What is this in the engine bay | FerrariChat
Discussion in '308/328' started by BwanaJoe, Nov 1, 2007.
  1. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    #1 BwanaJoe, Nov 1, 2007
  2. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,844
    NoNJ/Jupiter FL
    Steve W.
    Well that's strange. What is the other end connected to, or where is it going? Looks like a vent hose of some kind, but nothing down there it would attach to. Maybe it fell down from up above?
  3. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    It is connected to the air intake just below the connector to the filter. It feels like one piece of plastic.
  4. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    29,541
    E ' ' '/ F
    Trailer Swift
    It's designed to blow cool air on the CV joint.
  5. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    Thanks. Glad it isn't something that was busted!
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    12,912
    The twilight zone
    The Butcher
    and without that $2 dollar tube, you need to replace the CV boot every 2 years :(
  7. GrigioGuy
    Nov 26, 2001
    29,541
    E ' ' '/ F
    Trailer Swift
  8. Formula Uno
    Formula Uno F1 Veteran
    Oct 8, 2008
    6,659
    New York City
    So the opening is for cooling the cats or cv joint, and has nothing to do with my high oil temps, right???
    It the gauge is reading correctly, what else could be causing the oil to heat up so much...especially since the water temps are fine?
    Frank
  9. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,691
    Mike 996
    To cool a CV joint? SERIOUSLY? Never heard of CV joints overheating unless the gaiter has torn and allowed the grease to be thrown out. If that thing is really for that purpose then those EyeTies are even wierder than old Limey motorcycle designers!!
  10. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    #10 CliffBeer, Apr 27, 2009
    No need to cool a cv joint - unless perhaps you're involved in WRC...
  11. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    #11 finnerty, Apr 27, 2009
    To be a little more specific...
    There's a spot back and under there on the 308 where the lead pipe from the forward bank comes very close to both the differential and the inboard CV joint on the passenger side. The area is not well ventilated, so the exhaust pipe tends to make temps pretty high there, and the duct blows fresh air into this location to try to cool both the diff and the joint boot ----- doesn't work all that great though. I added a heat shield around my pipe a while back, tossed the duct in the trash can, and now I don't have to replace that cv boot until it wears out "normally" :).
  12. 308 GTB
    308 GTB F1 World Champ
    11,189
    New Jersey
    Barry Wolinsky
    #12 308 GTB, Apr 27, 2009
  13. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    This is not on the earlier carb cars so we must not have as hot of an exhaust , HAHAHAHA
  14. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,691
    Mike 996
    LOL! Well I'll be darned! OK, from now on if anybody tells me that Ferrari's are better designed than Fords, I'll just show 'em that picture! :)
  15. dwhite
    dwhite F1 Rookie
    #15 dwhite, Apr 27, 2009
    Changed the cam belts and tensioner bearings Saturday with another fchatter and we were joking about the tube and what it would cost from ferrari. Does not do a good job, my car also needs a new boot. We came to the wrong conclusion it was just to try and cool the entire engine compartment somewhat. He has a '77 so his car does not have one.
  16. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    Try checking the parts manual for the location of the oil temp sender. I honestly have no clue where it is located. Next, clean every contact you can find in that circuit path including the gauge connections themselves. I use dielectic grease to keep the corrosion down. It MAY just be dirty contacts or grounds after all these years. Or, the gauge itself is out of whack. Or, that oil temp sender is hosed.
    Don't feel bad, I am doing the same thing right now for my water temp gauge. Ahhhh, the fun never stops...
  17. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    #17 Brian Harper, Apr 27, 2009
    Once you find the temp sensor pull it out, rig up a ground wire and dip it in a pan of very recently boiling water. If you don't get 100C/212F, keep on working on the circuit. If you do get 100C, then put the sensor back in and find out why your oil is getting so hot.
    308GTB/GTS: Table 17 - LUBRICATION SYSTEM (308 GTS AND AUS) shows a thermistor right in the neighborhood of the shifter input on the front of the engine. I would guess draining the oil first before pulling this out would be a good idea, or at least be ready with an adequate bucket. I would also guess a dry sump car would have it on the oil tank, but I didn't see it on the TAV.
