What is a compression test during PPI? | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by Vlad328, Dec 17, 2004.
  1. Vlad328
    Vlad328 Formula Junior
    Mar 16, 2004
    279
    New Orleans, LA
    Vladimir Zuzukin
    I have often seen recommended to get a compression and leak down test during the PPI when purchasing a used Ferrari? What is this test for exactly?
  2. T0nyGTSt
    T0nyGTSt Karting
    Jul 31, 2004
    196
    It tells you the health of each cylinder.
    Each cylinder should have a similar amount (not more than 5% difference) - eg. each cylinder should do 160psi for example.
    Any huge variation means trouble either rings, valves, pistons, and that means rebuild time.
    T.
  3. ashsimmonds
    ashsimmonds F1 World Champ
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
    what is sort of standard on older (60's-70's) ferrari engines?
    i understand the numbers themselves aren't entirely useful as the volumetric efficiency has far too many factors involved.
    it's just the last 2 times i've measured mine (old fiat engine :) ) it had 210 psi across the board. anyone else's results i've seen have yielded numbers like 140-160, i've never seen anywhere near 200 before i got my car.
    the engine's just been rebuilt for decent performance, so it'll be interesting to see what happens to the numbers... though there may be a lot of overlap on the cams. wiggle wiggle wiggle. :D
  4. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    I've found such large differences between the readings on different gauges that I think the best is just to look at the variation between cylinders rather than the actual number on the gauge
  5. tbakowsky
    Sep 18, 2002
    20,016
    The Cold North
    Tom
    BINGO!!....
  6. ashsimmonds
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
    figgered that, and happy that my readings have all been within 1-2 psi of each other, was just interested to know if there was an "average".
  7. Rifledriver
    37,274
    It is to quantify each cylinders ability to contain the expanding gasses that create the force that provides an engines power. It is as said in another post measuring the motors health much the same as measuring a persons blood pressure. As was also very accurately put in another post the equipment varies a great deal as does methodology so a certain amount of judgement is required to make an accurate interpretation of the data collected. It is one of many reasons that it is important to have not only a qualified individual but also one that has a great familiarity with the particular type of car in question.
