What is the voltage my alternator should put out when the car is running? 348 | FerrariChat
Discussion in '348/355' started by Paresh, Jul 23, 2010.
  1. Paresh
    Paresh Karting
    Oct 5, 2009
    57
    Illinois
    Paresh
    Car is at 12.4 when stopped. 13.4 when running. Battery light is on. It has died only once. Belt tension is fine.
    Thanks!!!!! Also, when and if I have to build the alternator, what parts are most important to replace?
  2. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    That sounds pretty good actually.
    JM
  3. BigTex
    79,380
    Houston, Texas
    Bubba
    13.2 - 13.4v is a good output, IMO....check the cables or the battery itself for probems..
  4. JoshECS
    JoshECS Formula Junior
    433
    Ashburn,VA
    Josh Hill
    #4 JoshECS, Jul 23, 2010
    14.0v is considered to be the minimum allowed output while running. Most cars are between 14-14.5v when everything is working correctly and there isn't resistance in the cables. Check to see if the voltage increases with rpm, and Ohm test the two primary ground cables. There shouldn't be more than .1 ohm of resistance.
  5. Rifledriver
    37,104
    Checking voltage without load doesn't tell you much. It needs to be loaded to its rated amperage to determine condition or you will have battery problems and issues with digital electronics.
  6. roadracer311
    roadracer311 Formula 3
    May 6, 2009
    2,398
    San Francisco
    Paul
    My F355 puts out 14.5V at idle. My test was done with a fully charged, nearly new battery, and about 500 miles on the alternator (and whole car).
  7. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,728
    With a fully charged battery, and the car running for more than 10 minutes, you should see 14.0-14.2 V. After you stop the car, this will drift downward over 8 hours to about 13.5V and after a week to about 12.8V (no discharge).
  8. BOKE
    BOKE Beaks' Gun Rabbi
    33,965
    600 East Fremont Street
    Lucky
    http://www.saveabattery.com/
    The battery maintainer is a great trickle charger that can test your electrical system under load.
    Just checking what the alternator puts out or your battery voltage without a load isn't that good diagnostically.
    I have no affiliation with the company other than buying six units from them. Amazon sells them too.
    Always check your cables too.
    Good luck!
  9. Paresh
    Paresh Karting
    Oct 5, 2009
    57
    Illinois
    Paresh
    Thank you Brotherhood! The alternator rebuild resolved the issue. It was a Nippondenso. 100 dollars to rebuild. 1 hr to remove/install. New battery in car.
    All is good again!
  10. Rifledriver
    37,104
    Great guy and great product. He lives nearby and stops by from time to time.
