What have you done to your Ferrari Today? | Page 150 | FerrariChat
Discussion in '308/328' started by SteveGTB, Feb 5, 2014.
  1. LE06
    LE06 Karting
    227
    Lee
    miketuason, TheMayor, Zenobie and 2 others like this.
  2. 48969
    48969 Karting
    Jun 27, 2020
    108
    Chicago, Illinois
    J. Michael Collins
    Replaced the radiator fans on my 84 308. Bought billet aluminum mounts on eBay which pair with Spal 3010.0320 fans. To install I had to remove the front valance and shim the mounts. I used 3/8” vinyl tubing. Wiring was plug and play. The fans move more air and work great. Nice improvement.
    Frisky, TheMayor, LE06 and 2 others like this.
  3. ZikZak
    ZikZak Karting
    Dec 18, 2023
    170
    Vancouver/Los Angeles/Miami
    Dickie Maxwell
    That looks great, and I bet a big improvement. Do you have a link for the eBay mounts?
  4. 48969
    48969 Karting
    Jun 27, 2020
    108
    Chicago, Illinois
    J. Michael Collins
    ZikZak likes this.
  5. ZikZak
    ZikZak Karting
    Dec 18, 2023
    170
    Dickie Maxwell
    #3730 ZikZak, Sep 25, 2024
    The package says its for the GT4, but may work on the 308 GTS/B - is that the one you purchased? It looks very good - it sounds as if the guy put a lot of effort into designing it.
  6. 48969
    48969 Karting
    Jun 27, 2020
    108
    Chicago, Illinois
    J. Michael Collins
    Same package. I think you can install on the GT4 by removing the grill. I had to remove the valance too, but the fans fit nicely.
    ZikZak likes this.
  7. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    740
    Omaha, NE area, US
    Steve
    I bought the fan/bracket kit from the same seller, and they fit and work well. They move way more air than my tired originals. Did need to shim up the motor to bracket interface with rubber strips.
    48969 and ZikZak like this.
  8. Michael DB
    Michael DB Karting
    Dec 22, 2023
    231
    Michael D Beswick
    I dried my 308 GTBQV out- dehumidifier been in for 2 days......and tried to sort out the direction indicators-(Looks like the hazard switch)!
  9. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    214
    Boerne, TX
    Rodney Bolt
    Replaced interior incandescent bulbs to LEDs. A simple 30min upgrade. Way brighter, zero heat and much less current draw on the electrical (about 1/10th). Next up, the dash gauge bulbs. I'm not looking forward to that.
    or those interested, here are the bulbs I used (all from Amazon). (FYI... These are for a 89 328.)
    Door lights: 194 - (x2) White, 6000k, Auxito brand
    Overhead map light: 578 - (x1) White, 6000k, 39-42mm festoon, Auxito brand
    Door jams: BA9S - (x2) Red, Yoper brand
    bertrand328, Frisky, TheMayor and 2 others like this.
  10. PT 328
    PT 328 F1 Rookie
    4,004
    Got new tires.
  11. LE06
    LE06 Karting
    227
    Lee
    #3736 LE06, Sep 30, 2024
    I changed the oil pressure sending unit. Well kind of, most of the way. I got the old one off no problem and the new one on with the help of the wrench I cut up. But it is leaking just a little. It needs about a quarter turn more but my special tool won’t get it. So tomorrow it’s off th Harbor Freight. They have a wrench with a little better bend.
    I know I can take the whole unit off and it would be easy. But why would I do that when I can spend an hour cutting up a tool to make it half way work then go to harbor freight?
    work harder not smarter
  12. LE06
    LE06 Karting
    227
    Lee
    With an assortment of special tools I got the oil pressure sending unit good and tight.
    You can take the boy out of the Fiat but you can’t take the Fiat out of the boy!:D
    next up the heater hose that comes off the back of the head is weeping. So I need to replace it before this weekend. If I can find the other end.
    Zenobie and rwbolt1 like this.
  13. bertrand328
    bertrand328 Formula 3
    Jun 1, 2015
    1,620
    France
    Bertrand
  14. bertrand328
    Jun 1, 2015
    1,620
    France
    Bertrand
    Good idea but how remove the overhead map light please ? I don't understand how to do ...
  15. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    214
    Boerne, TX
    Rodney Bolt
    Very carefully. Insert a flathead into the small slot on the left side (opposite the switch). DO NOT TWIST. Push the screwdriver in about 1/4"-1/2" to compress a tension spring. While pushing in with one hand, use your free hand to pull down on the same left side to remove the entire light assembly. Again, do not twist the screwdriver or you will crack the lens.
    Arizona30 and bertrand328 like this.
  16. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,808
    Cerritos, CA.
    I helped a friend open his rear deck lid without breaking any lenses with the cable undone on one side
  17. KTinCHS
    KTinCHS Rookie
    15
    Charleston SC
    Kent Tucker
  18. RodC328gts
    RodC328gts Formula Junior
    Aug 17, 2021
    458
    Mexico
    Rod C
  19. LostAussie
    LostAussie Formula Junior
    Jun 13, 2013
    719
    Piemonte
    Stuart
    RodC328gts likes this.
  20. KTinCHS
    KTinCHS Rookie
    15
    Charleston SC
    Kent Tucker
    The "towers" you inquired about are the the 4 posts of my "Backyard Buddy" 4 post lift. I've only had the lift about 2 weeks, actually waited to take on this project until the lift was in place. I had a pair of Quick Jacks prior to this lift, and while they would lift the car about 20" off the floor, I never felt comfortable working under the car. I can't say enough of about how great this lift is. I'm currently restoring my father-inlaws, original owner, 73' camaro and this lift not only allows me to do most anything I need to do on that project, and when I'm not activly working on either car, I can store them one over the other. Again, I cant say enough about the quality and convenience of this lift.
  21. RodC328gts
    Aug 17, 2021
    458
    Mexico
    Rod C
    Yes, I meant the axle stands, thank you. I thought it was an accessory on the lift.
    Thanks. From the picture, I thought it was an accessory included on the lift, something like a jack. Now, thanks to Lost Aussie post, I see those are axle stands.
    I do own a 4 post lift, and it's amazing as you said. I've considered buying a couple of rolling bridge jacks, to be able to do brakes and similar.... pricey!
  22. JuLiTrO
    JuLiTrO Formula Junior
    Nov 2, 2017
    393
    Julio Saiz
    I spent 10 hours shooting this nice video. Hope you like it! Actually all the merit is for the maker, such a talented guy
    rmlovett1, peterp, Michael DB and 7 others like this.
  23. ZikZak
    ZikZak Karting
    Dec 18, 2023
    170
    Dickie Maxwell
    The was great!
    JuLiTrO likes this.
  24. Zenobie
    Zenobie Formula Junior
    Feb 22, 2021
    251
    Belgium
    CO
    Last week I had a new zipper installed in the back cover and the cover was replaced. Also finalized the reversing camera and installed a new automatic antenna + made it work directly on the on and off radio.
    rwbolt1 likes this.
  25. Boaty_Tom
    Boaty_Tom Karting
    Aug 24, 2024
    55
    United Kingdom
    Tom
    An amazing video Julitro and some beautiful shots!
    NoGoSlow and JuLiTrO like this.
