what is a major service? | Page 2 | FerrariChat
Discussion in '348/355' started by fatbillybob, Nov 24, 2014.
  1. RaginBull
    RaginBull Formula Junior
    Oct 24, 2006
    996
    Bay Area, CA
    Darryl
    #26 RaginBull, Nov 24, 2014
  2. phrogs
    phrogs F1 Veteran
    7,378
    Kzoo Michigan
    #27 phrogs, Nov 25, 2014
  3. Rifledriver
    37,369
    It has never been an official term. At one time most European cars had similar service schedules at 15k and 30k miles. In Ferraris case it was 12.5k and 25k but they changed to 15 & 30.
    We actually used to call them minor major and major majors. Benz called them D and E service.
    There was remarkable similarity between makes. Fluids and minor tune with valve adjust with a small list of checks on the minor, major tune with belts, even new chains on some cars and a long list of checks, adjustments, inspections etc.
    A belt service is a belt service period. Belts were never intended to be done solely at big services. That just became the norm out of greed and misinformation. A major includes a belt service but a belt service is not a major. Salesmen say it out of stupidity or for obfuscation.
  4. Bertil
    Bertil Karting
    Sep 8, 2012
    199
    Stockholm Sweden
    Bertil Palmblad
    As Rifledriver says, a belt service isn't a major. Check pages 460-465 in the work shop manual what Ferrari recomends (for the 348)
    All Ferraris
    BR
    Bertil
  5. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    Major service: A generic term meaning something bad is about to happen you your wallet. Typically it involves changing timing belts and tensioner bearings and a lot of other stuff that you don't really need to have changed or done but get talked into because you are already paying $4k to drop the engine so why not spend another 2 or 3 k , or more, on things that might have a 1 in 100 chance of failing before you get suckered into dropping the engine again because you drove 4k miles over the next 3-5 years.
    You will notice that was a classis run on sentence, which is the exactly exact definition of what a major is.
  6. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    If you check Ernie's 348 major thread, that's what I would say.
    Drop the engine, and repair/replace everything and anything that needs it.
  7. Big Lebowski
    Big Lebowski Formula Junior
    Jan 24, 2013
    337
    Peach state
    Brownie
    #32 Big Lebowski, Nov 25, 2014
  8. AlfistaPortoghese
    AlfistaPortoghese Moderator
    Mar 18, 2014
    3,778
    Europe, but not by much.
    Nuno
    How?!
  9. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    When I pull the motor from my 95 in a couple months (or less), I'm giving serious consideration to going through the entire engine. While I do have most of the service records, valve guides where done by a small shop. Now, the guy may have been the most talented guy on the planet, but I simply just don't know. Given 26K miles of 20 years, I think it would be wise to pull it all apart and replace / repair whatever looks suspect. It does not seem like that much more work once the motor is out.
    I'm looking forward to this "Major" :)
  10. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,956
    Richmond
    Pete
    Hill tensioner bearings were installed at the last major, so I will check them and if they feel rough at all or look damaged in any way, replace them.
  11. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,774
    A major is where you take the engine bay apart, fix everything that is wrong or will go wrong over the next 3 year in the engine and bay; then reassemble.
    Its called a major because of the kind of damage it does to your pocket book.
  12. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    LOTS of while you're in there stuff. :)
    And about half of what my Mondial 3.2 Coupe is currently worth.
  13. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    #38 97 Spider, Nov 25, 2014
    I agree with you 100% John. People can get really wrapped up in the super preventative maintenance part of it. But it gives some people a better peace of mind to get it all done and then maybe they are more relaxed when they take it for a drive and can enjoy their car more even although their pocket book it lighter.
    Normally have a run to failure policy on my cars. If it isn't broke or leaking leave it alone. Obviously this policy can't apply to timing belts and tensioners because letting them fail would be more costly then the replacement.
    That said I am doing Major Majors on my 348 and 355 because I have no service history on the cars and other then a new clutch on the 355 just before I bought it I have no idea when or if anything has ever been done on these cars. I've done 1000s of miles in each since ownership but it's time to really get in there and do everything then I'll probably go 8-10 years on belts and fix as it fails on other things.
  14. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
    Ok without the 50% of the time list...what do you think is a fair price for just that min service at a Indy shop? What is reasonable for an engine rebuild on a 355?
  15. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,704
    San Carlos, CA
    Mitchell Le
    That is a $7000 from a good indy. You will never get away with that. The last 2 cars I touch both have broken headers, cats, and engine mounts. Can you say $5,000?
    The last one has a old Spal fan, sucking up so much juice that the 30 amp fuse melted into 3 pieces, one evaporating totally, and destroying the NLA fuse board on its way out. I don't even know how much that will cost. And this is why preventive care is so much more important with certain things.
  16. Big Lebowski
    Jan 24, 2013
    337
    Peach state
    Brownie
    Speaking of fans (and apologies for a brief thread hijack) is there a good non OEM rad fan replacement? My left rad fan blew a fuse a couple of months ago, presumably the fan is getting a bit tired and drawing too many amps.
  17. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    What would an engine rebuild cost out of curiosity?
  18. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,493
    Tucson, Arizona, USA
    Robb
    $20k to $30k has been quoted in forza.
    Robb
  19. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,956
    Richmond
    Pete
    Spal makes them, just be sure to get the sealed non-motorsport version. The oem fan is a motorsports version that isn't sealed, hence they get dirty inside and fail.
  20. yelcab
    Nov 29, 2001
    13,704
    San Carlos, CA
    Mitchell Le
  21. 8500rpm
    8500rpm Formula Junior
    May 20, 2014
    546
    San Francisco Bay
    Chan
    Just headers and cats were already 5k, and that's aftermarket. Ask me how I know! :(
  22. Big Lebowski
    Jan 24, 2013
    337
    Peach state
    Brownie
  23. Eric C
    Eric C F1 World Champ
    11,136
    St. Louis, MO
    Eric
    Anything that forces me to crawl my big ass under the car.
  24. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    I agree this is basically a major provided that nothing else that is checked fails.
  25. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    Thats what I would think...normal maint stuff....If a person wanted to add while were in there stuff or anything that needed done right there and then the list would be endless and vary from car to car. I think very few cars would come in and need only this done but all of that would vary. Lets say a car comes in for a major and need rear rotors and pads would that be considered part of a major? I wouldnt its just getting done at the same time.just my opinion
