What I Should Look For in Running Hot | FerrariChat
Discussion in 'Boxers/TR/M' started by ag512bbi, Sep 11, 2023.
  1. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,490
    So. Cal
    Armen
    After sitting a while, I took my BBI out last night for a drive. I found my oil Temp rose pretty high (photo attached). Please give me your thoughts of what I should look for. Thank you.
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,516
    romano schwabel
    electric problem I think, may be ground?
    is it only the oil temperature showing so high?
  3. Rifledriver
    32,370
    Austin TX
    I hope Joe is right. The other possibilities are pretty grim.
    I would check oil level too. If it got very low too hot is pretty common.
    Run hard on a race track and BBs are famous for pegging the gauge. But cruising around town thats too high.
    lagunacc likes this.
  4. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,490
    So. Cal
    Armen
    Actually, NO the water temp was up there too. That fluctuates often.
  5. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,490
    So. Cal
    Armen
    I never had it run that high. Kinda scared me.
  6. Rifledriver
    32,370
    Austin TX
    If that oil pressure is at idle, no big deal. If at running speed not a great sign.
    Combination of high oil temp, low oil pressure and high coolant temp not great unless car was being run hard. Boxers run hot when run hard. Its why so many changes took place in the over all cooling on TR. Also why BBLMs had that great big nose. A friend who had a BB told me over 110 the oil temp went up as fast as the speedometer. At track events I routinely saw them buried past the 140 mark.
    How hot was the weather?
  7. sherpa23
    sherpa23 F1 Veteran
    9,964
    Rocky Mountains
    Bastuna
    I see that water temp from time to time, especially on hot days. I don't see that oil temp unless I'm driving fairly hard.
  8. Steve Magnusson
    24,381
    Have you confirmed if both radiator fans are running?
    (Sort of surprising, but a 512BB/BBi has no dedicated oil cooler?)
  9. Rifledriver
    32,370
    Austin TX
    Nope. Was a real issue in some operating modes.
    The big nose on BBLM held a huge oil cooler.
  10. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,490
    So. Cal
    Armen
    I'm no technician, so help me out here. Just got home. To check Oil level, I started and ran the car at idol for a GOOD 5 mins. Shut it off whiped dip stick clean, and checked oil level. No oil sign on dip stick. Is that the correct way to check?
  11. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,490
    So. Cal
    Armen
    Would that effect oil temp or just water temp?
  12. Rifledriver
    32,370
    Austin TX
    No. The oil temp needs to be over 80-85 degrees on gauge. Turn off engine and check level right away.
    ag512bbi likes this.
  13. Steve Magnusson
    24,381
    Both. There's a lot of heat transfer inside the engine between the two -- so they usually run about the same given enough time to reach equilibrium. Those temp sensor/gauges aren't super-accurate -- it's more telling that both are running higher than "normal" (rather than them not reading exactly the same).
    Wouldn't help the oil temp if your oil level is lowish, but make sure both radiator fans are working.
  14. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,490
    So. Cal
    Armen
    ryalex likes this.
  15. Rifledriver
    32,370
    Austin TX
    Suggest your guy use dinosaur oil. Valvoline 20/50 Racing is a good choice. So is Joe Gibbs oil.
    The Victorian era rings used in BBs are just hopeless for oil control. Synthetic oils burn so fast in them its tough to keep them full.
  16. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,490
    So. Cal
    Armen
    Wow, Very Interesting! Thank you
  17. Rifledriver
    32,370
    Austin TX
    Your mechanic may not care what some guy on the internet says but its worth a try.
  18. 4right
    4right F1 Rookie
    Are the fans on and staying on while the temp is above 90 or are they cycling on and off? Mine was running hotter than normal because the fans didn’t stay on long enough to cool the engine. Found a faulty temp switch on the radiator to be the cause. Replaced, fans stayed on when above 90 and temps went back to normal.
  19. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,490
    So. Cal
    Armen
    Good Question. Im guessing here, I believe the fans cycle. I'm gonna go check it out. Thank you
  20. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,499
    Dubai / Bologna
    My TR runs hot when there is air trapped at a high point in the cooling system.
    Despite the system being completely different, does a BB have a cooling system bleed valve on the engine or firewall, in addition to the one on the rad (I recall one being on the rad)? Could be a simple fix - how is the coolant level?
