What have you done to your Ferrari Today? | Page 74 | FerrariChat
Discussion in '308/328' started by SteveGTB, Feb 5, 2014.
  1. dinoart
    dinoart Formula Junior
    756
    Westminster CA
    David
    The passenger window lift is much better now after I greased the rollers. It is still slow but I can live with it. The passenger lock actuator doesn't seem to work properly. It supposes to stay shut (down position) when I lock the driver side door but it would go down and then immediately pop up. Should I take the actuator out and clean it? Is it serviceable?
  2. Schulz308
    Schulz308 Formula 3
    1,454
    STL USA
    That looks Fantastic!
    Daytona seats are a major thumbs up in a 308
  3. Ray F
    Ray F Karting
    Jul 17, 2005
    192
    Somerset, England
    Ray Forster
    Thanks, that’s what inspired them.
  4. DavidDriver
    DavidDriver F1 Rookie
    May 9, 2006
    4,416
    Grass Valley, CA
    David Driver
  5. JuLiTrO
    JuLiTrO Formula Junior
    Nov 2, 2017
    383
    Julio Saiz
    I was yesterday recovering and cleaning the leather seats.
    Results are very promising after having removed some years of neglected cleaning by previous owners and one very bad redying/painting layer
    Original Blue is coming out
    Best Regards
    Julio
    Jbrauer, Rosey, Oengus and 3 others like this.
  6. chasjen
    chasjen Karting
    70
    Dublin, Ohio
    Charlie
    Hello All,
    Since getting my first Ferrari this October, an 85 308 QV, I've replaced the rear main seal and clutch (while I was in there). No more oil leak! I've also replaced the fuel filter, accumulator, and fuel pump. Incidentally also installed new stereo.
    I can't believe how much better it runs after replacing the fuel pump, accumulator and filter. I was a little surprised. I replaced the parts due to a hot start issue.
    Finally, I give much thanks to everyone on this forum for your outstanding help!
    JuLiTrO likes this.
  7. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    16,181
    Gold Coast, Aust.
    Patrick
    Mine died a violent death - started having an epileptic fit (up/down several times a second), and I had to pull the fuse. While I was in there, I installed remote keyless entry. A very much worthwhile upgrade.
  8. Canuck550
    Canuck550 Formula Junior
    Sep 8, 2015
    462
    Incognito
    RJA
    a lot of maintenance over the winter, hard winter in Toronto
  9. billboboy
    billboboy Formula Junior
    Aug 15, 2015
    341
    San Jose, CA
    Will L
    Definitely serviceable with the door card removed. I had to do the same to my passenger lock last year. Shove a generous number of rags under the lock to collect the mess and go to town with WD-40 and an old toothbrush. Double check the plastic bits are still well connected and not cracked. The old grease turns into basically clay after a decade or so. I let mine “dry” for about a day before reapplying new lithium grease and exercising everything well before replacing the card. Hopefully it’s just a grease jam preventing the actuator from properly driving the mechanism.
  10. billboboy
    Aug 15, 2015
    341
    San Jose, CA
    Will L
    Took the 308 in for another random little oil leak and valve adjustment.
    I’ve also started hearing a loud repeating metal “TICK” sound coming from the passenger side of the front bank. It’s only happening when the engine is cold (goes away when oil warms up) and rate chases the RPM.
  11. Oengus
    Oengus F1 World Champ
    ordered the Carbonio magnetic rear license plate holder.
  12. dinoart
    756
    Westminster CA
    David
    I have the same thing on my 85 QV GTS US on the passenger side. It goes away just like you say.
    billboboy likes this.
  13. dinoart
    756
    Westminster CA
    David
    Good advise. What color is the new lithium grease? Thanks.
  14. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    Possible valve problem. Was this tick not present before, but started after, the valve adjustment?
  15. dflett
    dflett Formula 3
    Jun 24, 2005
    1,603
    NY
    David
    Could also be an exhaust leak.
  16. billboboy
    Aug 15, 2015
    341
    San Jose, CA
    Will L
    It definitely sounds like it iscoming from the top of the engine but seems far too slow to be a valve tick. Also very metal tick sounding, not from exhaust.
    Idoe is fine both cold and warm. I’ve asked my mechanic to take a listen and help me diagnose.
  17. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
  18. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    #1845 Crowndog, Feb 21, 2019
    If the door lock button with the Philips end is screwed to far down then the rod it’s attached to and won’t go all the way down. Remedy is to back it off some. The bevel shape interferes with the opening.
    Similar button but no bevel;
    GordonC likes this.
  19. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    11,990
    FRANCE
    #1846 nerofer, Feb 24, 2019
    Every cloud has a silver lining, so...took advantage of the abnormally mild weather this end February in eastzrn France to have my first topless drive of the year with ol' #80515. Supposedly, it should be freezing, but no...a touch of heating and it was actually gorgeous.
    Now enjoying a bottle of Bordeaux (Graves, "Chateau Bouscault 2001") listening to the car clicking while cooling off in the garage.
    Does it get better than this?
    Rgds
    Can't upload the pics...will do tomorrow!
  20. billboboy
    Aug 15, 2015
    341
    San Jose, CA
    Will L
    I used standard white lithium grease and it’s been working great.
    The original grease turns to clay after 30yrs and is a pain to get out without a mild solvent like WD-40 or other penetrating oil.
  21. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,086
    SanFrancisco BayArea
    1983 US 308 GTS QV
    Is lithium grease still better than modern synthetic (silicone) grease?
  22. nerofer
    Mar 26, 2011
    11,990
    FRANCE
    Here she is; glorious day in February, with the weather as you would expect it six weeks later...
  23. billboboy
    Aug 15, 2015
    341
    San Jose, CA
    Will L
    I haven’t tried silicone grease on mechanisms like door locks, just rubber suspension parts since it won’t degrade rubber or polyurethane.
    I had assumed that silicone grease is more for corrosion protction and water penetration prevention, not necessarily lubrication in highly temperature varying applications. For door locks it might not make a difference. For my throttle linkage I still use lithium grease as it has lasted me 4+ yrs between applications.
    From Wikipedia:
    Silicone grease is commonly used for lubricating and preserving rubber parts, such as O-rings. Additionally, silicone grease does not swell or soften the rubber, which can be a problem with hydrocarbon based greases. It functions well as a corrosion-inhibitor and lubricant for purposes that require a thicker lubricant.
    Grease made with lithium soap ("lithium grease") adheres particularly well to metal, is non-corrosive, may be used under heavy loads, and exhibits good temperature tolerance. It has a drip temperature of 190 to 220 °C (370 to 430 °F) and resists moisture, so it is commonly used as lubricant in household products, such as electric garage doors, as well as in automotive applications, such as CV joints. Lithium-containing greases first appeared during World War II and were perhaps the first large-scale commercial application of lithium compounds.
