What is Paul Sloans ECU ground strap? | FerrariChat
Discussion in 'Technical Q&A' started by ndnguyen, Oct 28, 2013.
  1. ndnguyen
    ndnguyen Karting
    Jul 27, 2005
    166
    #1 ndnguyen, Oct 28, 2013
    Hello,
    I hate to ask, but I spent a couple of hours reading old threads but could not find a definition of what is a Paul Sloans ECU ground strap. Best I could find is something about an extra ground wire connecting the ECU to the coil's ground.
    Thanks for any help,
    Nguyen
    Never mind, what'd ya know: as should as I post this I think I found it in below thread.
    http://www.ferrarichat.com/forum/technical-q/105715-308-gtsi-2v-intermittant-miss-help.html
    "SLOAN83QV
    Full Name: Little Dave M.
    I would bet The ground wire for the ignition boxes is the problem..do this fix 1st as it will save you alot of headaches (now or later)
    Run a new ground wire from the trunk where the Marelli Boxes ground to the bolt where the coils mount. The ground in the trunk is trouble and I have done this update on 6 308's to date + 1 user on FC did it 3 weeks ago and solved his problem."
