458 - What is the proper way to park the car? Shift to neutral? | FerrariChat
458 What is the proper way to park the car? Shift to neutral?
Discussion in '458 Italia/488/F8' started by s4play, Mar 17, 2020.
  1. s4play
    s4play Karting
    Oct 25, 2006
    171
    How do you guys park this car?
    Leave it in gear and just turn the key to shut it off?
    Do I shift to neutral first?
    What is the P/S button used for?
    thanks!
  2. Ianjoub
    Ianjoub Formula Junior
    Dec 22, 2019
    906
    Homosassa, FL USA
    Ian Joubert
    leave in 1st and shut off key
    PS = launch control
  3. AlfistaPortoghese
    AlfistaPortoghese Moderator
    Mar 18, 2014
    3,778
    Europe, but not by much.
    Nuno
    Always leave it in gear (1st or R - I leave mine in 1st).
    You can leave it in neutral, in theory. Just make sure the Auto Park has engaged when you turn off the key. I don’t recommend it though.
    I don’t have a PS button. Is it a US market thing?
    Kind regards,
    Nuno
    Caeruleus11 likes this.
  4. wthensler
    wthensler F1 Rookie
    3,489
    Gator Country, FL
    William
    Yes, seems to be a US thing. I also shut mine off in first gear.
    AlfistaPortoghese likes this.
  5. Borrow’d Mine
    Borrow’d Mine Formula Junior
    979
    Florida
    Turn it off from any gear, R, or N. Usually, the owners manual is in the front boot - just sayin ;)
  6. scott61
    scott61 F1 Rookie
    Feb 11, 2004
    2,606
    North of Boston
    Yours would be called "LAUNCH"
  7. RayJohns
    RayJohns F1 Veteran
    7,837
    West Coast
    Ray
    Owner's manual, page 47 and also page 156.
    You gotta be careful you don't accidentally put the car into what's called "Car wash mode" and have the thing roll away on you.
    Best thing is to shift into 1st gear, then turn the motor off. That will cause the gearbox to go into Park Lock. There is also an electronic parking brake off the rear rotors.
    Ray
  8. Euroryno
    Euroryno Formula Junior
    Feb 2, 2015
    325
    New Zealand
    Ryan
    I believe P/S means ‘Power Start’ aka ‘Launch Control’ in other markets.
    Turning off in neutral will still engage ‘Park’ mode ...in Speciale at least. I always park up like that and also turn hand brake to ‘off’ so it’s not clamped on for long periods. ‘Park’ is sufficient to hold it in place.
  9. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    Yep, Due to the nannies in the US that also tell you not to dry your cat in the microwave, you cannot have a button that says Launch. So they get a "PS" button instead of a Lauch button.
  10. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    If you shut it off in any gear, it will go directly to P. If you shut it off in N, it will go to P after about 10-20 seconds I think. Nothing wrong with eitehr.
  11. jomarti1
    jomarti1 Karting
    Feb 27, 2017
    77
    S. Florida
    PS means in Italian Partenza Sportiva. In English means Performance Start.
  12. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Yes. Literal translation is start sport.
  13. up4speed
    up4speed F1 Rookie
    3,639
    Long Island, NY
    Chris
    I think it’s Sport Departure
    Need4Spd likes this.
  14. AlfistaPortoghese
    Mar 18, 2014
    3,778
    Nuno
    “Launch”, imho, is way cooler. Fighter jet style.
    Kind regards,
    Nuno.
