seems ok .Thankfully the AC clutch isn’t fried and it blows cold in the cabin .
    I regassed the system in April using a generic r134 rattle can kit as it had leaked ( or I suspected) a little out over the winter .
    Then added a bit more the day before the rally .Suspect i over pressured it and strained the pump ?
    The friction heat transferred to the clutch pulley which intern melted the belt .
    Bits of shredded AC belt then got caught up the alternator belt .It didn’t snap just jumped off and the generator light appeared on the dash .
    Was thinking if the AC pump or clutch was knackered I would replace with this .
    https://gtcp.com/product/115776rrk-a-c-compressor-retrofit-kit-with-brackets/. $1200 + @$150 to ship to the U.K.
    But the system seems to hold pressure and work pretty ok .It was my bad over filling it and running it for 8 hrs solid.
    The black rubber pipes were replaced by the PO so are r134 compatible.
    All I would say the belts are pretty expensive compared to regular belts .Approx £65 each inc tax from Superperformance.
    I wish there was a aftermarket,modern flat ribbed ,poly belt conversation kit , pulleys etc like modern cars available .
    The OEM V belts feels tiny and delicate .
    JuLiTrO, FrisianDino and Michael DB like this.
  5. LE06
    LE06 Karting
    227
    Lee
    Took my 308 to a C&C on Saturday. It was about a 40min drive each way on the highway. The car ran like a top. This is the longest outing I have had it on and am very pleased. I have the idle set to low and even though it ran good it does have a flat spot. I am sure this winter I will have to rebuild the carburetors. But for now I will just enjoy the car.
    miketuason likes this.
  6. mixedgas
    mixedgas Formula Junior
    267
    Ramona, CA
    Sizes are 8 and 10 (13/32 and 1/2, respectively)
    rwbolt1 likes this.
  7. Imatk
    Imatk Formula Junior
    May 6, 2007
    768
    Dino246gt, 66MK, bertrand328 and 4 others like this.
  8. mixedgas
    267
    Ramona, CA
    Replacing clutch, throttle, and e-brake cables as preventative maintenance since my seats and center console are out. Also did the differential seals.
    LE06 likes this.
  9. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    In the last few days I did the timing belts and tensionner bearings. Also oil change and filter and new Redline NS transmission oil. All that for the new owner. Monday I should bring the car to TFX in Toronto to get it delivered to the new owner in Wasnington state. From east to west coast. I will sure miss her.
  10. AndyU1
    AndyU1 Rookie
    47
    Andy
    66MK, PAP 348 and LE06 like this.
  11. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    I started mine for the first time in 6 months.
    After I charged the battery for 12hrs the day before.
    :oops::oops:
  12. godabitibi
    Jan 11, 2012
    6,329
    Claude Laforest
    Why so long ?
    PAP 348 likes this.
  13. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Too busy/lazy.
    Car is currently in the carport out front, I walk past it every day lol
    Will try and start it and drive it more often.
    I haven't driven it since last November.
    Working 7 days a week these days, no time for anything but work and sleep.
    LE06 likes this.
  14. godabitibi
    Jan 11, 2012
    6,329
    Claude Laforest
    Man take time to live a bit. Work is not all in life. Life is short.
    Dino246gt likes this.
  15. Plutonium
    Plutonium Karting
    Jul 29, 2020
    97
    1980 308 GTSi
    kiwiokie, LE06 and Zenobie like this.
  16. kerrari
    kerrari Two Time F1 World Champ
    Oct 22, 2004
    24,033
    Coolum Beach AUSTRALIA
    Karen H.
    Got to drive it properly for the first time this year...been shuttling between body shop, mechanic and auto electrics. Part of the problem was a faulty battery installed by local shop. :confused:
    Enjoyed a nice 130km round trip even though it was only on the boring highway.
  17. mixedgas
    267
    Ramona, CA
  18. Imatk
    May 6, 2007
    768
    Make sure you check both sides of that crimp. I had the same (or very similar) tool and I had to crimp it once, then rotate 180 degrees and crimp it again since it didn't seem to do it equally
    mixedgas likes this.
  19. Enzo Anselmo Ferrari
    Enzo Anselmo Ferrari Formula Junior
    Apr 4, 2009
    903
    France
    Zenobie, Imatk, 4right and 2 others like this.
  20. Imatk
    May 6, 2007
    768
  21. newark_308
    newark_308 Karting
    213
    Newark DE
    Glenn Frenck
    Disconnected the radio that a PO installed since I've only used it at best twice since I bought the car. In theory, it eliminates parasitic draw on the battery. Now I find I don't have any turn signals today. Guess I'm plugging it back in tonight [emoji849]
    Sent from my SM-S918U using FerrariChat.com mobile app
  22. mxstav@comcast.net
    Nov 24, 2005
    211
    Green Oaks, IL
    Mark Stavropoulos
    I fixed my gas tank fuel sender. The gauge always measured empty. After verifying all the electrical components were working, I discovered the float was a sinker. The brass float developed a leak. It turns out this part on Amazon is a direct, drop-in replacement. It works fine now.
    Rosey, Imatk, Zenobie and 3 others like this.
  23. Imatk
    May 6, 2007
    768
    Got the hood on today. I'm waiting on a tie-rod end and then this car is finally ready to be driven.
    It only took 4 years and one month almost to the day. I guess now I can just drink beer on the weekends and stare at it LOL
    peterp, Zenobie, rwbolt1 and 2 others like this.
  24. Hellenmarc
    Hellenmarc Rookie
    12
    Hellen Marc
    I plan to replace the throttle cable today...but, I also backed my DD out from under it. Stuck on the lift for the foreseeable future as well due to crappy weather! Last week I took it to the body shop for rust repair, I love my car!
