What is the common fix for parking brake not working? 355 | FerrariChat
Discussion in '348/355' started by jevs, Mar 16, 2012.
  1. jevs
    jevs Formula Junior
    Oct 13, 2010
    477
    Missouri
    My parking brake has not worked since I got the car. What is the common problem/fix? Is it usually just adjusting it back at the rotors, or something else?
  2. White Knight
    White Knight Formula 3
    Aug 22, 2011
    1,531
    Ogden, UT
    Todd S.
    Generally the adjustment is made at the rear left rotor.
    When I had mine adjusted recently, I was told one of the components in the cable system between the handle and the rotor had worn down, so that was where the adjustment was.
  3. JDG16
    JDG16 Karting
    Jul 25, 2011
    200
    Houston
    Justin
    Mine didn't work when I did it. Dealer/shop said they had it adjusted. It worked for about a week (ie two drives).
    At least it "slows" the roll a little bit...
  4. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,721
    The common fix is to remember that 1st gear is where the transmission is placed when the motor is off. It has a higher ratio than reverse.
  5. White Knight
    Aug 22, 2011
    1,531
    Ogden, UT
    Todd S.
    This is a good point. I always leave my car in first when off, regardless of the parking brake being set.
  6. JDG16
    JDG16 Karting
    Jul 25, 2011
    200
    Houston
    Justin
    Agreed, but sometimes you need to be outside of the car with the engine running... for example, when mine was running rough (cat came unbolted), a friend and I were trying to take a look to identify the problem but had trouble finding a flat spot in the parking lot (awkward).
  7. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
  8. MManzonelli
    MManzonelli Karting
    Nov 4, 2003
    82
    Columbia, IL
    Mark Manzonelli
    In my case, shoes were worn down....Put new ones in, brake works fine....
  9. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    My parking brake held strong unless I parked on a hill and then it would disengage itself. I would actually hear it come unlocked.
    Here is a story of how I discovered this problem:
    When I first got my 355 I had it parked in my driveway which has a pretty good slope. Parked it with the engine running in neutral and parking brake on. I got about 10 feet away from the car and I heard the parking brake release then car started to roll backwards down my drive. HollyCrap!!! I run for the car "thank goodness I had left the drivers door open" jump in the drivers’ seat and slam on the brakes.
    I still haven't discovered why it does this; it only happens if there is a load placed on the parking brake such as the car sitting on a hill. It won't disengage itself on level ground.
  10. WATSON
    23,679
    WI
  11. jevs
    jevs Formula Junior
    Oct 13, 2010
    477
    Missouri
    #12 jevs, Sep 12, 2012
  12. f355spider
    f355spider F1 World Champ
    18,044
    I imagine it is a problem with the e-brake handle, which has the ratchet and pawl in it. I've messed with mine and figure I just need to buy a new e-brake handle assembly. They are not cheap!
  13. jevs
    jevs Formula Junior
    Oct 13, 2010
    477
    Missouri
    #14 jevs, Sep 13, 2012
    The cable is froze. The handle seems fine. I took it all apart last night before I posted to make sure I did not need anything else. It probobly got moisture in it and sat or something. The cables are left exposed in this system where the one from the handle joins to the one that goes to each brake assembly. It does not seem like it would take much to get moisture in them. Surprisingly none of the exposed portions of the cables were corroded or rusted. I was only replaceing the one cable because it had been scraped and the plastic coating was off in spots and rusting. That cable was actually still fine. I could probobly soak the bad cable and free it up, but it would be more likely to fail again, so I am just ordering a new one. The good thing is the cable only lists for like $33. Bean counters forgot to add Ferrari tax I guess.
  14. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    #15 348Jeff, Sep 13, 2012
    pic for you so eveyone knows what your on about! :)
    NB The two adjuster nuts should be tight up against each other - I was just in the middle of adjusting handbrake so had loosened the 2nd locking nut off
  15. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    I love the UK cars being pictured, corrosion, oil leaks, good old driven year round cars. Over here that last picture would spark a "handbrake correction" thread! Supposed to look like it just left the factory..............I have a Lambo customer drives his year round, gets quite the looks going down the freeway in the snow at 70-80mph.
  16. mr.steve
    mr.steve Guest
    Apr 6, 2012
    118
    Ron S
    It's not just UK cars Brian, it's Most Europe. France, Italy, Germany ect.
  17. jevs
    jevs Formula Junior
    Oct 13, 2010
    477
    Missouri
    Wow, my old cables looked new compared to that LOL. The cables are still silver. No rust on any of the hardware.
    In looking at the pictures of the new hand brake shoes on the web, it appears mine are still in very good shape. I am thinking there is no point in spending $200 when mine appear to be 3/4 life. I thought they would have much more pad on new ones.
    I was kind of fooled I think. Without the cables attached I had to turn the adjuster way out to get the pads to contact. This was making me think my pads were worn to the point of needing replacement. I believe it was just because there was no cable tension at all. I think I need to get the cables all in place at the loosest setting before adjusting the "gear". The cables must supply some pretension.
  18. ferrari4seater
    Feb 1, 2007
    22
    Hello
    does anybody know how many variations of the cable was produced…the one I just bought is different from one I took out.. my 355 is early ‘95… thanks
  19. Rifledriver
    37,089
    It looks like 1 front cable number for all cars and one rear cable number for all cars. By this point its very possible we are getting reproduction cables and they are being made wrong. Thats just a guess.
    For everyone else, the brake will never work correctly until it is adjusted properly. The factory never adjusted the shoes and 28 years later I still see cars whose shoes have never been adjusted. I have never had one not work well.
    Carmellini and f355spider like this.
  20. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,629
    Elliott Caras
    Did you get the handbrake cable from Superformance UK?
    I ordered one from them and it did not fit. The hooks on the end do not fit the early 95 cars as the connection at the hub is different.
