355 - What is that little nugget at the top / rear of the door? | FerrariChat
355 What is that little nugget at the top / rear of the door?
Discussion in '348/355' started by squid, Jun 12, 2023.
  1. squid
    squid Karting
    Oct 5, 2006
    153
  2. 308 GTB
    308 GTB F1 World Champ
    11,717
    New Jersey
    Barry Wolinsky
    Qavion likes this.
  3. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    #3 348Jeff, Jun 13, 2023
    308 GTB likes this.
  4. squid
    squid Karting
    Oct 5, 2006
    153
    You know, my detail guy said that, but when I went to my trusted body shop he said it was absolutely rust. Maybe I should just have him do the work and when he sands it down he can see it's not rust, maybe.
  5. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
  6. squid
    squid Karting
    Oct 5, 2006
    153
    Did you do the mirror stems as well? I have the same issue there, actually much worse.
    He's saying he will only do it no warranty, that the rust will start happening again immediately.
  7. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    I do have bubbling on my mirror stems but not bad enough to get it done yet.
    Are you sure you should be trusting this paint guy????!!!! LOL There's no reason why if rubbed down to bare metal and a proper primer applied why it shouldn't last. It is most definitely NOT rust - rust is brown whereas aluminum corrosion is like a white powder.
    Apart from the magnet test, you could always spray the "rust" with some of the purple deionizer used for cleaning wheels/fallout. Rust will dissolve whereas this white powder won't.
  8. Rifledriver
    37,086
    To some people any metal corrosion is rust. No need to split hairs.
    phrogs likes this.
  9. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    #9 348Jeff, Jun 13, 2023
    It's not about splitting hairs - if you look at post #4 the bodyshop guy was adamant it was rust and in post #6 the same guy says he will only paint it without warranty - bad sign in my opinion. He really should know his stuff better than that - the detail guy knew what it was.
    I'm just an amateur but because I prepped the surface properly its lasted over 10 years with no signs of coming back so there's no reason why a decent bodyshop cant do the same.
    bjwhite likes this.
  10. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    It's oxidation caused by moisture contamination of the bare aluminium before painting, something as simple as a finger print can slowly set it off.
    Mclaren and Aston Martin had huge problems with the same happening on their aluminium body panels.
    Best bet is to dry bead blast to bare, spirit panel wipe and quickly etch prime then a sealer coat on top, after that normal auto paint will stick to it like the proverbial.
  11. Mavic850
    Mavic850 Rookie
    Apr 25, 2021
    46
    Guy foulger
    A slight side line but how do you get it out? Mine need double doing.
  12. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    There's 2 captive alan bolts/screws on the inside of the door just above the door lock screws. It was quite a while ago when I did mine and I had my whole door apart when doing so so I cant quite remeber whether you would be able to wriggle it out or not - my gut feeling is you'd be better off taking the inner panels off the door to give proper access.
    My LHS one still needs doing so if there is enough interest I don't mind doing it and taking a few photos.
  13. Mavic850
    Mavic850 Rookie
    Apr 25, 2021
    46
    Guy foulger
    Thanks, I had mine unbolted, the door lining off but could not wriggle it out. Felt like something else was restricting it. I also see the rubber seal in the unit is very costly to replace.
  14. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    Try it with the window in the down position
    308 GTB likes this.
  15. bjwhite
    bjwhite F1 Rookie
    4,806
    Seattle, WA
    Brian White
    Those people are wrong. Hairs need to be split. It's not all that hard to speak accurately.
    willrace likes this.
  16. squid
    squid Karting
    Oct 5, 2006
    153
    I don't know the difference so possibly I was misquoting
  17. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    783
    Treasure Coast Florida
    MATT
    Just thought I would chime in. Rust usually refers to metal/steel and corrosion refers to abc, aluminum, bronze, copper. Having said that the piece can be stripped and I would find fund a shop and have it powder coated. I belive in fact that it was from the factory.
  18. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I would also blast and power coat that bit assuming the surface finish is not too damaged, it could be however. Best of luck!
    Sent from my SM-G990U using FerrariChat.com mobile app
