What key should I have for my 95 355? | FerrariChat
Discussion in '348/355' started by phrogs, Aug 6, 2013.
  1. phrogs
    phrogs F1 Veteran
    7,339
    Kzoo Michigan
    I have a folding key like a F50 but I have been lead to believe it should be a different key.
    Does anyone have a photo of their key?
    Jp
  2. AceMaster
    Feb 6, 2009
    34,776
    Ontario, Canada
    Can you post a pic of your key?
  3. phrogs
    phrogs F1 Veteran
    7,339
    Kzoo Michigan
    #3 phrogs, Aug 6, 2013
  4. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,655
    South East
    Jimmie
    There's a very clear picture at the beginning of the owners handbook
  5. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,209
    CT
    John Kreskovsky
    #5 johnk..., Aug 6, 2013
  6. 355dreamer
    355dreamer F1 World Champ
    Apr 3, 2006
    10,476
    DC Metro
    L.C.
    #6 355dreamer, Aug 6, 2013
  7. AceMaster
    Feb 6, 2009
    34,776
    Ontario, Canada
    that is definitely the F40/348 key (and likely some other models), but doubtful it is the 355 key
  8. XLR8R
    XLR8R Karting
    Feb 14, 2013
    171
    Michigan
    Matt
    Same for me...this is the original key for the 355.
  9. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Many 95's came with the square key with light on it like Johnk posted. Later years came with the one like Luke posted (same one I have).
  10. Speedwayspyder
    Speedwayspyder Karting
    Dec 25, 2012
    81
    New Smyrna Beach, Fl
    David
    Mine looks like 355Dreamers key.
  11. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,990
    Northeast U.S.
    Jim
    I have the square keys like JohnK's. One has a light in it, although the light fell out. Does anyone know where to get a light for one of these?
  12. Turbo Ron
    Turbo Ron Formula Junior
    Nov 3, 2003
    262
    West Los Angeles, CA
    Ron Stavis
    Mine to.
  13. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    Me three..
  14. phrogs
    phrogs F1 Veteran
    7,339
    Kzoo Michigan
    Yeah I don't have it with me in Afghanistan...
  15. phrogs
    phrogs F1 Veteran
    7,339
    Kzoo Michigan
    That's what I thought, but it seems some cars came with that square one. While mine it seems was a replacement no matter what.
    Thanks guys
  16. PeteyP
    PeteyP Formula Junior
    May 3, 2005
    830
    NJ
    Petey
    #16 PeteyP, Aug 6, 2013
  17. mike_747
    mike_747 Formula Junior
    Dec 15, 2008
    794
    Seattle
    My key for my 95 is like 355 Dreamer. the square keys are blanks and look like knock-offs. JMTBW
  18. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,871
    Richmond
    Pete
    This is the key mine has, LED light built in, late Sept. '94 build '95 model year.
  19. Shorn355
    Shorn355 F1 Veteran
    6,857
    Colorado
    Scott
    Me four - I have both the sqare key pictured and the smaller one with the silver Cavallino.
    FWIW the keys for my 88TR are like the one the OP posted (folding).
  20. 355rockit
    355rockit Formula Junior
    Dec 1, 2010
    892
    San Marcos, CA
    Vas
    That is how mine looks too.
  21. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,990
    Northeast U.S.
    Jim
    Pete, my car was built the same month as yours Pete Sept '94 for the 95 model year. I was told that the key with the light is rare, but do not know if this true. The little light fell out of mine. Does yours work?
  22. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,871
    Richmond
    Pete
    No, mine has the same problem! I was hoping somebody would reply to your question on how to fix it so I could fix mine as well :). Oh well, may have to make a trip to radio shack and dig through their LED's to see if I can find a match. I'll have to figure out how to take it apart and put a new battery in while I'm at it.
    Just curious, what number is your car? Mine is 100329, maybe ours were on the line together.
  23. johnk...
    Jun 11, 2004
    11,209
    CT
    John Kreskovsky
    #23 johnk..., Aug 7, 2013
    My car is a June 95 build. As for the key with light, the key splits and the top half on the button side come off to replace the battery. The light is not an LED but a small incandescent bulb.
  24. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,990
    Northeast U.S.
    Jim
    Pete, I will have to check the number when I get a chance. Thanks John for showing where the key splits in two. Does it come apart easily? Any trick to it? My '97 911 key has a small light on it also. It looks to be about the same size, but have never taken it apart.
  25. johnk...
    Jun 11, 2004
    11,209
    CT
    John Kreskovsky
    You can pry it open with a small screw driver at the top left corner on the picture. Getting if back together is a bit of a pain. Place the battery under button (+ (flat) side up) and side the button into the key making sure the little tab at the top (to orientate the horse) straight up. That's easy. Next you have to put the cover on. This is more difficult because the cover piece has a little tube that extends through the bottom (for the key ring or chain) and you have to align that first. But this prohibits the "locking" tabs from snapping into place. Again, I use a little screw driver to pry the cover away from the bottom half so the cover can be snapped into place. If you are careful it won't leave any marks.
    I opened mine to replace the batteries bit found that the batteries were good. I had to clean where the bulb and battery make contact to the copper pieces and bend the contact at the back side of the bulb forward a bit. Now the lights work like a charm.
