News
What is the easiest way to increase HP for a tr (not exhaust)
Discussion in 'Boxers/TR/M' started by jpanz, Feb 10, 2019.
  1. jpanz
    jpanz Rookie
    Sep 8, 2015
    47
    Central Jersey Monroe
    Is there a simple way to modify and increase hp to a tr? Such as increase timing or change cams.
    Is the risk too high to the engine to do such mods without changing many other components?
    I'm a rookie here and have reasonable understanding of basic motors but lack hands on experience or know how.
    Thanks for any input. I would not do the work myself as I would have a shop do it for me. Just curious what options are out there without getting crazy!
  2. Schulz308
    Schulz308 Formula 3
    1,141
    STL USA
  3. jpanz
    jpanz Rookie
    Sep 8, 2015
    47
  4. Rifledriver
    Rifledriver Two Time F1 World Champ
    24,602
    Austin TX
    Buy another car. There is no non crazy way.
    CIS injection will not tolerate long duration cams.
  5. jpanz
    jpanz Rookie
    Sep 8, 2015
    47
    Love the car just want to know if any easy option juice it up a bit.
    Since I couldn’t find any threads regarding this I realize it’s probably not easy or it’s unrealistic. Thanks for your input!
  6. vincenzo
    vincenzo Formula 3
    2,262
    Easiest way to increase Testarossa hp?
    Buy a corvette.
    Natkingcolebasket69 and Jakuzzi like this.
  7. todd6363
    todd6363 Karting
    Classified Subscribed
    Jan 20, 2007
    189
    Ohio
    Todd
    I've heard of those 125 hp fender badges, but never actually got to see the test data.
  8. jpanz
    jpanz Rookie
    Sep 8, 2015
    47
    Ok I see where this is going.
    Thanks guys
  9. robert biscan
    robert biscan F1 Rookie
    I don't know of any other than exhaust. I think a 512 TR is faster.
    jpanz likes this.
  10. todd6363
    todd6363 Karting
    Jan 20, 2007
    189
    Ohio
    Todd
    Its all in good sport.
    Put you $$ into serious maintenance items and enjoy your car.
    A kid with a 400hp old civic with a turbo, is going to smoke you anyways on the low end.
  11. jpanz
    jpanz Rookie
    Sep 8, 2015
    47
    My good friend with a 360 manual spider that just bought a Z06 loved this!!!!! ;) hes gonna bust my balls for ever!
  12. vincenzo
    vincenzo Formula 3
    2,262
    Just remember...
    In a few years, he’ll own a used chevy. A Testarossa owner will have a unique, appreciating, classic icon.
    jpanz likes this.
  13. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,026
    Lakeland FL
    Shamile
    #13 Shamile, Feb 10, 2019
    I have owned my 91 Testarossa for 19 years and have been on fchat since 2001. I have seen many threads asking about power increases but I have never seen a cost effective solution. Norwoods does the twin turbo kit as does Koenig with a supercharger kit. Both extremely expensive for the return.
    Even when I floor it to redline, the standard gearbox can't keep up to shift to the next gear fast enough. Add more power, I think it's just wasted.
    The Testarossa is a cool and visceral car....but a slow dog. Enjoy it for what it is. If you really want something fast and in your face, the Lamborghini Diablo won't disappoint. I owned a Diablo VT Roadster and you could really see how much they took from the Testarossa in secret testing . I've always said a Diablo is like a Testarossa on steroids.
    At least do the exhaust. The sound is amazing if not any faster.
    Shamile
    Freeze....Miami Vice!
    Sent from my SM-G950U using FerrariChat.com mobile app
    jpanz and turbo-joe like this.
  14. turbo-joe
    turbo-joe F1 Rookie
    4,912
    southwest germany
    romano schwabel
    first of all you may select between easiest and cheapest
    if you would be able to do all yourself ( but you have written you will let it do ) then you would have the most fun as shamile has written with this what norwoods or koenig was doing - 2 turbochargers. but then you have to use much money to get the car reliable ( pistons, fuel- ignition system, intercooler, clutch, gearbox, brakes, shocks ) but the car still is very heavy and not a race car. you see when you push the car a little how bad the brakes are in original condition ( even at that time they have been great but not today anymore ), so no need to have more power.
    to not spend so much you only replace the fue injection from CIS to a map controlled system. this will give you some more reliable power but it needs a specialist to adjust this map controlled fuel injection system. also you then just may use a combined system for injection and ignition. so you could put the rpm limiter then higher than original and with the right adjustment you may then also have some more power.
    I have no knowledge if there is avaiable on the market other cams. as brian has written: CIS injection will not tolerate long duration cams
    but why you like to have more power when you just got your car? get used to the car and enjoy. go on a racetrack and see where the limit is and always remember, you have 30 year old technic. so have fun
  15. MOSS
    MOSS Formula Junior
    Rossa Subscribed Owner BANNED
    Apr 28, 2004
    746
    I have owned one Norwood Twin Turbo. If you want to drop 70k and get a beautiful job done and 1000hp this is the way to go.
    Absolutely loved mine and had zero issues. Or keep an eye our for one of his.
    turbo-joe likes this.
  16. turbo-joe
    turbo-joe F1 Rookie
    4,912
    southwest germany
    romano schwabel
    #16 turbo-joe, Feb 11, 2019
    what did norwood do with the gearbox/mainshaft/layshaft/propellershaft? primary gears from clutch down to gearbox? clutch? brakes? also changed the pistons? ignition- injection system? if this all has to be done it is much more than only 70k
    my koenig competition with 2 map controlled injection- ignition systems now needs more adjustment, until now I adjusted up to 0,4 bar boost, but like to have again 1.3 :) but no time to adjust. too much to do ;) and just now relaxing with warm weather in thailand as every year :)
    you bought the car already done from norwood or let it have done by norwood?
  17. MOSS
    MOSS Formula Junior
    Apr 28, 2004
    746
    Motronic efi, Brembo big brake kit but I believe it is a 10k upgrade. Carillo or Oliver billet rods and custom forged pistons, Je/Ross. The custom airboxes were beautiful and Looked factory. Transmission gears were left alone but 512 components for shafts. It did break some teeth on 2nd but not under my ownership.
    I'm not sure he does them anymore. Tuning is the most time constraining I believe.
  18. turbo-joe
    turbo-joe F1 Rookie
    4,912
    southwest germany
    romano schwabel
    you have 1 or 2 motronics? I think 2. so modified or from what car? what year is your car?
    you know perhaps the compression ratio?
    how much max. boost you had until now?
    you bought the car with those modification or let have it done?
    2nd and 3rd gear set are the most stressed gears becasue in 1st gear you never can drive right, always spinning wheels and acceleration most happpens in 2nd and 3rd.
    after whow many rpm your boost will increase? on my competition below 3200 rpm is nothing :( but at 3500 it is like a rocket then :) :) :)
    could you please post some pictures
  19. Tifosi Dude
    Tifosi Dude Rookie
    Dec 16, 2018
    38
    Ata Orkun Oguz
    Higher compression pistons, some porting and matching, hotter cams and modified electronic injection can get you more than 480 HP. But peak power and torque will shifted to high RPM's so to get a proper power band you should raise the rev limiter to 8000-8500RPM(if there is one). With ITB's you can push to 550 HP.
  20. jpanz
    jpanz Rookie
    Sep 8, 2015
    47
    My initial thoughts were simple upgrade for maybe up to 50hp. I see that its not reasonable. If I was to go turbo or other I would just get another car!. Keeping this one as close to stock as I can.
    I just curios to see what options were out there!
    Thanks Again!
    Shamile, Tifosi Dude and turbo-joe like this.
  21. xplodee
    xplodee Formula Junior
    Jan 3, 2017
    330
    Allentown, PA
    Tim
    How much would this run? $20k? $50k?? 8500rpm and 480hp sounds like a dream come true out of the TR.
    Tifosi Dude likes this.
  22. turbo-joe
    turbo-joe F1 Rookie
    4,912
    southwest germany
    romano schwabel
    8500 rpm? I would not try this longer time
  23. Newman
    Newman F1 World Champ
    Professional Ferrari Technician Owner Consultant
    Dec 26, 2001
    12,794
    ON, Canada
    Newman
    Far more than $50K thats for sure!
    Jakuzzi and turbo-joe like this.
  24. Natkingcolebasket69
    Jul 2, 2017
    2,040
    Bay Area
    This reminds me of me when I had my cl65 amg...I pushed it to 700bhp, them
    Changed brakes, tcu, diff etc... in the end I could have gotten another car...
    The tr is a collectible, enjoy it for what it is or buy another new Ferrari to ride along with;)
    Jakuzzi and jpanz like this.
  25. Testarossa Lover
    Testarossa Lover F1 Rookie
    Silver Subscribed Owner
    Dec 31, 2006
    3,362
    Newport Beach, CA
    Haig Barsamian
    Tr is not a slow car. I have taken on countless 360 & 430s with it and surprised many with her performance.
    I will not buy it to collect, I will buy it to drive.
    jpanz, Shamile, Tifosi Dude and 2 others like this.
