What is this plug for please? | FerrariChat
Discussion in '348/355' started by belfry, Feb 9, 2020.
  1. belfry
    belfry Formula Junior
    May 14, 2015
    398
    Robert Batt
  2. belfry
    May 14, 2015
    398
    Robert Batt
    1990 Mondial T gearbox (same as the 348). I know that it's not the transmission fluid drain plug, as I've changed the transmission oil last year.
    I have been noticing the occasional drip of oil on the garage floor so I am investigating the underside of the car today.
    The plug/nut that I am pointing to in the photo turns freely and is not tight.
    Many thanks in advance.
  3. m.stojanovic
    m.stojanovic F1 Rookie
    2,752
    Malaysia - KL
    Miroljub Stojanovic
    It could be #3 (138739) on the diagram below. It is called "Rocker Arm Fastening Screw" (gear selector assembly) and there is a washer (#7) and an o-ring (#2) on it. It should not be just turning unless its threads have been stripped - easy to do as the body of the bolt is big but its threaded portion is much smaller diameter, probably M8. So, one may think "big bolt (hex head), big torque".
    energy88 likes this.
  4. belfry
    May 14, 2015
    398
    Robert Batt
    It's not the source of the occasional leak.
    Would you try to tighten it?
  5. energy88
    energy88 Two Time F1 World Champ
    27,052
    West of Fredericksburg, VA
    This is beginning to sound like a case of "if it ain't broke, don't fix it" for right now. I'd slap a sticker over it to prevent falling out and watch it like a hawk for leaks and put it on your "to do" list to take care of later when working on the gearbox and have replacement parts on hand.
  6. m.stojanovic
    2,752
    Malaysia - KL
    Miroljub Stojanovic
    ...fix it when the bolt falls out.
  7. Pangea
    Pangea Formula Junior
    Mar 27, 2011
    442
    Nick
    Just an observation..The rocker arm is part 1 and it looks like the bolt part 3 is secured by a nut part 6. If indeed that is the bolt thats loose someone may have previously tried to undo it by mistake so loosening the nut on the other end. If it is a lock nut of some type ,which is very likely in my experience, it may stay where it is and not unwind any further. Fingers crossed. Alternatively, as mentioned ,something may have stripped.
  8. Qavion
    Qavion F1 World Champ
    11,532
    Ian Riddell
    +1
    I had this bolt replaced for cosmetic reasons (the bolthead had contacted the ground at one point). This was during a full gearbox overhaul.
  9. 308 GTB
    308 GTB F1 World Champ
    11,183
    New Jersey
    Barry Wolinsky
    Another design wonder by Ferrari!
  10. m.stojanovic
    2,752
    Malaysia - KL
    Miroljub Stojanovic
    Very good observation, I did not notice the locknut on top. In that case, everything should be fine. The bolt is probably designed so that, when the nut is fully tightened, it can still rotate in order not to jam the selector crank and the o-ring is sufficiently compressed against the housing. The bolt should therefore not be unnecessarily rotated as the friction may damage the o-ring. here's a detail from the workshop manual:
    energy88 and Qavion like this.
  11. belfry
    May 14, 2015
    398
    Robert Batt
    Looking at the diagram carefully, this bolt will never fully tighten into the gearbox casing. The bolt is connected to the nut and, while these 2 can be tightened, there are no threads on the bottom of the bolt, or on the gearbox case. So the bolt is not supposed to tighten into the aluminium casing.
    On my car this bolt is tight but does turn if I put a socket on it. It looks like this is correct. Hopefully this will be useful for anyone else who might try to tighten this nut on their car!
  12. lanab
    lanab Formula Junior
    Feb 21, 2016
    448
    Stockholm, Sweden
    Probably some idiot thought it was the drain plug and stripped it.
  13. AceMaster
    Feb 6, 2009
    34,556
    Ontario, Canada
    Considering the drain plug is a few inches next to this....
  14. Rifledriver
    33,985
    Austin TX
    Nothing wrong with the design, just some people who try and fix them.
    taz355 likes this.
  15. Rifledriver
    33,985
    Austin TX
    I don't think it is possible to strip it.
  16. Dolcevita
    Dolcevita Formula 3
    1,377
    Ontario, Canada
    Craig
  17. Ferrarium
    Ferrarium F1 Veteran
    5,631
    Central NJ
    Eric
    No... I "believe" that's different the oil pimp pressure bolt is behind a different plug.
    Sent using FerrariChat.com mobile app
