What have you done to your Ferrari Today? | Page 16 | FerrariChat
Discussion in '308/328' started by SteveGTB, Feb 5, 2014.
  1. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    My electric woes traced to a bad alternator. Lasted 30+ years! No rebuilt units in stock locally so I had it rebuilt locally$125 out the door and still has the original Bosch stickers.
    Now I have 14.4v between the posts at 1000 rpm.
    Coolant bleeding has commenced and I'm not getting a ton of air after my first bleed.
  2. SpyderGT
    SpyderGT Formula Junior
    May 15, 2005
    997
    Vancouver, BC
    Jon
    New upholstery finished in my 328 - seats, doors, console, emergency brake. The work was done by Dave Gallagher of Phoenix Upholstery, Vancouver, BC. Dave does the upholstery work for world class RX Autoworks where his business is co-located. A true craftsman and enthusiast. Jon
  3. Ladybegood
    Ladybegood Karting
    Feb 17, 2012
    189
    Derbyshire, GB
    Glad I replaced on a whim , they turned out to de on last legs the centre electrode was almost completely worn on both and would soon fail
  4. Howard A.
    Howard A. Karting
    Jun 23, 2010
    68
    Hershey PA
    I have the clutch out and while I 'm in there I am replacing the bearings too. An ongoing problem is leaking oil from all points. I puilled off the trans pan to put in a new gasket and Strat-O-Seal washers and out dropped the springs and balls that are up in the mid casting. I have been searching for a cross section or a tutorial on replacing those gaskets but haven't found it yet.
  5. jcinflorida
    jcinflorida Formula Junior
    Oct 24, 2009
    331
    Melbourne Florida
    Replaced driver's side CV joint boot (cleaned/inspected/repacked joint), new oil cooler lines, and pulled out all the interior fabric trim parts for re-covering. Took awhile to get the old fabric off and now the search for the unobtanium black-stripe fabric begins.
  6. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    #381 scowman, Sep 1, 2014
    Fixed my driver power window. Electric motor was seized. Cleaned and lubed good as new. Took it for a spin through magnolia and got caught in the rain. Gts does a great job keeping rain off the driver even at low speeds
    Tucked under a gas station and had a cigar.
  7. ClydeM
    ClydeM F1 World Champ
    11,910
    Wayne, NJ
    Clyde E. McMurdy
    Crawled under the car to check out a suspension squeak. all bushings & shocks were replaced 7 years ago :(
    Looks like the shock bushings. {sigh}I'm not sure if this can wait until winter.
    May have to pick up a HF shop press a la Birdman.
  8. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,149
    SanFrancisco BayArea
    1983 US 308 GTS QV
    I re-re-re-re-re-re-re-fixed my exhaust rattles. I think I may have fixed them for good this time (... he says naively...). I squished the ends of the heat shields down with hose clamps.
  9. mresso
    mresso Karting
    Mar 6, 2012
    114
    Santa Rosa
    Mike R.
    #384 mresso, Sep 3, 2014
    The rubber weather stripping above the windshield was very worn and I decided to replace it. Bought for under $200 on fleabay and did it myself...an easy DIY for a mechanical klutz such as myself. It turned out great and makes for a much cleaner look when riding without the targa top (which is most of the time.)
  10. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    #385 scowman, Sep 5, 2014
    Jacked her up to r&r the diaper. A little banging a little sanding a can of primer and a can of BBQ paint and it should look good as new right?
  11. ragtop1
    ragtop1 F1 Veteran
    5,242
    Ontario
    Larry Warren
    i had mine sand blasted and powder coated. It should hold up to the heat better and longer. I tried your method and the paint still peeled.
  12. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    How fast did it peel?
  13. ragtop1
    ragtop1 F1 Veteran
    5,242
    Ontario
    Larry Warren
    I believe I got about 2 seasons out of it
  14. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    Did a bit or searching. I think I'm going to try header paint. Sounds better than BBQ paint.
    Trying to keep the costs down so blast and powder coat is off the table for now.
  15. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Replaced the rear outer cam bearing and seal. Odd the PO or mechanic had pushed the seal in past the inner lip which caused the outer bearing to leak. The whole job took just over 4 hrs. Very easy by most standards. The hardest part was trying to retrieve the seal which was on the inner side of the seal lip.
  16. mresso
    mresso Karting
    Mar 6, 2012
    114
    Santa Rosa
    Mike R.
    #391 mresso, Sep 12, 2014
    Removed the diaper from my 1980 GTSi and had it powder coated flat black wrinkle. The best $150 I ever spent on the car. The part came out looking beautiful. The small imperfections in the metal were made invisible because of the wrinkle. The coating will add protection to a surface that is otherwise easily scratched or rock pelted.
  17. Renato
    Renato Formula Junior
    Apr 14, 2013
    553
    New York
    That looks great! I suspect with that application/finish you'll be set for a long time.
  18. MarcH
    MarcH Formula Junior
    Nov 5, 2010
    446
    Hoeksche Waard
    Marc
    #393 MarcH, Sep 12, 2014
  19. GF355UK
    GF355UK Karting
    Jan 26, 2013
    160
    Ok not technically today but tomorrow...
    I'm off to Silverstone for a packed weekend of Ferrari Racing Days.
    Joining a 650 car track parade tomorrow afternoon. This will be the first time I've done something like this as an owner (spectated at several similar things) so it promises to be very special indeed.
    Looking forward to seeing the inaugural run of the 'famous' F40LM restoration that's been keeping many glued to fcthat and club scud.
    Plus - I'm in a nice hotel near the track with a few like minded pals, which means a few beers sat night.
    What's not to like? :)
  20. Elentinos
    Elentinos Formula Junior
    Sep 8, 2011
    296
    Netherlands
    Erwin
    I fitted a Tubi on my 328 today. 2 hours work, the old stock exhaust bolted right of and the Tubi fitted like a glove. After an hour driving I am a happy man. This is how it should sound like from the start. I drove my 328 for three years with the stock exhaust, it's like I have rediscovered my car...
  21. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Removed the throttle cable. Cleaned and re lubed it. Cable was like new. White grease was still on the pedal clamp. The internal capilitary tube was making its way out which caused some friction. Pushed it back inside the coiled spring housing tube. Works very smooth now. Simple job. You can clean and re lube the cable end to end. Peace of mind now.
    I will check the clutch cable whilst I pull the clutch later this fall.
  22. Jez
    Jez Karting
    Jul 29, 2013
    70
    Westerham
    Jeremy Gilbert
    A lap of Silverstone race track! - Ferrari Racing Days Tribute Lap
  23. davebuchner
    davebuchner Formula 3
    Jun 1, 2005
    2,487
    London UK
    Dave Buchner
    Haven't driven the 308 for 2 months - I have been travelling a lot and have only spent 3 weekends at home in that time. She was stored uncovered in the garage and very dusty - so yesterday morning I gave her a good wash and then went for a great drive.
    The sports exhaust I fitted a few months ago was burbling on the overruns, and she performed so well. I forget what a small, nimble car she is especially compared to the 360. It was like putting on your favourite pair of shoes after not wearing them for a while.
    As I wasn't using her enough I had been considering selling her - but I have shelved those ideas for the moment!
    Went out in her again this morning to visit a fellow Ferrarista who has a 166 Barchetta (s/n 0056M). Stunning - especially when parked next to his Bugatti Type 37.
  24. 4right
    4right F1 Rookie
    The prior owner of my 308 did the same thing with spray on paint, consequently, the diaper was rusted and the paint was pealing. This was actually the first project that I did, performed the same service as described here already, sand blasted then powder coated. Still looks great after six years on!
  25. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    I painted with VHT Flame Proof for headers. 2 cans, $20 and it looks good. We'll see how that lasts.
