What is correct engine paint for type 209? | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by SCantera, Aug 27, 2009.
  1. SCantera
    SCantera F1 Veteran Silver Subscribed
    Aug 4, 2004
    5,834
    Living Falls NC
    We are in process of rebuilding the engine in my GTC s/n 9593. New pistons, rings, rods.....lots of new pieces for its 1st ever rebuild.
    My question is that the block, head and manifolds have a silver paint. What would u recommend to match the color and lustre of the original?
    thanks in advance
  2. BIGHORN
    BIGHORN In Memoriam
    Sep 18, 2006
    733
    FLORIDA/NEW MEXICO
    JOHN F KELLY
    May not be around any more but Evenrude silver was right on
  3. Dave330gtc
    Dave330gtc Formula Junior
    Mar 12, 2002
    601
    NW Indiana
    David Smith
    I don't remember the brand but we used a high heat silver from the auto parts store that was more matte than shiny. Once it is in the car a lot of the silver disappears. I had the same question before my engine was rebuilt but the answer from an old time restorer was don't overthink it. It is not one of the important issues.
  4. lancia
    lancia Formula Junior
    Jan 18, 2004
    575
    Consider Harley Davidson high-heat silver; reasonable match for color and brightness, and the silver does not come off on your hand like some silver paints do; I think Bill Hirsch has a good option also if you contact them.
  5. Cris Bertschi
    Cris Bertschi Formula Junior
    Mar 3, 2005
    808
    Buenos Aires
    Cristián Bertschi
    And the cam covers?
    Regards.
    Cris.-
  6. michael bayer
    michael bayer Formula 3
    Aug 4, 2004
    1,292
    Wrinkled, but just right, if you expect to be judged then you should consider sending then to a pro who knows what the correct wrinkle is. Otherwise see the thread on Tom Yang on wrinkle paints and application
  7. SCantera
    Aug 4, 2004
    5,834
    Living Falls NC
    Good point. The only thinking I had to do was call Patrick Otis who is doing the bottom end work. Patrick said Bill Hirsch's engine paint is what he recommended.....just as Lancia pointed out in his post.
    thanks guys......can't wait to get my revitalized GTC back on the road!!
  8. philrose08
    philrose08 Rookie
    Aug 26, 2009
    16
    london
    phil rose
    eastwoods aluma blast is one of the best well matched paints as its not glossy like most silvers and etches into aluminum really well.
  9. SYake
    SYake Karting
    May 15, 2005
    87
    NoVA
    I have had the Harley Davidson aluminum shot bead paint recommended. For wrinkle paint -- I sent my heat shields to Gary Bobileff. I also had a friend send his valve covers to Gary. You can save some with Gary by stripping them yourself--I used aircraft paint sripper (made for aluminum).
  10. BarnFound330
    BarnFound330 Karting
    Feb 1, 2005
    89
    Pleasanton, Ca
    Vince Bobba
  11. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,580
    Grant
    Are you painting inside you engine?
    I know this sounds nuts but when my Daytona engine was striped down recently it had green aircraft type paint on the alli inside of the engine.
    Anyone know if it needs to be done if so with what type of paint?
    Grant
  12. SCantera
    Aug 4, 2004
    5,834
    Living Falls NC
    I believe it is zinc chromate that was used on the inside of the engine. From what I understand all inside surfaces are to be coated......with the obvious exception of the combustion areas. I believe there is a newer more modern type of paint, but I will have to talk to my shop to find out what it is.
  13. SCantera
    Aug 4, 2004
    5,834
    Living Falls NC
    Beautiful engine and pics. I just received the paint from Bill Hirsch.
  14. lancia
    Jan 18, 2004
    575
    Yes, Ferrari used zinc chromate primer to coat the surfaces of the castings internal to the engine to seal the casting and the same zinc chromate is the primer for the silver (or wrinkle finish) external finish. Inspecting original castings, it appears that, at least for some pieces, the entire piece was primed and then machined, as the line between the primer and machined surfaces is too exact, even from masking (as in your photo of the timing case). I also speculate that the engine castings may have been assembled without gaskets and internals for the purpose of painting the exterior (self-masking) and then taken apart for real assembly. It must be the reason that you find (and see in original photos) silver paint on the ends of the exposed studs, but no paint on any of the hardware or gaskets. It would have saved the need to mask individual pieces. Just a theory from observation.
  15. Bryanp
    Bryanp F1 Rookie
    Aug 13, 2002
    3,822
    Santa Fe, NM
