What is this gunk in my dry sump oil reservoir? | FerrariChat
Discussion in '308/328' started by Ossie, May 15, 2010.
  1. Ossie
    Ossie Formula Junior Owner
    May 20, 2009
    666
    Melbourne, Australia
    Owen
    I keep finding slimy yellow stuff around the top of the oil reservoir in my dry sump 76 308 GTB (see attached photo). It doesn't appear to be in the actual oil but just collects around the cap and on the top inside of the reservoir. It looks like the old girl has a bad cold!
    I think I read somewhere once that it the result of the car making lots of short trips and never warming up properly. Anyone else come across this? It seems to get worse in the winter months, but car runs fine otherwise.
    P.S. No jokes please, we're all adults (I think!)
  2. jmn
    jmn Formula Junior
    Jan 31, 2005
    361
    Colorado
    jmn
    It might just be condensation from a lot of short trips, but it looks like quite a bit to me. You may have coolant in your oil for an unknown but potentially expensive reason. I have an early dry sump glass car, and have never seen anything like that, although I live in a very dry climate (Colorado).
  3. Ossie
    May 20, 2009
    666
    Owen
    Thanks. This is also an early RHD glass dry sump car, but our climate (Melbourne, Australia) goes from stinking hot in summer to wet and cold in winter. As mentioned it has only started to appear again in the past few weeks as our weather has started cooling down. Car does not appear to be losing any coolant so I've pretty much ruled out coolant/oil contamination (I think)...
  4. b27
    b27 F1 World Champ
    Oct 11, 2007
    15,781
    Brett
    I would still get it checked out Ossie, give your mechanic a quick call. The weather of late has been quite mild and the humidity hasn't been that high. The combination of H2O and oil make the yellow gunk. Perhaps you just need to drive it a bit more. ;)
  5. miketuason
    miketuason F1 World Champ Owner Silver Subscribed
    Feb 24, 2006
    15,814
    Cerritos, CA.
    Check your water reservoir and see if it has the same gunk.
  6. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    Yes, I hate to say it --- but I agree --- it may be coolant contaminating the oil system.
    However, unless you have owned that car since brand new, you can't be certain that someone didn't add some sort of "additive" to the oil along the way. Do a pressure test on the coolant system for leaks ---- if it's okay, change your oil, and see if the goo comes back (you may need to change the oil several times to get rid of all the residue).
  7. 350HPMondial
    350HPMondial F1 Veteran Silver Subscribed
    Feb 1, 2002
    5,326
    Edwardo
    Oh,oh,
    Pull, rear head... Ill bet the gasket is failing or close too.. Then, pull the motor.
    (ouch, Here we go,,, $$,$$$.$$ !!!!!!!!!)
    I'll bet you can get in and out for like, $ 8,000.00
    Good luck,
    Love the car,, wanna trade now...?
    Edwardo
    1981 Mondial 8, Euro with CA papers, no cats ever.
    Balanced and blueprinted 2V 308 motore'
  8. Ossie
    May 20, 2009
    666
    Owen
    Thanks guys, yes I suspect coolant is the most likely, although I've driven the car at least 4000+ miles in this condition in the past 12 months and it doesn't seem to be getting any worse or causing any other issues. A pressure test of the cooling system sounds like a good idea so might start with that and change the oil again as a precaution.
    Doesn't concern me greatly if I have to pull the engine as I know it's down on compression on 2 cylinders anyway and I was expecting to do rebuild at some point (just need to finish building the new workshop first!). In the meantime just plan to continue driving and enjoying it as it still runs like clockwork.
  9. finnerty
    May 18, 2004
    10,406
    Coolant (if it is) in the oil AND low compression in one or more cylinders is fairly indicative of a blown (or at least leaking) head gasket, mate.
    BTW, when you do your pressure testing, do two separate tests --- one with a cold engine, and one with a hot engine --- it's important to do both for accurate testing.
  10. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,041
    Another vote for short trips. Check your crankcase breathers. I've seen really bad formations of gunk there.
  11. Marco Bussadori
    Marco Bussadori Formula Junior
    Aug 6, 2007
    430
    London
    Marco Bussadori
    This is totally normal behavior.
    What you have there is a "foam" that is made up by a suspension of water in oil bubbles.
    There will always be a bit of condensate water in the oil system. As the oil travels around etc. it can form a bit of foam. The bubbles in the foam will contain water vapor. The part of the oil system (the filler neck) is also the coldest part of the system so it is completely normal that you will find this gunk there as it is the first place where as the oil cools it will form a lower viscosity greasy concentrate.
    The filler neck will not warm up enough to melt all the deposit on short runs and so you have a build up.
    This usually forms more in lower quality olis (or slightly older higher quality oils). You can find additives to prevent it, or use oils (like Redline 10W-40) which have an anti foaming agent added to them.
    I see it more in winter than summer.
    So, I say, If she has a snotty nose, then wipe it for her? (trying to remain adult about this)
    M
  12. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    +1 , looks like condensation. Check out the easy stuff first and don't suspect a major issue. Do the cooling system pressure test and if you want to do something else then drain the oil and send out a sample for analysis.
  13. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    Agreed, I've seen this on other dry sump cars (More prevalent with high paraffin content oils). Wipe it out. Pressure check the cooling system. If all is well, take it for a good LONG drive... at least 40-50 miles. When you get back, crack, don't open - just crack the oil cap and let any pressure bleed off then close it and let things cool down.
    If you are just encountering condensation, a long drive will boil it out of your oil system and most will be driven off via the normal breathing of the crankcase. You may get a steam pocket in the dry sump tank so be sure to crack the cap just in case the normal venting is not working.
    Rick
  14. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,876
    Mike 996
    "Doesn't concern me greatly if I have to pull the engine as I know it's down on compression on 2 cylinders anyway"
    Are they adjacent cylinders?
  15. f355spider
    f355spider F1 World Champ Owner Rossa Subscribed
    May 29, 2001
    18,048
    My girlfriends Toyota Tundra did this with the factory dino oil in the winter months (lot's of short trips). I changed it over to Mobil 1 and it stopped doing it immediately.
  16. Flinch
    Flinch Formula Junior
    Nov 15, 2009
    302
    Holland and Sweden
    Peter El Cheapo
    When the comprssion is down on 2, you have to be careful, very careful. Better test coolant pressure and do it the right way. Then again, if you have compression loss, it is time to do some serious maintenance. And if you have to adjust the valves, take of the heads too and replace the gaskets. It is easier/cheaper to do it all at once.
    I'd say, pull the engine. Better safe than sorry. It the oil is contaminated with too much coolant the mains and crank will die!
