what is resonating at 4K RPM on a 328? | FerrariChat
Discussion in '308/328' started by yelcab, Sep 3, 2009.
  1. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,598
    San Carlos, CA
    Mitchell Le
    I have a tinny, glassy resonating noise at 4,000 RPM in gear or not in gear, timing side of the engine. Has anyone had the same ?
  2. wazie7262
    wazie7262 Formula 3
    Feb 13, 2008
    2,357
    Temecula, CA
    Scott
    Kind of a "ping"? I used to have that. Once I changed my exhaust it went away. I think this is fairly typical from other threads/posts I seem to remember.
  3. 308nut
    308nut Formula 3 Lifetime Rossa Owner
    Jul 22, 2002
    1,881
    NOLA/Covington
    Wade
    The exhaust on the 328's start to get a pinging sound after a while, I believe it is the resonators inside the tips that start to go bad. Have heard it on many 328's
    Wade
  4. 308-newbie
    308-newbie Guest
    I had a belt cover stud that cracked (started similar to that) then broke and it sounded like something was going to fly apart. Check the cover studs are tight as a quick and dirty.
  5. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,038
    I second that. I've seen about 3 or 4 let go on different 308s. I kept the 10mm stud spuds in my tool box that I fished out of the block. One of them was a little stubborn, the others unscrewed easily - thankfully.
