What have you done to your Ferrari Today? | Page 155 | FerrariChat
Discussion in '308/328' started by SteveGTB, Feb 5, 2014.
  1. bball16
    bball16 F1 Rookie Rossa Subscribed
    Dec 2, 2011
    4,125
    NY LI FtL
    I installed CarPlay in my 458.
    bitsobrits and ZikZak like this.
  2. bitsobrits
    bitsobrits Formula Junior Rossa Subscribed Silver Subscribed
    Nov 12, 2011
    740
    Omaha, NE area, US
    Steve
    Where did you find such a small screen?
  3. Chez23
    Chez23 Rookie
    Apr 12, 2025
    3
    Hi sorry to jump on here but not sure how this works. Looking at a 2019 488 Spider with 11k miles- is 11k miles too many? Asking 299K. Has full PPF. MSRP was 359 so nice options. Also had the new extended warranty Ferrari added to 2019+ years this past Jan,
  4. bball16
    Dec 2, 2011
    4,125
    NY LI FtL
    That’s the factory screen. CarPlay works in that screen.
  5. bitsobrits
    Nov 12, 2011
    740
    Omaha, NE area, US
    Steve
    Ah, thanks. I’m obviously not familiar with the 458. There are aftermarket screens available for CarPlay retrofit, but most are largish.
  6. bball16
    Dec 2, 2011
    4,125
    NY LI FtL
    It’s as good as factory
  7. miketuason
    miketuason F1 World Champ Owner Silver Subscribed
    Feb 24, 2006
    15,808
    Cerritos, CA.
    jimmyp11, 308Dadoo, Jbrauer and 9 others like this.
  8. Vonbarron
    Vonbarron Formula 3 Owner Rossa Subscribed
    Aug 26, 2014
    2,261
    Westside Mofo
    S B
    26street and LE06 like this.
  9. 26street
    26street Formula Junior
    Jan 30, 2021
    466
    Westchester New York
    Mark k
    That’s great just hope you got that washer out before putting the housing back
  10. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    214
    Boerne, TX
    Rodney Bolt
    That's awesome! I'm actually looking forward to doing the same work. On the A** Pain Scale, how would you rate this job? What special tools are required to have on hand?
  11. Imatk
    Imatk Formula Junior
    May 6, 2007
    768
    How tough a job is this? I've done clutches on Mustangs, but you just remove the transmission and then you have access. This looks quite a bit more involved
  12. miketuason
    Feb 24, 2006
    15,808
    Cerritos, CA.
    Actually that is not a washer, that’s part of the bracket for the oil/water separator which is secured by one of the bell housing bolt. I know it looks like a washer from the photo but believe me it’s not.
    Well if you have not done it before a scale of 1-10 (10 meaning the hardest) I would say 7 maybe 6 if you’re mechanically inclined and also depending on the condition of the car. And as far as special tools required? Clutch alignment tool and pilot bearing puller, and of course a torque wrench.
    Since you’re only removing the bell housing as I mentioned above I would say 6 to 7, (10 meaning the hardest) probably the hardest part is removing everything that’s in the way of the bell housing.
    26street, Imatk and rwbolt1 like this.
  13. miketuason
    Feb 24, 2006
    15,808
    Cerritos, CA.
  14. Imatk
    May 6, 2007
    768
    Isn't there a special socket to remove that lower bearing/gear?
    miketuason likes this.
  15. miketuason
    Feb 24, 2006
    15,808
    Cerritos, CA.
    Oh yes I forgot you do need this 45mm ring nut socket for the lower transfer gear. Sorry Rodney I forgot to tell you about the stool.
    rwbolt1 and Imatk like this.
  16. 26street
    Jan 30, 2021
    466
    Mark k
    lol sorry that is what happens when you don't wear your glasses lol
  17. BLACK HORSE
    BLACK HORSE Formula 3 Silver Subscribed
    Feb 11, 2004
    1,961
    California - Bay Area
    Rob
    I think we're all there... I'm blind as a bat! lol ...
    26street likes this.
  18. 26street
    Jan 30, 2021
    466
    Mark k
    LE06, Imatk and miketuason like this.
  19. bertrand328
    bertrand328 Formula 3
    Jun 1, 2015
    1,620
    France
    Bertrand
    I try to do the oil service of my 328, BUT the F. dealer did not know very well parts number for old car I think and the washer provided is not the good one :mad:
    LE06 likes this.
  20. LE06
    LE06 Karting Silver Subscribed
    Sep 26, 2022
    227
    Lee
    Took it out for a ride. My wife and I decided to go to a park and walk around. It was packed! Took us about 20 minutes do get through it barley moving. The temps got to about 230 or 240 before I was on open road. They slowly came down to about the line between 190 and 250. I had to cut through another small street and it got hot agin. AC doesn't work but If I turn it on it does activate one fan. Interstate home cooled but by the time I got home it was at about 230 or 240. I have a new thermostat and temp sensor for the radiator. I guess I won't be driving till I do all the work I planed on.
  21. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    214
    Boerne, TX
    Rodney Bolt
    I had the exact same issue. You probably need to burp the cooling system to get the air out. (Which begs the question, "How did air get in?"). On mine, air was entering through a bad water pump seal. After replacing the pump, doing the obligatory 'while I'm in here stuff', and purging all the air out, mine runs cool as a cucumber.
    LE06 likes this.
  22. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    214
    Boerne, TX
    Rodney Bolt
    Anneal the old washer and all will be good. Be careful not to melt it like I've done. Doh!
  23. Rifledriver
    37,089
    That motor should never see 230. Time to turn it off.
    LE06 likes this.
  24. LE06
    Sep 26, 2022
    227
    Lee
    Yea in the park I had no where to stop. The second time I did pull it over and shut it off. I kept the fan running to cool what i could in the radiator.
    @rwbolt1 I will try burping it agin just to see if I have a small leak. I cant find one. Depending on what Comes out of it when I run the flush through it I may take the radiator in to be cleaned out.
    My biggest worry is working a head or blowing a head gasket.
    mixedgas likes this.
  25. Rifledriver
    37,089
    Look to see if you melted the spark plug connectors or melted the plastic disc on the thermostat.
    LE06 likes this.
