What have you done to your Ferrari Today? | Page 151 | FerrariChat
Discussion in '308/328' started by SteveGTB, Feb 5, 2014.
  1. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    218
    Boerne, TX
    Rodney Bolt
    What reverse camera solution did you come up with? How is it powered?
  2. Zenobie
    Zenobie Formula Junior
    Feb 22, 2021
    251
    Belgium
    CO
    The camera is powered by the reversing light, the screen via cable to the fuse box power supply after ignition. That is a.o. the yellow/black cable that you see to the left of the fuse box. The hardest/most time consuming part is the cable from the camera to the screen. This runs under the windshield rubber through the side pillar, rider's side, down through the lower body sill rubber, at the rear under the back carpet and through the standard opening through the engine wall through the wheel well through the engine compartment wall/trunk to the camera.
  3. LE06
    LE06 Karting
    235
    Lee
    Excellent!
    JuLiTrO and Frisky like this.
  4. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    218
    Boerne, TX
    Rodney Bolt
    Installed a single-DIN Android-Auto / CarPlay head unit (Power Acoustik CP-71W). It also supports front and rear wired cameras. Works great. Sounds good enough for me. $140 @ Walmart. I was tired of the clumsy ugly mess of mounting my phone on the windshield and then constantly having to clean up the suction cup marks from the mount.
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,742
    The twilight zone
    I took a car/work buddy out for a ride. I know it sounds trivial but it's been some time since I could just take anyone out for a ride. Yesterday was maybe better though, I let my son drive it for the first time after his 1st real ride, just around the block but he was pretty excited. Little things sometimes mean the most.
    The TIG, PT 328, Zenobie and 3 others like this.
  6. mixedgas
    mixedgas Formula Junior
    267
    Ramona, CA
    LE06 likes this.
  7. sir_sire
    sir_sire Rookie
    Jul 19, 2022
    40
    Aachen, Germany
    Can you tell me, which lift you are using exactly? I'm looking for dimensions, as I currently plan on buying a new unit.
    Thank you
  8. LE06
    LE06 Karting
    235
    Lee
    Frisky, stoked_7, 66MK and 1 other person like this.
  9. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    Started it, got every thing up to temperature and had my last drive of the year before winter is finally here...
    timjen88 and LE06 like this.
  10. KTinCHS
    KTinCHS Rookie
    15
    Charleston SC
    Kent Tucker
    I'm using the BACKYARD BUDDY CLASSIC B-4P7CL 7000lb 4post lift
    All of the specs are on the web site.
  11. speedcat
    speedcat Karting
    Jul 26, 2011
    158
    Calgary, Canada
    Same here, there may not be too many days like this before the snow arrives. Took the roof off and turned the heat on.
    Zenobie, LE06 and 66MK like this.
  12. Sigmacars
    Sigmacars Formula 3
    1,218
    You got a antifreeze leak sweet smell
  13. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    A decade late on the response but accurate. ;-)
    ChevyDave likes this.
  14. ChevyDave
    ChevyDave Formula Junior
    Dec 21, 2019
    418
    Pacific Northwest, USA
    Dave W
    Finally decided to tackle the QV’s console “smile” and discovered my car was equipped with the rare factory Uniball Pen option… :p
    - Dave
    Zenobie likes this.
  15. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    747
    Omaha, NE area, US
    Steve
    You might want to consider an upgrade to a Montegrappa for a more authentic Italian experience.
  16. ChevyDave
    Dec 21, 2019
    418
    Dave W
    Mine’s an ‘83; I don’t believe Montegrappa became available until ‘84. ;):D
    - Dave
  17. dflett
    dflett Formula 3
    1,632
    NY
    David
    Went for the first proper drive in about 18 months. Started easily so no issue with the fuel or carbs but everything else took a while to be happy in 0 degree C temp. Everything was stiff and a bit noisy until 15 minutes into the drive. It’s always a surprise just how different my car drives straight out of the garage compared to how it drives when everything is warmed up.
    Dino246gt, Harry-SZ, The TIG and 8 others like this.
  18. 85QVEuro
    85QVEuro Formula Junior
    Jan 15, 2021
    546
    NYC
    Joe
  19. Zenobie
    Feb 22, 2021
    251
    Belgium
    CO
    Nicely cammouflated the par from par-king :)
    85QVEuro likes this.
  20. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    Changed engine oil and brake fluid today.
    miketuason and LE06 like this.
  21. bitsobrits
    Nov 12, 2011
    747
    Omaha, NE area, US
    Steve
    I earlier converted my front spare tire well to 'removable' to facilitate various maintenance jobs I've been doing on the car while trying to keep it drivable. But the frequent removal/replacement of the very nice and original early type vinyl spare tire cover with its glued front edge was an annoyance, and I was concerned about damaging it. So I whipped up an interim solution that's very quick to remove/install. Just 16 gauge aluminum with some Amazon vinyl glued over the top and a bolt-in bracket to receive the single thumbscrew. There is a 45 bend at the front that hooks over the edge of the fiberglass well.
  22. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
  23. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
    Clever idea
  24. LE06
    LE06 Karting
    235
    Lee
    Took it out for a short ride. I was amazed how nice it is running now. Got the carbs synced, no spitting and back firing. I really don't want to rebuild them, but it's an old car and it has never been done, it's time. I was very happy....till I stoped and noticed the speedo was stuck at 60. Tapping on it brought it down, guess it does not like the cold. Something els to fix over the winter.
  25. jsumnertx
    jsumnertx Karting
    Dec 9, 2004
    164
    Austin
    jferazzi, ragtop1, subnet67 and 5 others like this.
